cafoose
520-HC no compression
cafoose
I was mowing with my 520-HC and I noticed the oil light came on. I promptly added oil to the full mark and it seemed to have lost power and started missing. I checked compression and the front cylinder is 85 and the rear is 0. It still starts and no loud knocking like a broken rod. I did notice wet oil drips underneath but nothing like a vented block. I hear they're expensive and difficult to rebuild. Thinking of a possible repower. 22 HP predator is $950 and 16.8 is $450. Is there really much difference in performance between the two for just running a 48 inch deck? Any other options or suggestions?
  • Sad 2
Sparky
Might just be the valve seat let go. Is it the rear cylinder that’s at 0 psi?
ri702bill
YUP - does it have over 1100 hours on it? That seems to start the countdown clock on them to the issue at hand.
sqrlgtr
@cafoose I would be interested in taking it off your hands if you decide not to pursue the repower. Would like the extra speed for running around the farm  :auto-layrubber::auto-checkeredflag: .
  • Haha 1
cafoose
I like the speed myself and would like to fix it :banana-wrench:
cafoose
Just saw this on marketplace. Will it work in my 520-HC? Description:
Good running horizontal shaft v twin off a cub cadet 2160. It’s got electric start & vacuum fuel pump, it’s ready to go on a mower similar to that or a gokart if you remove the governor. $250 or best offer.
Product photo of 16hp Briggs & Stratton vanguard v twin horizontal
cafoose
From Grok AI:
**The engine was manufactured on September 14, 1994** (based on the code **94091411**).
### Breakdown:
- **94** = Year (1994)
- **09** = Month (September)
- **14** = Day (14th)
- **11** = Plant/assembly line code
### Tractor Context:
The **Cub Cadet 2160 (AGS)** was produced from **1994 to 1997/1999** (depending on exact variant), so this engine is original to that era tractor — roughly **32 years old**.
At that age, these Vanguards are known for longevity **if** they've had decent maintenance. At **$250**, it's still a reasonable price for a complete, running take-off engine, but inspect it carefully for wear (bearings, compression, oil leaks, carb condition).
Ready to pull the trigger? I can walk you through a quick pre-purchase checklist or what to expect when mating it to the 520-HC.
cafoose
Showing 1237 hours.
Sparky
5 hours ago, cafoose said:
Showing 1237 hours.
That 16 twin is a Kohler right? I don’t think that 1100 hours that Bill @ri702bill mentioned applies to that Kohler
cafoose
Showing 1237 hours.
Nope, it's the hours on the original Onan on my 520 The 16 I'm looking at is a Briggs Vanguard
Handy Don
A key difference might be the crankshaft bearings. The Onan on the HC had bearings able to handle the horizontal thrust from the PTO clutch. Cubs don’t work the same way and wouldn’t need that type of bearing so you might need to use an electric clutch for the PTO with the Briggs.
@cafoose, can you tell from the Briggs specs what bearings it had?
cafoose
From Grok AI:
Yes, the Briggs & Stratton Vanguard 303447-0447-01 (16 HP, code 94091411) is a popular candidate for a repower on the Wheel Horse 520-HC.
Why It Fits Well:
  • The 520-HC originally came with an Onan 20 HP twin (or similar). A 16 HP Vanguard is a bit smaller in power but is a common, reliable swap for these tractors. Many owners report successful installs on 520-H / 520-HC models.
  • It's a horizontal-shaft engine with ball bearing PTO side (as we discussed), flange mounting, and pressure lubrication — good match for the tractor's drive system.
  • Physical mounting dimensions are close enough that it bolts up with minor (or no) adapter plate work in many cases. The crankshaft PTO end usually aligns with the existing pulley/clutch setup.
Things to Check / Common Adaptations:
  1. Mounting — Verify bolt pattern and height. Some swaps need a simple adapter plate or shims for perfect alignment.
  2. PTO / Pulley — Ensure the crankshaft diameter and keyway match your mule drive or deck drive pulley. You may need to swap or modify the pulley.
