maine home 0 #1 Posted June 28 (edited) Hi, I'm burning up PTO belts on a GT1600 mower. Could the pulleys by the tighter be worn out? The outside belt keeps jumping to the inside pulley? Would also like to know what the adjustment on back of deck is for? Thank you 20260629_142130.mp4 Edited June 29 by maine home Added pics Share this post Link to post Share on other sites
peter lena 9,984 #2 Posted June 28 @maine home seams like spindle bearing , lubrication failure , incremental , bearing , stop / start 'probably causing belt jump . not familiar with your unit , would bet on combined rotational drag , what model mower do you have , brand ? pete Share this post Link to post Share on other sites
ebinmaine 79,894 #4 Posted June 28 We don't use the mowing deck here but others will be along soon. @MainelyWheelhorse @Blue Chips @midpack Another Mainer here. Share this post Link to post Share on other sites
Bill D 3,024 #5 Posted June 29 Welcome. Any pictures? They are very helpful when diagnosing issues like this. Share this post Link to post Share on other sites
midpack 1,147 #6 Posted June 29 IIRC the adjuster on the back of the deck is to level it. The belt jumping, is that in the mule drive? Check that the pulleys were put on in the right order. I had one that was mixed up before I got it. I also had a rear discharge that I put on so that the blades were turning backwards. I finally put an arrow with magic marker on the deck to clarify which way to put the belt on Share this post Link to post Share on other sites
MainelyWheelhorse 2,969 #7 Posted June 29 (edited) 1 hour ago, maine home said: Hi, I'm burning up PTO belts on a GT1600 mower. Could the pulleys by the tighter be worn out? The outside belt keeps jumping to the inside pulley? Would also like to know what the adjustment on back of deck is for? Thank you @maine home Hi fellow Mainer! What size is the mowing deck? Pictures of your setup should definitely help us figure out what’s wrong. There could be many things that could cause the belt to jump. The smaller 37’ inch deck use one belt from the PTO to the deck. The bigger ones like the 42” inch ones use two. One from the PTO to the front most middle pulley on the deck, and one just on the deck to run the mowing blades. The belt from the PTO to the deck is on the mule drive. If it’s jumping, something could be wrong with the pulleys. If it’s the mule drive it might not be tight enough, or something is off there. There’s a few possibilities. Edited June 29 by MainelyWheelhorse 1 Share this post Link to post Share on other sites
Blue Chips 821 #8 Posted June 29 Welcome, fellow Mainer. All of the above comments are worth considering. Post a picture or two if you can. Make sure the photos show how you're routing the belts. This thread is reminding me that our front lawn is getting deep enough to hide a large groundhog and needs some attention from my mowing deck. 1 3 Share this post Link to post Share on other sites
8ntruck 9,126 #10 Posted June 29 to the forum. Make sure that your pulley bearings and center mower shaft bearings are not sloppy and spin freely. Working from memory here, I think that the pulley spacers on the mule drive shaft are different lengths. If you get them in the wrong place, belt alignment will be a bit off. Sorry, but I don't remember right now which one goes where. Belt tension should be in the neighborhood of having about 1/2" belt flex on each side of the belt halfway between the PTO and mule drive. A remote possibility is that the mule drive shaft might be bent. This would certainly mess with pulley alignment. Good luck. Please, when you find the solution, post it - share the knowledge. 2 Share this post Link to post Share on other sites
maine home 0 #11 Posted June 29 I just edited my post. Added pics. The sparer is spit see pic. I need part number. Share this post Link to post Share on other sites
Handy Don 17,089 #12 Posted June 29 At first glance, it looks like the engine-to-deck belt might be the right length but looks to me to be not the right width (or else it is extremely worn). A properly fitted belt should, when new, ride with the outer surface of the belt being very slightly above the edges of the V pulley. 2 Share this post Link to post Share on other sites
maine home 0 #13 Posted June 30 On 6/28/2026 at 8:38 PM, MainelyWheelhorse said: @maine home Hi fellow Mainer! What size is the mowing deck? Pictures of your setup should definitely help us figure out what’s wrong. There could be many things that could cause the belt to jump. The smaller 37’ inch deck use one belt from the PTO to the deck. The bigger ones like the 42” inch ones use two. One from the PTO to the front most middle pulley on the deck, and one just on the deck to run the mowing blades. The belt from the PTO to the deck is on the mule drive. If it’s jumping, something could be wrong with the pulleys. If it’s the mule drive it might not be tight enough, or something is off there. There’s a few possibilities. It's a new belt but it twisted when it jumped the pulley. Now it has a bad twist in it and will not work. Share this post Link to post Share on other sites
maine home 0 #14 Posted June 30 16 hours ago, 8ntruck said: to the forum. Make sure that your pulley bearings and center mower shaft bearings are not sloppy and spin freely. Working from memory here, I think that the pulley spacers on the mule drive shaft are different lengths. If you get them in the wrong place, belt alignment will be a bit off. Sorry, but I don't remember right now which one goes where. Belt tension should be in the neighborhood of having about 1/2" belt flex on each side of the belt halfway between the PTO and mule drive. A remote possibility is that the mule drive shaft might be bent. This would certainly mess with pulley alignment. Good luck. Please, when you find the solution, post it - share the knowledge. Check my pictures. The third spacer broke the weld spitted (see pic). That looks like the problem is? Share this post Link to post Share on other sites
maine home 0 #15 Posted June 30 On 6/28/2026 at 8:38 PM, MainelyWheelhorse said: @maine home Hi fellow Mainer! What size is the mowing deck? Pictures of your setup should definitely help us figure out what’s wrong. There could be many things that could cause the belt to jump. The smaller 37’ inch deck use one belt from the PTO to the deck. The bigger ones like the 42” inch ones use two. One from the PTO to the front most middle pulley on the deck, and one just on the deck to run the mowing blades. The belt from the PTO to the deck is on the mule drive. If it’s jumping, something could be wrong with the pulleys. If it’s the mule drive it might not be tight enough, or something is off there. There’s a few possibilities. 36? Share this post Link to post Share on other sites
peter lena 9,984 #16 Posted June 30 @maine home those belts are showing you the way , looks like total collective drag failure , have any help on this ? like someone that owns a similar set up ? would also bet the mule drive bearings , and pto spindle needle bearing is dry , hanging up , thats typically the engine heat , destroying lubrication , minimising belt driven spin up , actually not a bad job , done a few , my experience , is to change out all related lubrication in every bearing , lucas x tra hd , green chassis grease ? 550 deg flash point , polyurea rated , to stay with bearings , done this on 3 decks , never failed again , or make noise . you do not know what the bearing lube is , original fill is based on cheap , dollar saving stage of assembly, they will work , but will soon be whyining with noise. why not eliminate that stage ? only my experience on related failures , experienced helper , will really , save it , pete 1 Share this post Link to post Share on other sites
peter lena 9,984 #17 Posted June 30 @maine home never look at a rotational anything , as a single area , fix / repair , to me thats a glairing mind set . that deck pulley with imploded bearing , would have gotten after that , from the start , can imagine the related , pto lever set up , did this years ago , basic functional improvement , at every stage , makes this set up work , as it should , pete Share this post Link to post Share on other sites
