cafoose
520-HC no compression
cleat
19 hours ago, cafoose said:
What's the best way to get the plastic knobs off the 520 choke and throttle levers?
Claw hammer, just pretend you are pulling a nail.
sqrlgtr
I never had any trouble getting them off but have had to use a little glue to keep them on afterward. :tools-wrench: Others may have a better solution to keeping them on, I hate to use super gliue on anything I think I might have remove again later on.
cafoose
Claw hammer works great :D
  • Haha 1
Handy Don
My go-to for these is a tiny dab of hot glue applied to the tip of the arm.
sqrlgtr
This I will try if, I mean next time, I have to do another.
kpinnc
7 hours ago, cafoose said:
@kpinnc Is this the manifold you used?
No sir. The bend on that one is backwards from what I used. You want the shorter leg on the front and the hoop facing up. Otherwise it will interfere with the PTO engagement.
You'll have to weld whichever end shut that is open and add an adapter closer to the middle to make it the way I did. I used a reducer from the auto parts store and flattened it to an oval on the manifold side.
ineedanother
Posted (edited)
I use an adjustable wrench (crescent-type spanner) rather than a claw and tap it off with a hammer. You can also pry against the wrench rather than the knob if you choose to use a claw hammer.
Edited by ineedanother
cafoose
Posted (edited)
It's alive
:banana-wrench:
Edited by cafoose
  • Excellent 5
c-series don
That thing sounds bad ass! Like it has some big cam drag racing engine in it!!
  • Haha 1
cafoose
Open exhaust and worn plugs. Seems to run lean but when I partially close the choke it evens out. May do a carb rebuild. Don't know if it had ethanol in a previous life.
cafoose
Got the relay today, wired it up and it works great just like it should :D Also wired up the oil pressure switch and the lights pigtail. All that's left is the tach wire in the 9 pin. Would be cool if I could get the tach working. Any ideas? All I need is the exhaust fabricated, Tune up and oil change, install the hood, and the mule and mower deck. :banana-wrench:
cleat
I have hooked a 520 tach to a Kohler K series and it worked just fine .
I just hooked to one of the AC wires at the regulator just like the 520 is wired and it got the correct signal.
Edited by cleat
Handy Don
As long as the stators have the same number of coils (18 in the case of the Onan’s) it’ll work.
cafoose
From Grok AI:
Handy Don
Since tachs are essentially counting revolutions over time intervals, your Vanguard hookup will show 8 pulses per revolution vs the 18 of the Onan.
Unless the WH tach can be recalibrated (unlikely), it’ll read as approximately 44% of the actual speed of the Vanguard.
Speed ==> Reading
@1000 RPM ==> 444
@2000 RPM ==> 888
@3000 RPM ==> ~1,330
@ 3600 RPM ==> ~1,600
cafoose
Or the numbers on the tach itself are changed. I would guess rpm can be verified with a hand held tach?
