cleat 9,223 #51 Posted July 21 19 hours ago, cafoose said: What's the best way to get the plastic knobs off the 520 choke and throttle levers? Claw hammer, just pretend you are pulling a nail. 1 Share this post Link to post Share on other sites
sqrlgtr 3,702 #52 Posted July 21 52 minutes ago, cleat said: Claw hammer, just pretend you are pulling a nail. I never had any trouble getting them off but have had to use a little glue to keep them on afterward. Others may have a better solution to keeping them on, I hate to use super gliue on anything I think I might have remove again later on. 1 Share this post Link to post Share on other sites
cafoose 3,813 #53 Posted July 21 Claw hammer works great 1 Share this post Link to post Share on other sites
Handy Don 17,316 #54 Posted July 22 2 hours ago, sqrlgtr said: I hate to use super gliue on anything I think I might have remove again later on. My go-to for these is a tiny dab of hot glue applied to the tip of the arm. 1 1 Share this post Link to post Share on other sites
sqrlgtr 3,702 #55 Posted July 22 1 minute ago, Handy Don said: My go-to for these is a tiny dab of hot glue applied to the tip of the arm. This I will try if, I mean next time, I have to do another. 1 Share this post Link to post Share on other sites
kpinnc 18,884 #56 Posted July 22 7 hours ago, cafoose said: @kpinnc Is this the manifold you used? No sir. The bend on that one is backwards from what I used. You want the shorter leg on the front and the hoop facing up. Otherwise it will interfere with the PTO engagement. You'll have to weld whichever end shut that is open and add an adapter closer to the middle to make it the way I did. I used a reducer from the auto parts store and flattened it to an oval on the manifold side. 1 Share this post Link to post Share on other sites
ineedanother 2,803 #57 Posted July 23 (edited) On 7/20/2026 at 9:35 PM, cafoose said: What's the best way to get the plastic knobs off the 520 choke and throttle levers? I use an adjustable wrench (crescent-type spanner) rather than a claw and tap it off with a hammer. You can also pry against the wrench rather than the knob if you choose to use a claw hammer. Edited July 23 by ineedanother 1 1 Share this post Link to post Share on other sites
cafoose 3,813 #58 Posted July 25 (edited) It's alive Edited July 25 by cafoose 1 5 Share this post Link to post Share on other sites
c-series don 12,362 #59 Posted July 25 That thing sounds bad ass! Like it has some big cam drag racing engine in it!! 1 Share this post Link to post Share on other sites
cafoose 3,813 #60 Posted July 25 2 hours ago, c-series don said: That thing sounds bad ass! Like it has some big cam drag racing engine in it!! Open exhaust and worn plugs. Seems to run lean but when I partially close the choke it evens out. May do a carb rebuild. Don't know if it had ethanol in a previous life. 1 Share this post Link to post Share on other sites
cafoose 3,813 #61 Posted July 28 Got the relay today, wired it up and it works great just like it should Also wired up the oil pressure switch and the lights pigtail. All that's left is the tach wire in the 9 pin. Would be cool if I could get the tach working. Any ideas? All I need is the exhaust fabricated, Tune up and oil change, install the hood, and the mule and mower deck. 1 1 Share this post Link to post Share on other sites
cleat 9,223 #62 Posted July 28 (edited) 14 hours ago, cafoose said: Got the relay today, wired it up and it works great just like it should Also wired up the oil pressure switch and the lights pigtail. All that's left is the tach wire in the 9 pin. Would be cool if I could get the tach working. Any ideas? All I need is the exhaust fabricated, Tune up and oil change, install the hood, and the mule and mower deck. I have hooked a 520 tach to a Kohler K series and it worked just fine . I just hooked to one of the AC wires at the regulator just like the 520 is wired and it got the correct signal. Edited July 29 by cleat 2 1 Share this post Link to post Share on other sites
Handy Don 17,316 #63 Posted July 29 22 hours ago, cleat said: I have hooked a 520 tach to a Kohler K series and it worked just fine . I just hooked to one of the AC wires at the regulator just like the 520 is wired and it got the correct signal. As long as the stators have the same number of coils (18 in the case of the Onan’s) it’ll work. 1 1 Share this post Link to post Share on other sites
cafoose 3,813 #64 Posted July 29 31 minutes ago, Handy Don said: As long as the stators have the same number of coils (18 in the case of the Onan’s) it’ll work. From Grok AI: Share this post Link to post Share on other sites
Handy Don 17,316 #65 Posted July 31 Since tachs are essentially counting revolutions over time intervals, your Vanguard hookup will show 8 pulses per revolution vs the 18 of the Onan. Unless the WH tach can be recalibrated (unlikely), it’ll read as approximately 44% of the actual speed of the Vanguard. Speed ==> Reading @1000 RPM ==> 444 @2000 RPM ==> 888 @3000 RPM ==> ~1,330 @ 3600 RPM ==> ~1,600 1 Share this post Link to post Share on other sites
cafoose 3,813 #66 Posted August 1 9 hours ago, Handy Don said: Unless the WH tach can be recalibrated Or the numbers on the tach itself are changed. I would guess rpm can be verified with a hand held tach? 1 Share this post Link to post Share on other sites
Handy Don 17,316 #67 Posted August 1 11 hours ago, cafoose said: Or the numbers on the tach itself are changed. I would guess rpm can be verified with a hand held tach? LOL! I’m visualizing pieces of masking tape with numbers on them! Personally, I test revs with a free iPhone app “Video Tachometer” to get within ±10 RPMs of my target. After I’ve got the carb mixtures tweaked, I set my “target” speed in the app and then adjust the throttle linkages/stops until the app shows I’ve hit the target. 1 Share this post Link to post Share on other sites
cafoose 3,813 #68 Posted August 1 2 hours ago, Handy Don said: LOL! I’m visualizing pieces of masking tape with numbers on them! I was thinking of possibly having a new decal made to go on the tach. 2 hours ago, Handy Don said: Personally, I test revs with a free iPhone app “Video Tachometer” to get within ±10 RPMs of my target. Anything out there for android? Share this post Link to post Share on other sites
Handy Don 17,316 #69 Posted August 1 (edited) 51 minutes ago, cafoose said: Anything out there for android? I don’t follow the Android world at all. FWIW, I would search the interweb for apps that use the camera and strobe the light that are compatible with your specific device. Hardware varies so much in the android world, especially for camera specs, your device may not have the needed oomph. There are not-to-expensive external tachs that work via induction (off the spark plug wire) and/or optical that are helpful for doing maintenance and sychronization like this one. Edited August 1 by Handy Don 1 Share this post Link to post Share on other sites
