Goldnboy
C 161 fuel line route.
Goldnboy
Can someone post a picture of the fuel line route from the tank to the front of engine?
It currently is routed under the the left fender and between the side cover and frame on left.
ineedanother
@Goldnboy Hydro or 8-speed?
Goldnboy
Posted (edited)
Its a Hydro.   My GT 1848 Eaton though went under the pump on the right. Is this similar on a sunstrand?
Other posts on this subject are over 15 yrs old and the pictures are not showing.
Edited by Goldnboy
Retired Wrencher
I would assume it would go from the seat pan area. Then through there if shifter area to the engine. I had models like yours. That’s pretty much how they were routed if your gas tank is underneath the seat pan.
peter lena
@Goldnboy  perfect spot for a  steel brake line ?  tubing bender to  enhance upper  frame corner  fit , fitting , opportunity ?  eliminate most of the  rubber hose break down ,  rubber hose tank start  and carb with clear  fuel rated hose , filter  / check valve  . did this years ago , stopped  fuel  hose issue ,  also  add  sta bil  to all my fuels , 1 -2 oz to every tank top off . clear  start and stop hose , lets you see , what's going on , always clean / clear  fuel  going to my carb . did a complete  fuel run clean out , tank / carb , to verify effect ?  guess what ?  the repetitive problem  , never came back . have this on my 3 horses , imagine eliminating a  chronic issue ? pete
Bill D
I route all my fuel lines down the left side.  My two 416H's have the lines routed like this.  Easier routing and it keeps it from interfering with the hydro pedal linkage.
