Beap52 2,537 #1 Posted July 10 The back of the my camper shell was ever so lightly loose so I decided to tighten the bolts a bit. I decided to check the other five bolts and below is what one of them looked like. One failing isn't much of an issue but if the majority of the others had rusted, this could have lead to a disaster Easy to miss some important maintenance. 5 Share this post Link to post Share on other sites
ri702bill 13,393 #2 Posted July 10 Looks familar - we have Bridge supports that look like that here in RI !! 1 Share this post Link to post Share on other sites
JCM 11,470 #3 Posted July 10 I have had many caps on many trucks since 1978. On the aluminum one's I used 4 clamps on the short beds and 6 on the long beds. On my commercial caps always bolted down.Always good to check them. Good find 1 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #4 Posted July 10 21 minutes ago, JCM said: Good find 1 Share this post Link to post Share on other sites
ri702bill 13,393 #5 Posted July 11 We had a Dodge Dakota at work for pickups & deliveries that had a cap... one day it came back minus the cap - it flew off on Rt 95! 2 1 Share this post Link to post Share on other sites
953 nut 70,653 #6 Posted July 11 11 hours ago, JCM said: On the aluminum one's I used 4 clamps on the short beds and 6 on the long beds Aluminum is very susceptible to galvanic corrosion when in contact with a dissimilar metal. Stainless steel fasteners should have been used. 5 Share this post Link to post Share on other sites
ebinmaine 81,281 #7 Posted July 11 21 minutes ago, 953 nut said: Aluminum is very susceptible to galvanic corrosion when in contact with a dissimilar metal. Stainless steel fasteners should have been used. On the few I've seen the clamps are also aluminum. Share this post Link to post Share on other sites
JCM 11,470 #8 Posted July 11 4 hours ago, ebinmaine said: On the few I've seen the clamps are also aluminum. Yes they are. 1 Share this post Link to post Share on other sites
adsm08 5,247 #9 Posted July 12 (edited) 12 hours ago, 953 nut said: Aluminum is very susceptible to galvanic corrosion when in contact with a dissimilar metal. Stainless steel fasteners should have been used. Every cap clamp I have ever used, going back to 1988, was an aluminum body with a stainless bolt. Edited July 12 by adsm08 3 Share this post Link to post Share on other sites
