Adam F
Building pulling tractor
Adam F
Hi, my family has a collection of wheel horse tractors. I am new to the forum and this is my first time posting. I am a third generation wheel horse fan. My son has just recently started lawn and garden tractor pulling riding someone else’s tractor. I would like to build a tractor for him. He has pick out our 1996 312-8. Can you tell me if this is a good tractor to build off of. I have been told it might not be the best. Any help would be greatly appreciated. Thank you!
Sparky
  I think it’s all dependent on which transmission your 312 has. The frames and steeeing is generally all the same.
  If the trans has 1-1/8” axles then it’s the most stout of the 8 speeds and that’s the one the pullers want.
ebinmaine
:text-welcomeconfetti:
26 minutes ago, Sparky said:
which transmission
I can see that logic. Adam, can you find out from the person who told you that, exactly why?
ebinmaine
@Sparky
Internet search shows the smaller axles were only used up to 1993 but I can't verify the source
Achto
Posted (edited)
:WRS:
The 8 speed with 1 1/8" axles and a 8 pinion differential is the strongest transmission. I do know guys that are using the 8 speed w/ 1" axles that have not had any issues running a stock engine.
The tranny in my puller is a 6 speed w/ 1 1/8" axles. It use to have a 10 pinion diff but I made tranny gravel out of that.:( I have since retro fit an 8 pinion diff into it. The 8 pinion has been holding up well with my stock-ish 14hp engine.
IMG_20240406_144648008_HDR.jpg.169ba92e3ad12963e5b3f8206c21768a.jpgIMG_20240406_144259510_HDR.jpg.fb3d174277695981cd842fa98ac180d6.jpg
Edited by Achto
  • Excellent 4
Adam F
Perfect! Thank you for the information. I will look for a serial # to see what I have. I’m sure I will
have plenty more questions as the build moves forward.
  • Like 4
WHX??
:WRS:
Doesn't @jeremi3210 boy pulls with a 312?
jeremi3210
9 hours ago, WHX?? said:
:WRS:
Yes he does, never had any problems with it.
TonyToro
@Adam F welcome to the group and the pulling world. We have been pulling wheel horses for 9 years now. What type of sled you are using transfer sled or stone boat? What class are you going to pull in?
Are you going to keep the stock 12hp engine?
Adam F
Yes we are going to keep the stock 12 hp for now. We will be pulling a transfer sled. We were going to run jr stock to start.
Adam F
I have another question. Can I use the same times that came on the tractor. Where can I find pulling tires that will fit the stock rim?
TonyToro
The 12hp will work perfect in the stock class. As the years go on there are things that can be done to get more power from it. Best to check what your rules say for that class but what we found work best is a 23-10.5-12 tire with lower air pressure depending on track conditions. The old Kenda turf tire if you have to run turf or now Cheng shin makes a great AG tire. If rules allow you to cut tires those give amazing grip. We just did a set. They work great.
I’ll have to search and find the tire site we have been buying from. They have discount and coupons time to time. This sport gets expensive quickly so saving dollars helps. lol
