cleat
314H cleanup and repair.
cleat
7 hours ago, 702854boy said:
You're supposed to use paint not blood for Wheel Horse red
Tell that to the little flying vampires (IE mosquitos).
I want to apply some red paint today but it is currently very foggy and once that clears the rain starts again for the next few days.
It seems we only get one day a week without rain any more.
ebinmaine
Reversed here.
cleat
6 minutes ago, ebinmaine said:
Reversed here.
You can have some of mine, I want to paint and to get a break from mowing grass every time we finally do get a nice day.
cleat
Governor lever bead blasted and painted.
I used chrome paint as that is what I had on hand.
Hopefully it will look OK.
New bolt and flat washer with the OEM nut.
Choke and throttle lever assembly ready to go together.
These were painted with the same chrome paint after bead blasting.
791543182_Chokeandthrottleleverassemblyreadytogotogether.JPG.13d7f0705f4c611264b74d43e8050bc3.JPG
Choke and throttle lever assembled.
New bolt, lockwasher, and flat washer.
All other parts OEM
I did use a new flat washer under the nut as well even though there was not one there and the parts manual does not show it.
  • Like 5
MainelyWheelhorse
2 hours ago, ebinmaine said:
Reversed here.
And apparently a month instead of a week apart too.
cleat
Maybe someone can help me out.
I am missing this linkage rod that goes from the choke lever on the carb to the choke lever.
I made one that works but an original would be nice.
I can order one but the shipping the vendors are charging is crazy.
sqrlgtr
I will check; I may have already used it but if not your welcome to it.
sqrlgtr
@cleat no luck on choke lever must of dun used it but will keep my eyes open just in case I over looked it.:handgestures-fingerscrossed:
cleat
Thank you.
cleat
Well, it is sunny today.
Supposed to rain tonight but I took that as a good day to apply some paint.
Top side of two hoods and two fenders got some red paint.
  • Like 6
cleat
Masking removed from bottom of hood.
Red is now complete.
There are some dust and bugs in the paint but I will clean that up later.
  • Excellent 3
cleat
Got the rear end out and propped up on stands.
It then got the final cleanup, wire wheeling, and sanding complete.
A coat of primer was applied.
I would have preferred red primer but I ran out of that so the grey will have to do.
A couple of coats of IH red was applied.
1043186761_Rearendpainted1.JPG.095dba5761597405bfc44a5942797454.JPG1606597721_Rearendpainted2.JPG.9ffd44064ed0a2a15a992b2cb71ab246.JPG1231498919_Rearendpainted3.JPG.07b3f1bf59db5e7461a5f16fafcddc38.JPG2139472341_Rearendpainted4.JPG.c6b2451811f408c1d3e831fc97b3fbb7.JPG
Handy Don
Ya run what ya brung, right? Gray works.
I’m loving the spark plug! 🤣
  • Haha 1
