compston_family@hotmail.c 3 #1 Posted July 1 Hello all, I have a somewhat worn 701 which I am having fun getting back into shape. The latest problem to be solved is that at some point the hood was removed without removing the wingnut screw and the tab securing the front of the hood was ripped off and discarded. So does anyone have a picture of this tab so I can fabricate another one? Thank you. Mike Share this post Link to post Share on other sites
Pullstart 71,233 #2 Posted July 1 Here is what I did to fix that issue on my 502: https://www.wheelhorseforum.com/topic/73794-502-worker-refresh/?tab=comments#comment-714660 Share this post Link to post Share on other sites
WHX?? 58,115 #3 Posted July 1 (edited) Hello Mike Only pics I have hope it helps. Sorry I don't have measurments. @Achto and @rmaynarddid a 701 and @kpinnc is currently doing one. Any help fellas? Edited July 1 by WHX?? 1 Share this post Link to post Share on other sites
Achto 32,688 #4 Posted July 1 5 minutes ago, WHX?? said: Any help fellas? I can try to remember to get some pic's & measurements when I get home from work. Share this post Link to post Share on other sites
rmaynard 17,582 #5 Posted July 1 Take a look at this thread: https://www.wheelhorseforum.com/topic/90128-calling-all-metal-fabricators/ 2 Share this post Link to post Share on other sites
kpinnc 18,960 #6 Posted July 1 59 minutes ago, WHX?? said: Any help fellas? Mine isn't "factory" by any means, but I had to replace what was there. 1 1 Share this post Link to post Share on other sites
compston_family@hotmail.c 3 #7 Posted July 2 Wow! Thanks guys. Mine isn't rusted at all, and all the pictures give me what I need to fabricate the "tab". I can turn the knob for the 1/4-20 screw to fasten it to the tractor. Thanks again! Share this post Link to post Share on other sites
rmaynard 17,582 #8 Posted July 2 47 minutes ago, compston_family@hotmail.c said: I can turn the knob for the 1/4-20 screw to fasten it to the tractor. A word about the knurled knobs, especially the one in the front. I have lost at least three of the front knobs from vibrating loose. I solved that problem by placing a lock or star washer under the knob. On the side knobs I use nylon washers to keep from damaging the paint. 2 Share this post Link to post Share on other sites
WHX?? 58,115 #9 Posted July 2 2nd that Bob. I lost so many i don't run them any more 'cept for special occasions. Usually always within arms length of a philips anyway. 1 2 Share this post Link to post Share on other sites
compston_family@hotmail.c 3 #10 Posted July 3 Thank you- I was looking at that, and I wondered if I could cross drill the screw and put in a cotter pin to prevent it from getting away? 1 Share this post Link to post Share on other sites
Lane Ranger 12,105 #12 Posted July 3 I did not make this but my 701 has this nice feature. The lower hood was strengthened with a metal band then a stainless steel door hinge was welded on with a tab to install the hinge to the frame. You can remove the two thumbscrews in the gas tank and then lift up the hood with no obstructions. 1 Share this post Link to post Share on other sites
hcminis 1,801 #13 Posted July 3 I have a small piece that will fit the round hoods for that fix. Send me a message or text 317-491-3106 and can send you the part. 1 Share this post Link to post Share on other sites
