cleat 9,445 #51 Posted August 31 7 hours ago, 702854boy said: You're supposed to use paint not blood for Wheel Horse red Tell that to the little flying vampires (IE mosquitos). I want to apply some red paint today but it is currently very foggy and once that clears the rain starts again for the next few days. It seems we only get one day a week without rain any more. 2 Share this post Link to post Share on other sites
ebinmaine 81,278 #52 Posted August 31 22 minutes ago, cleat said: It seems we only get one day a week without rain any more. Reversed here. 1 Share this post Link to post Share on other sites
cleat 9,445 #53 Posted August 31 6 minutes ago, ebinmaine said: Reversed here. You can have some of mine, I want to paint and to get a break from mowing grass every time we finally do get a nice day. 1 Share this post Link to post Share on other sites
cleat 9,445 #54 Posted August 31 Governor lever bead blasted and painted. I used chrome paint as that is what I had on hand. Hopefully it will look OK. New bolt and flat washer with the OEM nut. Choke and throttle lever assembly ready to go together. These were painted with the same chrome paint after bead blasting. Choke and throttle lever assembled. New bolt, lockwasher, and flat washer. All other parts OEM I did use a new flat washer under the nut as well even though there was not one there and the parts manual does not show it. 5 Share this post Link to post Share on other sites
MainelyWheelhorse 3,208 #55 Posted August 31 2 hours ago, ebinmaine said: Reversed here. And apparently a month instead of a week apart too. 1 Share this post Link to post Share on other sites
cleat 9,445 #56 Posted September 1 Maybe someone can help me out. I am missing this linkage rod that goes from the choke lever on the carb to the choke lever. I made one that works but an original would be nice. I can order one but the shipping the vendors are charging is crazy. Share this post Link to post Share on other sites
sqrlgtr 4,224 #57 Posted September 1 I will check; I may have already used it but if not your welcome to it. 1 Share this post Link to post Share on other sites
sqrlgtr 4,224 #58 Posted September 1 @cleat no luck on choke lever must of dun used it but will keep my eyes open just in case I over looked it. 1 Share this post Link to post Share on other sites
cleat 9,445 #59 Posted September 1 2 minutes ago, sqrlgtr said: @cleat no luck on choke lever must of dun used it but will keep my eyes open just in case I over looked it. Thank you. Share this post Link to post Share on other sites
cleat 9,445 #60 Posted September 3 Finally got a sunny day here today. It rained just under an inch last night though. I managed to get the bottom of the hoods and fenders painted that I had sanded and primed a few days ago. Hopefully I can get the top sides painted on Sunday as it is not supposed to rain that day. 12 Share this post Link to post Share on other sites
cleat 9,445 #61 Posted September 6 Well, it is sunny today. Supposed to rain tonight but I took that as a good day to apply some paint. Top side of two hoods and two fenders got some red paint. 7 1 Share this post Link to post Share on other sites
cleat 9,445 #62 Posted September 6 Masking removed from bottom of hood. Red is now complete. There are some dust and bugs in the paint but I will clean that up later. 2 3 Share this post Link to post Share on other sites
cleat 9,445 #63 Posted September 7 Got the rear end out and propped up on stands. It then got the final cleanup, wire wheeling, and sanding complete. A coat of primer was applied. I would have preferred red primer but I ran out of that so the grey will have to do. A couple of coats of IH red was applied. 6 1 Share this post Link to post Share on other sites
Handy Don 17,735 #64 Posted September 7 Ya run what ya brung, right? Gray works. I’m loving the spark plug! 🤣 1 1 Share this post Link to post Share on other sites
cleat 9,445 #65 Posted September 7 21 minutes ago, Handy Don said: Ya run what ya brung, right? Gray works. I’m loving the spark plug! 🤣 Yea, it looks stupid but it keeps the paint out of the hydraulic return. 1 1 Share this post Link to post Share on other sites
