Natejc_98 20 #1 Posted 14 hours ago I’m looking for the recommended process to restore old wheels from grinding to sanding to painting. Also what tools are preferred in the process? 1 Share this post Link to post Share on other sites
AlexR 3,053 #2 Posted 13 hours ago (edited) I always just use a cordless drill with wire brushes to get it down to bare metal, after that clean well with acetone or similar residue free liquid to clean surface for primer. Rust-Oleum primer and then after that dries Rust-Oleum cottage white. Can also use a gloss clear if you wish. Sometimes if there is extra paint or lots of rust I will use a 4 1/2 grinder with a wire brush attachment to more quickly clean it up. Edited 13 hours ago by AlexR 1 1 Share this post Link to post Share on other sites
EB-80/8inPA 2,025 #3 Posted 13 hours ago (edited) I had a set of rusty old wheels I picked up a while back that need pressed into service now that I need to re-shoe the B-80. Decided to prep, paint, mount them, and then simply swap out the old ones. Although I do have a wire brush attachment that fits the weed wacker (and it does do some really mean grinding work), I opted to get the set of four sandblasted locally for $40 and forego the mess. I’ll use my lazy susan painting thingy to spin and spray them (once the humidity drops). Many here swear by inserting playing cards around the rim after mounting the tires and before a final spray to leave a nice clean finish unmarred by tools. I will be trying that or some similar masking technique. I hope to need nothing other than a set of tire spoons to mount the rims and will install tubes from the get go. Will post pics once done (could be a while but I do anticipate finishing up before @ebinmaine completes his Colossus project). For paint color, all I can say is: Good luck and have fun! Edited 13 hours ago by EB-80/8inPA 4 Share this post Link to post Share on other sites
Ed Kennell 46,450 #4 Posted 11 hours ago 1 hour ago, EB-80/8inPA said: Many here swear by inserting playing cards around the rim The playng cards work for me. 2 Share this post Link to post Share on other sites
ebinmaine 79,474 #5 Posted 6 hours ago We've tried several methods. Hand sanding starting with 80 grit works well to break out the really rough stuff. After that it's your wire brush of choice or sand flap wheels. Definitely recommend the acetone just before painting. That too removes some rust. Color here is Rust-Oleum 2X Cottage White. 1 2 Share this post Link to post Share on other sites
ri702bill 12,371 #6 Posted 4 hours ago For any really really rusted surfaces - that are thick enough to withstand the process - I highly recommend using a needle scaler. Works great on WH rims and the outer side of truck brake drums. A bonus - it leaves a mildly rough clean surface that cleans up with acetone and provides great adhesion for the primer. Mount the tire after prep but before any painting. Yes, the plastic coated playing cards work great. 1 1 Share this post Link to post Share on other sites
953 nut 67,187 #7 Posted 3 hours ago 1 hour ago, ri702bill said: any really really rusted surfaces - that are thick enough to withstand the process - I highly recommend using a needle scaler. Works great on WH rims A good coat of self etching primer followed by a couple of coats of the color of your choice with ample dry time should be applied prior to mounting the tire, then all is needed will be a touch up. 1 Share this post Link to post Share on other sites
squonk 47,229 #8 Posted 2 hours ago Nothing beats sand/bead blasting providing you're not the guy doin it! 3 3 Share this post Link to post Share on other sites
Lee1977 7,671 #9 Posted 1 hour ago How badley rusted and what model tractor? Share this post Link to post Share on other sites
EB-80/8inPA 2,025 #10 Posted 1 hour ago 1 hour ago, squonk said: Nothing beats sand/bead blasting providing you're not the guy doin it! There was a guy doing some blasting when I picked up my finished wheels. Between the fans and the blasting was that operation ever loud! I think it was $40 well spent. 1 1 Share this post Link to post Share on other sites
EB-80/8inPA 2,025 #11 Posted 1 hour ago 4 hours ago, ebinmaine said: Definitely recommend the acetone just before painting. I assume you use some sort of protective gloves - which do you use? They all seem to start dissolving prematurely for me. Share this post Link to post Share on other sites
sqrlgtr 3,147 #12 Posted 1 hour ago (edited) I always tape mine up, after sanding, blasting or what ever i had to do tyo get them in good enough shape to prime and paint. Edited 1 hour ago by sqrlgtr Share this post Link to post Share on other sites
oliver2-44 11,601 #13 Posted 25 minutes ago 1 hour ago, EB-80/8inPA said: There was a guy doing some blasting when I picked up my finished wheels. Between the fans and the blasting was that operation ever loud! I think it was $40 well spent. That was a steal of a deal Share this post Link to post Share on other sites
