rustyedge1 203 #1 Posted July 1 Solenoid starting to give me issues as it’s original to tractor an you can’t find one like it. Don’t know part number. Has K341 16hp engine. There are so many on line and locally and I really don’t know which to buy. Any advise welcome. I changed the switch as I had a NOS new one that was same part number as old one. Old solenoid gets fire but plunger inside is sticking at times now. If I work the switch I can get it to start. I don’t like the looks of the new ones, but don’t have much choice. 1 Share this post Link to post Share on other sites
ebinmaine 80,757 #2 Posted July 1 I use a Cole Hersee brand. All metal. Can get the part number later. 2 Share this post Link to post Share on other sites
Achto 32,791 #3 Posted July 1 (edited) 21 minutes ago, rustyedge1 said: don’t like the looks of the new ones, but don’t have much choice. Grab a Ford 3 terminal starter solenoid from bout any automotive store. Looks the same as the one you have. https://www.napaonline.com/en/p/ECHST58 https://www.oreillyauto.com/detail/c/standard-ignition/standard-ignition-3-terminal-starter-solenoid/std0/ss571 Edited July 1 by Achto 2 1 Share this post Link to post Share on other sites
rustyedge1 203 #4 Posted July 1 1 hour ago, ebinmaine said:All metal. Can get the part number later. 1 hour ago, ebinmaine said: Can get the part number later. What is part number when you’ve time. Share this post Link to post Share on other sites
rustyedge1 203 #5 Posted July 1 1 hour ago, ebinmaine said: I use a Cole Hersee brand. All metal. Can get the part number later. When you’ve time part number appreciated.. Share this post Link to post Share on other sites
squonk 48,141 #6 Posted July 1 (edited) Go with the Napa ST53. The metal ones are the same inside and the steel can rust. Edited July 1 by squonk 2 Share this post Link to post Share on other sites
ebinmaine 80,757 #7 Posted July 1 6 hours ago, rustyedge1 said: When you’ve time part number appreciated.. Cole hersee 24037bx @squonk certainly has good point on the rusting. That Echlin part is a good replacement as well. I like the Cole Hersee solenoid specifically for the "old look" and our mo-chines are all under cover 99% of the time. Share this post Link to post Share on other sites
rustyedge1 203 #8 Posted July 1 1 hour ago, squonk said: Go with the Napa ST53. The metal ones are the same inside and the steel can rust. 1 hour ago, squonk said: The Napa ST53 says its a 6 volt Share this post Link to post Share on other sites
squonk 48,141 #9 Posted July 1 30 minutes ago, rustyedge1 said: The Napa ST53 says its a 6 volt Meant ST58 1 Share this post Link to post Share on other sites
rustyedge1 203 #10 Posted July 1 Went with the Cole Hersee through Advance Auto home shipping free and was what I thought reasonably priced. Always Rust-Oleum Thanks again all for the input.. Share this post Link to post Share on other sites
rustyedge1 203 #11 Posted July 5 (edited) Problem solved. Thanks for all your help.. 39 and change shipped to my address..The ST58 was 33 and change but would have to pick up at store. May get it as extra.. Edited July 6 by rustyedge1 3 Share this post Link to post Share on other sites
