peter lena 10,065 #26 Posted August 20 @ bradley david good , , did you clean out and re grease those 6203 , wide grease shield bearings ? every related bearing in deck / mule drive , has lucas x tra hd green chassis grease , ? wal mart $7 , 550 deg flash point , polyurea rated , stays with bearings , what a concept , farm equipment , also have this in my pto lever set up detailing , no bearing whine , smooth / easy spin ups , pete https://www.landmsupply.com/lucas-oil-x-tra-heavy-duty-grease-14-5-oz?gad_source=1&gad_campaignid=20358896375&gbraid=0AAAAADm05vyAKEXdhbXkKPM5xHl6aJe6H&gclid=CjwKCAjwy5rUBhB5EiwAIoAtCuYCyJDKMPVKKh4js00k6y6h7ARmTfZL7aaD5V94IWRkGtSAvLpd1hoCcRkQAvD_BwE bombproof lube , also check walmart $ 7 , pete Share this post Link to post Share on other sites
bradleydavidgood 42 #27 Posted August 22 On 8/20/2026 at 8:45 AM, 953 nut said: Rear discharge is the way to go, I do like it. I used it yesterday and it seemed to work well. And I love that I can trim close on both sides, especially because my yard is many small areas and it would be harder to turn around all the time. 1 Share this post Link to post Share on other sites
bradleydavidgood 42 #28 Posted August 22 On 8/20/2026 at 9:36 AM, OoPEZoO said: Welcome to the forum, glad you are getting things sorted out. I'm just up in Willow Street, and there are quite a few more of us that are local if you ever need a hand to figure out a problem. Just be careful of the guys who's answer is always "buy another tractor".....and I don't mean a replacement, I mean a 2nd, 3rd, 4th, 5th......LOL. I appreciate the videos of your trip to A-Z. I've bought plenty of stuff from them over the years either at the Big Show or shipped parts, but have always wanted to take a trip up. That wall of mower decks really makes me want to go check things out in person. I'm also a fan of the rear discharge, especially with a manual transmission. I mowed for 15+ years with a 36" rear discharge and my only complaint was that I wanted a larger deck. Thanks! Mine is not running that well. It is loud and poppy and backfires and flames out the exhaust and seems like it is not the right mixture or something else going on. The kid who sold it to me had just an angled pipe on the exhaust and also gave me the old muffler. I installed the old muffler and yesterday as I was mowing it blew the muffler right off...it was old and rusty but something is way too hot and forceful at the exhaust. Before I put another muffler on I need to get it running right. The previous owner said he didn't rebuild the carb so I thought I'd do that. And it slowed down going up hills and sometimes stalled out completely. Maybe the fuel pump is weak or the line is clogged somewhere. Share this post Link to post Share on other sites
bradleydavidgood 42 #29 Posted August 22 Oh, and when it would slow down and almost stall, giving some choke got it going again and then I could throttle it up and close the choke again. Also seems like fuel issue. Share this post Link to post Share on other sites
Handy Don 17,474 #30 Posted August 22 7 hours ago, bradleydavidgood said: Oh, and when it would slow down and almost stall, giving some choke got it going again and then I could throttle it up and close the choke again. Also seems like fuel issue. Carb overhaul then mixture settings. Governor setting and mechanism check. 1 Share this post Link to post Share on other sites
bradleydavidgood 42 #31 Posted August 22 3 hours ago, Handy Don said: Carb overhaul then mixture settings. Governor setting and mechanism check. Great, thank you! Share this post Link to post Share on other sites
OoPEZoO 609 #32 Posted August 22 Agree with Don. Sounds like typical carburetor “sitting around” with crappy gas in it. The maintenance manuals for these tractors/motors do a great job of getting things sorted out. Clean out the carb, set everything back the way it should be, and it will most likely run perfectly. At least that’s the experience I’ve had with any of the ones I’ve monkeyed with. These engines are very simple and reliable if taken care of Share this post Link to post Share on other sites
bradleydavidgood 42 #33 Posted August 23 14 hours ago, OoPEZoO said: Agree with Don. Sounds like typical carburetor “sitting around” with crappy gas in it. The maintenance manuals for these tractors/motors do a great job of getting things sorted out. Clean out the carb, set everything back the way it should be, and it will most likely run perfectly. At least that’s the experience I’ve had with any of the ones I’ve monkeyed with. These engines are very simple and reliable if taken care of Thank you! What manuals should I buy? Share this post Link to post Share on other sites
Handy Don 17,474 #34 Posted August 23 57 minutes ago, bradleydavidgood said: Thank you! What manuals should I buy? Buy? Odds are once you know the engine make and model a diligent interweb search will turn up a downloadable manual. Share this post Link to post Share on other sites
bradleydavidgood 42 #35 Posted August 23 32 minutes ago, Handy Don said: Buy? Odds are once you know the engine make and model a diligent interweb search will turn up a downloadable manual. I usually find that those searches end in endless scam links. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #36 Posted August 23 What engine do you have? A K321 or a M14? Share this post Link to post Share on other sites
Handy Don 17,474 #37 Posted August 23 8 hours ago, bradleydavidgood said: I usually find that those searches end in endless scam links. I guess I’ve done enough that I can usually spot the “come ons.” I do occasionally register with them to get a particular manual I’ve been unable to find elsewhere. When I do, I use a disposable email address. Share this post Link to post Share on other sites
