8ntruck 9,075 #1 Posted June 15 (edited) Had the lake house septic tank pumped today as a precaution for the upcoming guests in the next monts. While the septic guy was here, we dug up the hatch over the exit pipe and discovered that the exit pipe was clogged with roots. That 'splains the overflow we had last year from the septic tank. The tank empties into a large drywell. I suspect that if we open that exit pipe, we will also have to replace the drywell with a drain field to meet current code. $$$$$ and lots of negotiation to get a drain field located so it will be in code to the 3 wells in the immediate area. Does anybody have any advice about removing roots from PVC pipe without replacing it? I'm thinking that this job is a better fit for a plumber who is more experienced with a drain auger than I am. Edited June 16 by 8ntruck Share this post Link to post Share on other sites
ri702bill 12,535 #3 Posted June 15 Are there cleanouts for that pipe both inside and outside the house?? I ask because if there are, it makes narrowing down the location of the of the root clog easier..... Share this post Link to post Share on other sites
SylvanLakeWH 31,808 #4 Posted June 15 Professional drain guys can deal with roots in pvc... the small homeowner cable drain routers like I have won't touch them... I do mine twice a year to keep ahead of the roots. Every 4-5 years I have it done professionally and there is no comparison... I have 4' crock sections so the roots love those joints... 1 Share this post Link to post Share on other sites
squonk 47,448 #5 Posted June 15 Most of those guys will have a spring loaded razor sharp expandable bit that will conform to the pcv walls and slice the roots out. May enlarge the pipe a few thou! 1 1 Share this post Link to post Share on other sites
953 nut 67,524 #6 Posted June 15 (edited) Had that problem with a previous drain field. If you attach a 2" PVC pipe to the tank outlet pipe you can use this to add a couple of pounds of Copper Sulfate to kill the roots. I did this once a month for a year and then went to once every other month for a year. Everything was flowing well and I continued to do this once every three months. Edited June 16 by 953 nut 2 Share this post Link to post Share on other sites
My_horse 122 #7 Posted June 16 I want to start doing this. I’d like to dump it right in the exit pipe. I have a filter on the exit pipe, so I could pull the filter, then make a piece of smaller pvc with an elbow to fit in the exit pipe to funnel it in there. 1 Share this post Link to post Share on other sites
