cafoose
520-HC no compression
sqrlgtr
@cafoose looks right at home on there.
cafoose
@sqrlgtr You may end up with the Onan when it's finished :banana-wrench:
sqrlgtr
:greetings-clappingyellow::greetings-clappingyellow:
cafoose
Got the engine mounted and PTO hooked up. Do ya think the belt is too close to the other belt in the last pic? Thinking I may have to move the engine about an inch front. I have a parts 520 that I used the engine mount plate from and attached it to the Vanguard. Then I bolted the two plates together raising it up a tad. Progress so far.
Edited by cafoose
sqrlgtr
@cafoose first pic is new belt,2nd pic is old belt, 3rd pic is numbers on new belt.
sqrlgtr
Looks too close in pic but pics are deciving sum times,If it were me and your using the 83" belt I would scoot the Briggs forward a little bit more if u can easy enough but you could always go shorter belt????
Edited by sqrlgtr
cafoose
Went front 3/4 inch now it seems right :banana-wrench:
Edited by cafoose
sqrlgtr
Agree....I have used smaller bolts on mounting tabs on block to scootch motor forward a little also if need be..
cafoose
I just removed the engine and drilled new holes 3/4 inch front. Little bit of a pain but I believe it's the best way to go.
  • Excellent 2
Handy Don
You are making terrific progress. Very satisfying, I’m sure.
What are you thinking for re-routing the exhaust?
sqrlgtr
I vote straight pipes... keep the neighbors on their toes :hide:
  • Haha 1
cafoose
Didn't get that far yet, Open to suggestions? @kpinnc @Lee1977?
cafoose
What neighbors? :lol:
Handy Don
Personally not a fan of straights. Too much respect for my hearing.
Mellow stacks are good if you have clearance in use and for parking. Tuning dual cylinders into a single header might be tricky but interesting!
cafoose
Already has 2 into one
sqrlgtr
yeah I'm with ya HD I wouldn't do that to any of mine either. To many trees around my place to have stacks though.:chores-chopwood:
cafoose
My ears ring just from the pepper pot mufflers :angry-screaming:
cafoose
@kpinnc @Lee1977 anybody else know how the throttle cable hooks up on the Vanguard? Where does the ignition wire go from the 520 ignition switch to the Vanguard? The regulator batt terminal goes to batt on the ignition switch correct? Coil kill on Vanguard to coil kill on ignition? I need to hook up the starter relay from the 520 to the Vanguard. Oil pressure switch on Vanguard to where on the 520? Tach on 520 to where on Vanguard? Anybody know the wire colors on the 520 to hook up on the Vanguard?
cafoose
What's the best way to get the plastic knobs off the 520 choke and throttle levers?
Lee1977
I bought my Vanguards with the Briggs & Strattion switch prewired.
Best get electrical information from Kevin.
Both of mine the trottle hoop is the same.
Choke hoop up.
As for removing the plastic choke trottle levers. Go real easy with a claw hammer.
Edited by Lee1977
kpinnc
I have bought manifolds from Ebay and modified them to use a canister muffler. They can be found pretty cheap ($30 or so). Takes a little welding to make it but they work well.
peter lena
@cafoose regularly  suggest   rislone  zinc oil additive ?  repetitive ENGINE VARNISH RELATED ISSUES , like piston ring hang up  valve stem glue debris hang up, that varnish  builds up and cools down like like a coral reef , to anything handy . also like a hi detergent  10-30  flat tappet oil  , like valvoline , V R 1 , operational  running  ease is very apparent . don,t have any  onans , but  stay  in touch with my  tractors  all the time . you were asking for suggestions , this is no instant miracle , but  a thorough , engine oil  drain / flush , and refill , just let it  operate in a comfortable zone , BTW  also use , STA BIL in all my fuels , no fuel hose break downs . if I had an onan , while still at  pfizer  , you can bet  , that  carb manifold would have been  all s/s  welded tubing , eliminating that  repetitive issue . PTO inner needle bearing ?  clean / flush it out , lucas , GREEN CHASSIS GREASE, XTRA HD ,  550  FLASH POINT  . very lightly , polyurea rated , insures easier spin up, also replace the outer sealed bearing , napa . related gold mine  enhancement  areas .     nothing sarcastic , LOVE REPEDITIVE PROBLEMS , eliminate them , pete
cafoose
Any ebay links to the manifold you used? What should I look for? I really like that manifold :D
Lee1977
I made the franges for this one. It's 3/4" steel conduit and 2" tail pipe.  There is nothing in the tail pipe. The end is 1 1/2'  black pipe  with 90 degree bend.
Welded eo it is a 1" washer and two 3/4" washers seperated wieh drilled out 1/4" nuts.
