cleat 9,193 #51 Posted August 31 7 hours ago, 702854boy said: You're supposed to use paint not blood for Wheel Horse red Tell that to the little flying vampires (IE mosquitos). I want to apply some red paint today but it is currently very foggy and once that clears the rain starts again for the next few days. It seems we only get one day a week without rain any more. 2 Share this post Link to post Share on other sites
ebinmaine 80,243 #52 Posted August 31 22 minutes ago, cleat said: It seems we only get one day a week without rain any more. Reversed here. 1 Share this post Link to post Share on other sites
cleat 9,193 #53 Posted August 31 6 minutes ago, ebinmaine said: Reversed here. You can have some of mine, I want to paint and to get a break from mowing grass every time we finally do get a nice day. 1 Share this post Link to post Share on other sites
cleat 9,193 #54 Posted August 31 Governor lever bead blasted and painted. I used chrome paint as that is what I had on hand. Hopefully it will look OK. New bolt and flat washer with the OEM nut. Choke and throttle lever assembly ready to go together. These were painted with the same chrome paint after bead blasting. Choke and throttle lever assembled. New bolt, lockwasher, and flat washer. All other parts OEM I did use a new flat washer under the nut as well even though there was not one there and the parts manual does not show it. 5 Share this post Link to post Share on other sites
MainelyWheelhorse 3,039 #55 Posted August 31 2 hours ago, ebinmaine said: Reversed here. And apparently a month instead of a week apart too. 1 Share this post Link to post Share on other sites
cleat 9,193 #56 Posted September 1 Maybe someone can help me out. I am missing this linkage rod that goes from the choke lever on the carb to the choke lever. I made one that works but an original would be nice. I can order one but the shipping the vendors are charging is crazy. Share this post Link to post Share on other sites
sqrlgtr 3,693 #57 Posted September 1 I will check; I may have already used it but if not your welcome to it. 1 Share this post Link to post Share on other sites
sqrlgtr 3,693 #58 Posted September 1 @cleat no luck on choke lever must of dun used it but will keep my eyes open just in case I over looked it. 1 Share this post Link to post Share on other sites
cleat 9,193 #59 Posted September 1 2 minutes ago, sqrlgtr said: @cleat no luck on choke lever must of dun used it but will keep my eyes open just in case I over looked it. Thank you. Share this post Link to post Share on other sites
cleat 9,193 #60 Posted Thursday at 09:59 PM Finally got a sunny day here today. It rained just under an inch last night though. I managed to get the bottom of the hoods and fenders painted that I had sanded and primed a few days ago. Hopefully I can get the top sides painted on Sunday as it is not supposed to rain that day. 11 Share this post Link to post Share on other sites
cleat 9,193 #61 Posted Sunday at 03:49 PM Well, it is sunny today. Supposed to rain tonight but I took that as a good day to apply some paint. Top side of two hoods and two fenders got some red paint. 6 Share this post Link to post Share on other sites
cleat 9,193 #62 Posted Sunday at 05:13 PM Masking removed from bottom of hood. Red is now complete. There are some dust and bugs in the paint but I will clean that up later. 2 3 Share this post Link to post Share on other sites
cleat 9,193 #63 Posted 8 hours ago Got the rear end out and propped up on stands. It then got the final cleanup, wire wheeling, and sanding complete. A coat of primer was applied. I would have preferred red primer but I ran out of that so the grey will have to do. A couple of coats of IH red was applied. 4 Share this post Link to post Share on other sites
Handy Don 17,285 #64 Posted 7 hours ago Ya run what ya brung, right? Gray works. I’m loving the spark plug! 🤣 1 1 Share this post Link to post Share on other sites
cleat 9,193 #65 Posted 7 hours ago 21 minutes ago, Handy Don said: Ya run what ya brung, right? Gray works. I’m loving the spark plug! 🤣 Yea, it looks stupid but it keeps the paint out of the hydraulic return. 1 1 Share this post Link to post Share on other sites
cleat 9,193 #66 Posted 7 hours ago Rear end rigged to lift without damaging the fresh paint. I use an engine leveler to tweak the rigging so it sits level. Rear end is now sitting on stands in shop awaiting the assembly that will happen this coming winter. It is level in all ways to help with the assembly. 2 3 Share this post Link to post Share on other sites
ebinmaine 80,243 #67 Posted 5 hours ago 2 hours ago, cleat said: Yea, it looks stupid but it Ain't stupid if it works!! 1 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,100 #68 Posted 4 hours ago 43 minutes ago, ebinmaine said: Ain't stupid if it works!! I always wondered about that... I work... so... 3 Share this post Link to post Share on other sites
sqrlgtr 3,693 #69 Posted 4 hours ago 3 hours ago, cleat said: Yea, it looks stupid but it keeps the paint out of the hydraulic return. more like border line genius Share this post Link to post Share on other sites
ebinmaine 80,243 #70 Posted 4 hours ago 16 minutes ago, SylvanLakeWH said: I always wondered about that... I work... so... I thought you retired..... 1 Share this post Link to post Share on other sites
