cleat
314H cleanup and repair.
cleat
7 hours ago, 702854boy said:
You're supposed to use paint not blood for Wheel Horse red
Tell that to the little flying vampires (IE mosquitos).
I want to apply some red paint today but it is currently very foggy and once that clears the rain starts again for the next few days.
It seems we only get one day a week without rain any more.
ebinmaine
Reversed here.
cleat
6 minutes ago, ebinmaine said:
Reversed here.
You can have some of mine, I want to paint and to get a break from mowing grass every time we finally do get a nice day.
cleat
Governor lever bead blasted and painted.
I used chrome paint as that is what I had on hand.
Hopefully it will look OK.
New bolt and flat washer with the OEM nut.
Choke and throttle lever assembly ready to go together.
These were painted with the same chrome paint after bead blasting.
791543182_Chokeandthrottleleverassemblyreadytogotogether.JPG.13d7f0705f4c611264b74d43e8050bc3.JPG
Choke and throttle lever assembled.
New bolt, lockwasher, and flat washer.
All other parts OEM
I did use a new flat washer under the nut as well even though there was not one there and the parts manual does not show it.
  • Like 5
MainelyWheelhorse
2 hours ago, ebinmaine said:
Reversed here.
And apparently a month instead of a week apart too.
cleat
Maybe someone can help me out.
I am missing this linkage rod that goes from the choke lever on the carb to the choke lever.
I made one that works but an original would be nice.
I can order one but the shipping the vendors are charging is crazy.
sqrlgtr
I will check; I may have already used it but if not your welcome to it.
sqrlgtr
@cleat no luck on choke lever must of dun used it but will keep my eyes open just in case I over looked it.:handgestures-fingerscrossed:
cleat
Thank you.
cleat
Well, it is sunny today.
Supposed to rain tonight but I took that as a good day to apply some paint.
Top side of two hoods and two fenders got some red paint.
  • Like 6
cleat
Masking removed from bottom of hood.
Red is now complete.
There are some dust and bugs in the paint but I will clean that up later.
  • Excellent 3
cleat
Got the rear end out and propped up on stands.
It then got the final cleanup, wire wheeling, and sanding complete.
A coat of primer was applied.
I would have preferred red primer but I ran out of that so the grey will have to do.
A couple of coats of IH red was applied.
1043186761_Rearendpainted1.JPG.095dba5761597405bfc44a5942797454.JPG1606597721_Rearendpainted2.JPG.9ffd44064ed0a2a15a992b2cb71ab246.JPG1231498919_Rearendpainted3.JPG.07b3f1bf59db5e7461a5f16fafcddc38.JPG2139472341_Rearendpainted4.JPG.c6b2451811f408c1d3e831fc97b3fbb7.JPG
  • Like 4
Handy Don
Ya run what ya brung, right? Gray works.
I’m loving the spark plug! 🤣
  • Haha 1
cleat
Yea, it looks stupid but it keeps the paint out of the hydraulic return.
:ph34r:
cleat
Rear end rigged to lift without damaging the fresh paint.
I use an engine leveler to tweak the rigging so it sits level.
Rear end is now sitting on stands in shop awaiting the assembly that will happen this coming winter.
It is level in all ways to help with the assembly.
666105591_Rearendsupportedandlevelledinshop1.JPG.e707609a2b7255a6cbcbf203caccae46.JPG
1526113828_Rearendsupportedandlevelledinshop2.JPG.32e9c7d28b9cea8ac92ff79c1fe23fed.JPG
1534083640_Rearendsupportedandlevelledinshop3.JPG.9e25a7e1e4ff239201b093b9ef91cda5.JPG
  • Excellent 3
ebinmaine
Ain't stupid if it works!!
  • Excellent 2
SylvanLakeWH
I always wondered about that...
I work... so... :confusion-confused:
:lol:
  • Haha 3
sqrlgtr
:ph34r:
more like border line genius :handgestures-thumbupright: B) :D
ebinmaine
:lol:
I thought you retired.....
:hide:
  • Haha 1
cleat
Old rotten tires removed from rear wheels.
Inside part of wheel where the tires mount are in absolutely perfect condition.
Don't even need to clean up or paint this area on them.
These will seal up nicely with no need for tubes (good thing as 12" tubes are costly).
702854boy
I can get 2 Ar-pro ones off of the jungle site for around 30 bucks and they fit 23 8.50/9.50/10.50 and they are quite heavy duty and I have yet to have any problems and I've used them in 4 tractors so far
cleat
Rear wheels have been wire brushed and sanded.
Prime and paint will happen after the tires are mounted.
Front wheels have been wire wheeled, sanded, and primed on the tire side as they are very rusty in spots.
These will get tubes for sure.
827263305_Frontwheelswirewheeledsandedandprimed1.JPG.89472faddc6a0a9f166b9fe2741cd6ef.JPG
1329862508_Frontwheelswirewheeledsandedandprimed2.JPG.2ca28a43bfeccf3dbc109c5416acfb3e.JPG
804954714_Frontwheelswirewheeledsandedandprimed3.JPG.4386afb8550040f6d95c7678a0afe396.JPG
Front wheels have been painted on the tire side.
All four wheels now ready for the tires to be installed.
2009822128_Allfourwheelsreadyfortirestobeinstalled1.JPG.5cb57f062f9db84a02fee395051c6c13.JPG
320018048_Allfourwheelsreadyfortirestobeinstalled2.JPG.59f63769570dd72985bbc9832a9d741a.JPG
  • Excellent 2