  3. Exhaust / Muffler — Original Onan exhaust may not fit; many use a universal or custom muffler setup.
  4. Wiring / Controls — Electric start, alternator output, and throttle/choke cables usually adapt easily. There are dedicated wiring harness kits for Vanguard conversions on Wheel Horse
WHX??
Scrap price or a big roll of the dice you can't see it run... just sayin.
cafoose
Seller sent me this video
kpinnc
Yes it will, but it will require some light fabrication to raise the PTO shaft about an inch and to mate up to the mount holes on the tractor frame.
I have repowered several tractors with Vanguards ranging from 14hp though 23hp, and they are very good engines. 3 of them are in the pic below.
The modifications are well worth it in my opinion, and the Vanguard engines have plenty of parts still available. Plus they sip fuel and have excellent torque for thier size. A 16hp Vanguard easily handles the hydro and a 48 inch mowing deck.
  • Excellent 2
cafoose
Picked up the vanguard and unhooked a few minor things on the 520. @kpinnc got any build threads on the vanguard swap?
kpinnc
There are several different ways to do it. What I did is in the following two threads:
523-H
Whatchamacallit
I'm sure I have more stuff somewhere. Just look those over and ask any questions.
Don't forget you'll be changing from coil ignition to magneto, so you'll have to swap the ignition switch and wire it all up to whatever level of complexity you are comfortable with. My 523H has an hour meter, volt meter, and oil pressure guage only.
cafoose
First, the Vanguard has a 1 inch crankshaft and the Onan is a 1 1/8 crankshaft. Can I get an adapter to use the Onan PTO setup in the Vanguard? Second, The crankshaft on the Onan is 1 1/2 inches higher than the Vanguard. I need to block up the Vanguard 1 1/2 inches. Can I use 1 1/2 square tubing?
sqrlgtr
Ive never done it but I'm sure I have seen sleeve adapters for the different cranks, and dont see why you culdnt use sqaure tubing to get motor/crank in the raised position.
Handy Don
:text-yeahthat:
Just remember you’re attaching sixteen horsepower with some serious torque! Pay attention to constrain movement in all directions and use strong bolts, strong tubing, and solid welds!
Lee1977
Posted (edited)
I did a rough measure on my 520-H the center line of crank shaft is 7 1/4" above the frame. The Vanguard is 5  1/4" using the existing  1/4"  mounting plate you need to raise it 1 3/4" .to run the same belts.
The crank shaft center should line up with the back side of the PTO loop hole on the mounting plate. You need to check the measurements I did it with the PTO  in place..
Here is the mounting plate  used on my 312-8.
Edited by Lee1977
  • Excellent 3
  • Heart 1
Handy Don
27 minutes ago, Lee1977 said:
...did a rough measure on my 520-H the center line of crank shaft is 7 1/4" above the frame. The Vanguard is 5  1/4" using the existing  1/4"  mounting plate you need to raise it 1 3/4" .to run the same belts.
Is the height difference coming from a shallower oil pan and pumped oil circulation vs. splash for the Kohler?
Lee1977
Single cylinder Kohlers the crank height center of crank is 6 1/4". the Onan is 7 1/4" not sure why.
cafoose
I got 1 1/2 inch difference but I'll double check if I measured right. I found some 3/8 plate steel and 3/4 square tubing at a machine shop today right below Rogersville today. Maybe @sqrlgtr knows the place, Davis Fabrication in Bulls Gap area off Rt 113? They just gave me the metal free since I only needed a few small pieces :D I'm going to try and fit up a riser plate for the vanguard with it. Still need the crank adapter to go from 1 to 1 1/8 for the PTO or a PTO off a K-181 with a 1 inch crank.
cafoose
Posted (edited)
Progress on the repower. Didn't bolt the engine down yet because I need the PTO mounted first. Waiting for the crank adapter ordered today from Carroll Stream Motor Company.
Edited by cafoose
  • Excellent 2
