1968Commando 172 #1 Posted 4 hours ago Has anybody ever made a homemade snow plow? I got a welder that’s no big deal, I would be plowing a concrete driveway so want to avoid tearing that up. Share this post Link to post Share on other sites
Ed Kennell 46,283 #2 Posted 3 hours ago Snow plows are cheap $100-$200. Probably cost more than that for iron and weld wire to make one. 3 Share this post Link to post Share on other sites
pfrederi 20,720 #3 Posted 2 hours ago You can probably pick up a plow with a worn edge cheaper than making something that may or not fit/operate correctly. Put a piece of plastic on it like the one in the picture ..no scratches on your driveway 3 Share this post Link to post Share on other sites
OoPEZoO 597 #4 Posted 2 hours ago (edited) I agree with Ed. I love fabricating stuff and seeing other people’s creations and homemade solutions. I also use my tractors for plowing. There is no way I would ever consider trying to make a plow. They are “cheap” and typically readily available. I mean, maybe adapting a different plow blade to fit a wheelhorse plow frame would make sense in certain situations, but the main plow frame? Forget about it, just buy one @pfrederi, how often do you have to change out that plastic edge? I just got my driveway repaved last week and it’s time to replace my plow edge. Curious what you use and how well they hold up? Edited 2 hours ago by OoPEZoO 1 Share this post Link to post Share on other sites
pfrederi 20,720 #5 Posted 2 hours ago I had one a 42" blade for several years in float mode.The one pictured is on a 48" blade that has been used for 4 years but now I use down pressure it is wearing some. Now I use it mostly to plow the section of driveway that is pavers the rest is gravel so only about 75'. Price has gone way up since I bought the 48' piece and that was more than the original 42" Share this post Link to post Share on other sites
squonk 46,981 #6 Posted 1 hour ago I use a split section of 3" PCV pipe. 3 1 Share this post Link to post Share on other sites
ri702bill 12,284 #7 Posted just now Too bad you can't invert it for a second go when it wears thru... Good inexpensive, readily available choice of off the shelf material, if I must say so.. Share this post Link to post Share on other sites