cleat 9,445 #66 Posted September 7 Rear end rigged to lift without damaging the fresh paint. I use an engine leveler to tweak the rigging so it sits level. Rear end is now sitting on stands in shop awaiting the assembly that will happen this coming winter. It is level in all ways to help with the assembly. 2 3 Share this post Link to post Share on other sites
ebinmaine 81,278 #67 Posted September 7 2 hours ago, cleat said: Yea, it looks stupid but it Ain't stupid if it works!! 1 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,919 #68 Posted September 7 43 minutes ago, ebinmaine said: Ain't stupid if it works!! I always wondered about that... I work... so... 3 Share this post Link to post Share on other sites
sqrlgtr 4,224 #69 Posted September 7 3 hours ago, cleat said: Yea, it looks stupid but it keeps the paint out of the hydraulic return. more like border line genius Share this post Link to post Share on other sites
ebinmaine 81,278 #70 Posted September 7 16 minutes ago, SylvanLakeWH said: I always wondered about that... I work... so... I thought you retired..... 1 Share this post Link to post Share on other sites
cleat 9,445 #71 Posted September 8 Old rotten tires removed from rear wheels. Inside part of wheel where the tires mount are in absolutely perfect condition. Don't even need to clean up or paint this area on them. These will seal up nicely with no need for tubes (good thing as 12" tubes are costly). 3 Share this post Link to post Share on other sites
702854boy 1,245 #72 Posted September 8 1 hour ago, cleat said: (good thing as 12" tubes are costly). I can get 2 Ar-pro ones off of the jungle site for around 30 bucks and they fit 23 8.50/9.50/10.50 and they are quite heavy duty and I have yet to have any problems and I've used them in 4 tractors so far 2 Share this post Link to post Share on other sites
cleat 9,445 #73 Posted September 8 Rear wheels have been wire brushed and sanded. Prime and paint will happen after the tires are mounted. Front wheels have been wire wheeled, sanded, and primed on the tire side as they are very rusty in spots. These will get tubes for sure. Front wheels have been painted on the tire side. All four wheels now ready for the tires to be installed. 3 3 Share this post Link to post Share on other sites
cleat 9,445 #74 Posted September 10 Getting ready to mount tires. I did this yesterday but the internet went down due to heavy rain so I could not post pics. Rears are Carlisle turfmasters that I got a great deal on last winter (I don't remember who from). This is the tool I use for all of my Lawn and garden tractor tire mounting and demounting. Rear wheel mounted on tool. New TR413 valve stem ready to be installed. Tool used to pull valve stem into position after giving it a light lube with dish soap. Valve stem installed. Tire bead and outer edge of wheel was lubed with dish soap then the tire was pushed on. These tires seem just slightly small so it is quite a push to get it on. Next step is to put a couple of clamps on the tire to reduce it's width so it is held down into the smaller diameter portion of the wheel for the tire installation to go easier. The tire bead, top edge of the wheel, and the tire installation tool are lubed with dish soap and the tire is popped into place. Tires aired up to 20 PSI to fully seat onto the beads Tires sprayed with Snoop to check for leaks. None found. Front wheel sat on tool. Front wheel clamped into place then the tire was lubed and popped into place. Again, harder than it sounds but it went on. Tube installed and the valve stem tool is screwed on so I don't accidentally knock it down installing the tire. Front tire installed using the same technique as for the rear with the clamps and lube (I know that sounds bad). All four assemblies taken outside and washed to clean up the tires and get rid of any dish soap. 7 2 Share this post Link to post Share on other sites
cleat 9,445 #75 Posted September 10 Hoodstand wire wheeled and sanded. + Hoodstand cracks welded up. I have never had a Wheel Horse yet that was not cracked there. Hole drilled for foot control auto center spring to hook into. Hole is 11/64" and is 1.75 inches from right side and down .25 inches. Tires masked ready for wheels to be painted. 2 3 Share this post Link to post Share on other sites
