compston_family@hotmail.c
701 hood question
Hello all,
I have a somewhat worn 701 which I am having fun getting back into shape.
The latest problem to be solved is that at some point the hood was removed without removing the wingnut screw and the tab securing the front of the hood was ripped off and discarded.
So does anyone have a picture of this tab so I can fabricate another one?
Thank you.
Mike
WHX??
Posted (edited)
Hello Mike
Only pics I have hope it helps. Sorry I don't have measurments.  @Achto and @rmaynarddid a 701 and @kpinnc is currently doing one. Any help fellas?
Edited by WHX??
Achto
5 minutes ago, WHX?? said:
Any help fellas?
I can try to remember to get some pic's & measurements when I get home from work.
kpinnc
59 minutes ago, WHX?? said:
Any help fellas?
Mine isn't "factory" by any means, but I had to replace what was there.
Wow! Thanks guys. Mine isn't rusted at all, and all the pictures give me what I need to fabricate the "tab".
I can turn the knob for the 1/4-20 screw to fasten it to the tractor.
Thanks again!
rmaynard
A word about the knurled knobs, especially the one in the front. I have lost at least three of the front knobs from vibrating loose. I solved that problem by placing a lock or star washer under the knob. On the side knobs I use nylon washers to keep from damaging the paint.
WHX??
2nd that Bob. I lost so many i don't run them any more 'cept for special occasions. Usually always within arms length of a philips anyway.
  • Excellent 2
Thank you- I was looking at that, and I wondered if I could cross drill the screw and put in a cotter pin to prevent it from getting away?
WHX??
Excellent idea guy. :thumbs2:
Lane Ranger
I did not make this but my 701 has this nice feature.
The lower hood was strengthened with a metal band then a stainless steel door hinge was welded on with a tab to install the hinge to the frame.
You can remove the two thumbscrews in the gas tank and then lift up the hood with no obstructions.
hcminis
 I have a small piece that will fit the round hoods for that fix.  Send me a message or text 317-491-3106 and can send you the part.
