Adam F 8 #1 Posted June 23 Hi, my family has a collection of wheel horse tractors. I am new to the forum and this is my first time posting. I am a third generation wheel horse fan. My son has just recently started lawn and garden tractor pulling riding someone else’s tractor. I would like to build a tractor for him. He has pick out our 1996 312-8. Can you tell me if this is a good tractor to build off of. I have been told it might not be the best. Any help would be greatly appreciated. Thank you! 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,295 #2 Posted June 23 I think it’s all dependent on which transmission your 312 has. The frames and steeeing is generally all the same. If the trans has 1-1/8” axles then it’s the most stout of the 8 speeds and that’s the one the pullers want. 3 1 Share this post Link to post Share on other sites
ebinmaine 80,599 #3 Posted June 23 7 hours ago, Adam F said: been told it might not be the best. 26 minutes ago, Sparky said: which transmission I can see that logic. Adam, can you find out from the person who told you that, exactly why? Share this post Link to post Share on other sites
ebinmaine 80,599 #4 Posted June 23 @Sparky Internet search shows the smaller axles were only used up to 1993 but I can't verify the source Share this post Link to post Share on other sites
Achto 32,621 #5 Posted June 23 (edited) The 8 speed with 1 1/8" axles and a 8 pinion differential is the strongest transmission. I do know guys that are using the 8 speed w/ 1" axles that have not had any issues running a stock engine. The tranny in my puller is a 6 speed w/ 1 1/8" axles. It use to have a 10 pinion diff but I made tranny gravel out of that. I have since retro fit an 8 pinion diff into it. The 8 pinion has been holding up well with my stock-ish 14hp engine. Edited June 23 by Achto 1 5 Share this post Link to post Share on other sites
Adam F 8 #6 Posted June 23 Perfect! Thank you for the information. I will look for a serial # to see what I have. I’m sure I will have plenty more questions as the build moves forward. 4 Share this post Link to post Share on other sites
WHX?? 58,048 #7 Posted June 23 Doesn't @jeremi3210 boy pulls with a 312? 1 Share this post Link to post Share on other sites
jeremi3210 752 #8 Posted June 23 9 hours ago, WHX?? said: Doesn't @jeremi3210 boy pulls with a 312? Yes he does, never had any problems with it. 1 Share this post Link to post Share on other sites
TonyToro 1,190 #9 Posted June 24 @Adam F welcome to the group and the pulling world. We have been pulling wheel horses for 9 years now. What type of sled you are using transfer sled or stone boat? What class are you going to pull in? Are you going to keep the stock 12hp engine? Share this post Link to post Share on other sites
Adam F 8 #10 Posted June 25 Yes we are going to keep the stock 12 hp for now. We will be pulling a transfer sled. We were going to run jr stock to start. 1 Share this post Link to post Share on other sites
Adam F 8 #11 Posted June 28 I have another question. Can I use the same times that came on the tractor. Where can I find pulling tires that will fit the stock rim? 1 Share this post Link to post Share on other sites
TonyToro 1,190 #12 Posted June 28 3 hours ago, Adam F said: I have another question. Can I use the same times that came on the tractor. Where can I find pulling tires that will fit the stock rim? The 12hp will work perfect in the stock class. As the years go on there are things that can be done to get more power from it. Best to check what your rules say for that class but what we found work best is a 23-10.5-12 tire with lower air pressure depending on track conditions. The old Kenda turf tire if you have to run turf or now Cheng shin makes a great AG tire. If rules allow you to cut tires those give amazing grip. We just did a set. They work great. I’ll have to search and find the tire site we have been buying from. They have discount and coupons time to time. This sport gets expensive quickly so saving dollars helps. lol Share this post Link to post Share on other sites
Adam F 8 #13 Posted 12 hours ago Can anyone tell me where the best place is to get parts to further build our pulling tractor. I would like to try and get a throttle pedal and some other various parts for the tractor. 1 Share this post Link to post Share on other sites
953 nut 69,116 #14 Posted 3 hours ago If you do an introduction and post your question it will get a lot more attention. https://www.wheelhorseforum.com/forum/47-introductions/ Also our puller section has lots of good posts with answers to your question. Reading over the old posts should be helpful. https://www.wheelhorseforum.com/forum/48-pullers/ Share this post Link to post Share on other sites
TonyToro 1,190 #15 Posted 2 hours ago 10 hours ago, Adam F said: Can anyone tell me where the best place is to get parts to further build our pulling tractor. I would like to try and get a throttle pedal and some other various parts for the tractor. You can message me and I can give you links to where and what to get. We have a fleet of pulling tractors. hitch…D&D is the best option foot pedal can be bought from Midwest or right on Amazon any other tips and tricks ask away. 1 Share this post Link to post Share on other sites
