pfrederi 20,956 #1 Posted June 18 (edited) My friends badly worn RM 366 deck on his 856 is eating drive belts for the deck. One issue is the idler pulley sits at an angle because the hole in the end of the idler arm is wallowed out. (part# 6636 item 47) I had an extra but it is worn also. Any ideas on how to fix it. There is so little metal around the hole I don't think drilling it bigger and putting in a sleeve will help. Edited June 18 by pfrederi Share this post Link to post Share on other sites
kpinnc 18,778 #2 Posted June 18 (edited) TSC has sleeve adapters for 3 point systems ranging from CAT 0-3, in thin and thick wall sizes. Also, you can search Amazon for 3/4 ID steel bushings, but both options require cut and re- welding to repair. Just a thought. I use those steel bushings all the time and have had good luck with both sources. Edited June 18 by kpinnc 2 Share this post Link to post Share on other sites
squonk 47,510 #3 Posted June 18 (edited) I don't see # 70. Are you talking about # 47? Edited June 18 by squonk Share this post Link to post Share on other sites
pfrederi 20,956 #4 Posted June 18 51 minutes ago, squonk said: I don't see # 70. Are you talking about # 47? Sorry I was looking a couple of parts diagrams you are correct it is 47 Share this post Link to post Share on other sites
ri702bill 12,594 #5 Posted June 18 Is the stub shaft on part # 57 worn too?? If so, perhaps a Speedy-Sleeve shaft repair can be done!! 1 1 Share this post Link to post Share on other sites
Handy Don 17,072 #6 Posted June 18 3 hours ago, pfrederi said: My friends badly worn RM 366 deck on his 856 is eating drive belts for the deck. One issue is the idler pulley sits at an angle because the hole in the end of the idler arm is wallowed out. (part# 6636 item 47) Frankly, I hear your pain. I’ve about had it with machines that wear out hard to replace parts after a measly 60 years or so! What is this world coming too? I”m actually looking at the same issue and at last year’s Big Show I bought an extra mid hitch for the 854 with a less worn idler pivot/arm. 1 Share this post Link to post Share on other sites
gt14rider 1,273 #7 Posted June 19 @pfrederi made a jig for part #47, then made my own. Put brass bushing in 1 1 Share this post Link to post Share on other sites
gt14rider 1,273 #8 Posted June 19 Here i repaired the mid mount pivot point 3 5 Share this post Link to post Share on other sites
squonk 47,510 #9 Posted 11 hours ago (edited) I was having a similar issue. Found a thin wall bushing that fit the pin nicely. Bored out the arm to 9/16" and it's a nice tight fit. A dab of moly grease and back together. It's on back ward in the photo. Edited 11 hours ago by squonk 1 Share this post Link to post Share on other sites
pfrederi 20,956 #10 Posted 10 hours ago Where did you find the bushing?? Share this post Link to post Share on other sites
squonk 47,510 #11 Posted 10 hours ago 12 minutes ago, pfrederi said: Where did you find the bushing?? In one of my drawers! I think I got it at our local farm supply a few years back. McMaster has steel ones that I saw. I'm going back to the farm store to see if I can get another one for my 857 Share this post Link to post Share on other sites
wallfish 20,284 #12 Posted 6 hours ago 4 hours ago, pfrederi said: Where did you find the bushing?? Try looking here. ASB bearings https://asbbearings.com/ Share this post Link to post Share on other sites
