Chrishar
Commando 8
Chrishar
Posted (edited)
Finally had room to get the commando in the shop to work on getting it up and going  I rebuild the transmission and installed it and the rear hitch too thanks to the people the help  me with some gears and bearings so I could get the transmission done I'll looking for a steering wheel if anybody as one thanks
Edited by Chrishar
  • Like 5
  • Excellent 2
ri702bill
Post an ad in the Wanted Section...
Progress looks good so far.
Chrishar
I have one post wanted section for awhile though I would try here too
Retired Wrencher
Chris that is a start. Just take your time with it. Just enjoy working on it one part at a time. You have been here long enuf to know all the advantages of this site.
Chrishar
Commando has new shoes put on today have been working on the motor when I have time to
wallfish
I could use that extended steering wheel for a custom project I have going on. Do you have a pic of the correct steering wheel you want for that tractor? Trade if I have one?
Chrishar
One like this
Chrishar
The engine block is bolted down new ignition switch installed working on rebuilding the generator now and working on the wiring have a month and couple weeks to go to have it finished
Retired Wrencher
On 7/29/2026 at 1:30 PM, Chrishar said:
One like this
Retired Wrencher
Chris this is the one I had.I believe this is period correct.
Chrishar
Starting to look like a engine
Chrishar
Generator is on just need to know what size belt
Chrishar
The wiring is almost done
953 nut
3/8"  X 32"  Cogged Rubber Edge Gates 7315
squonk
Or NAPA 257315
Chrishar
Did some work on the commando today the wiring is done gas tank fuel line installed did some work to the fender pan and mounted the seat on have couple more things to do and should be ready to bring it back to life  as anybody used LED headlight bulbs instead of the 1156 bulbs