OoPEZoO 609 #38 Posted August 23 Manuals can all be found here on the forum site. Just search for your specific model off the ID tag on your tractor. If you are struggling, take a pic of the ID tag and post we’ll help you find it Share this post Link to post Share on other sites
bradleydavidgood 42 #39 Posted August 25 Thanks for the info. The plate on the motor has no readable info on it anymore. Just a silver plate. Here are some pictures: Share this post Link to post Share on other sites
bradleydavidgood 42 #40 Posted August 26 Previously my tractor was identified as 87-89. Apparently there was a different engine in 1987 than 88-89.... 1987 Wheel Horse model: 31-14K802 Engine: Kohler M14S-601524 Factory charging system: 3-amp dual-output, unregulated No conventional 15-amp voltage regulator. Factory headlights are powered directly from the engine's AC stator circuit and normally work only while the engine is running. 1988 Wheel Horse model: 31-14K803 Engine: Kohler M14S-601540 15-amp regulated charging system 1989 Wheel Horse model: 31-14K804 Engine: Kohler M14S-601540 15-amp regulated charging system If you guys can't identify the engine exactly from the pictures, then maybe we can do it by looking for the regulated charging system. Thanks 1 Share this post Link to post Share on other sites
953 nut 69,313 #41 Posted August 26 With your air filter cover removed you will see the voltage regulator if yours is a 15 amp charging system. Share this post Link to post Share on other sites
OoPEZoO 609 #42 Posted August 26 I’ll bet the neighbors love that exhaust pipe….LOL. Share this post Link to post Share on other sites
pfrederi 21,150 #43 Posted August 26 You have the 15 Amp system Spec 601540 Can see the regulator circled in yellow Share this post Link to post Share on other sites
squonk 48,125 #44 Posted August 26 On 7/9/2026 at 9:51 PM, Lane Ranger said: i use a 42 inch recycling deck with my 314-8. The baffle on a resr discharge holds ghe grass clips in a little longer for recuts! But it also holds wet grass which i mowed over this week (dewy) that clings to the decks. I had it off today to clean! @Lane Ranger Did you pull the baffle off and get all that grass that gets trapped behind it? Share this post Link to post Share on other sites
bradleydavidgood 42 #45 Posted August 27 6 hours ago, OoPEZoO said: I’ll bet the neighbors love that exhaust pipe….LOL. Yea I was away for 3 weeks and the grass was high and the old muffler blew right off the side and dropped on the lawn. I had the gun range ear muffs on so it didn't bother me and was determined to finish the yard. I got the one side done then went down to the other side near the intolerant type neighbor who by the way runs loud equipment very often especially one of those very loud backpack blowers and has to get every leaf several times a week, powerwash everything, mow constantly, etc. Well when I turned around the wife was on the deck just looking at me and the man was almost jumping up and down like "no stop that!". I pointed to the little patch I had left as to say "Just this little bit more", and he jumped up and down even more. It was really funny but I restrained myself from laughing and drove the tractor away, parked it in it's spot and turned it off. So yea they loved it. If I saw/heard my neighbor mowing with no muffler, I'd take my mower over and finish it for him. 1 Share this post Link to post Share on other sites
bradleydavidgood 42 #46 Posted August 27 6 hours ago, pfrederi said: You have the 15 Amp system Spec 601540 Can see the regulator circled in yellow That's awesome! Thank you! Now for bonus points who can tell me if the tractor is 1988 or 1989 without any S/N or ID? Or confirm that there was no visible differences those years. Share this post Link to post Share on other sites
bradleydavidgood 42 #47 Posted August 27 4 hours ago, squonk said: @Lane Ranger Did you pull the baffle off and get all that grass that gets trapped behind it? I don't know what the baffle is but I don't think I have those circles around the blades like in your pic. I do need to clean the bottom of the deck. I'll have to do that in the next few days. I'll make a video. I was mowing wet grass and very tall dry grass. Share this post Link to post Share on other sites
Brockport Bill 2,478 #48 Posted August 27 On 7/11/2026 at 11:47 AM, bradleydavidgood said: Thanks for all the replies, I'll go thru them soon. In the meantime, I bought this deck The next thing I'm wondering is what I need to hook it up. After lunch I'll be taking a short video of my tractor and I'll post it. Thanks! people have there own priorities for "value" but IMO that price is high for that decks condition Share this post Link to post Share on other sites
Brockport Bill 2,478 #49 Posted August 27 if you have a 42 rear discharge deck ( not a recycler ) I suggest you consider adding a deflector on the rear - - i use vinyl base cove molding and carriage bolts - - it deflects the grass down rather than straight back - keeps the rear underneath of tractor much cleaner 1 Share this post Link to post Share on other sites
OoPEZoO 609 #50 Posted August 27 I imagine the difference between 88 and 89 is little to nothing. Have you checked the tractor itself for an ID tag? I believe it should be on the fender area under the seat. Either way, a search here for either 31-14K803 or 31-14K804 should get you all of your related manuals. Same goes for your mower decks, just search the model number, and it’s all freely accessible Share this post Link to post Share on other sites
