Cee245 853 #1 Posted 6 hours ago My 314h won't shut down with the key switch. I've checked the wiring and there is no noticeable damage. I know of the dark blue wire from switch to regulator... I am not good with electrical, but i usually get it eventually. Before I look too far... Would a switch from a 97 416h (onan)work on this 93 314h (kohler) I was hoping to test if the switch on the 314 is bad. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,271 #2 Posted 3 hours ago No. 416-8 uses battery ignition switch 103990 314-H uses magneto ignition switch 116338 The switch function can be checked. Click on the switch. 2 Share this post Link to post Share on other sites
953 nut 66,521 #3 Posted 1 hour ago Check to be sure the key switch on the 314H has a good ground. The switch is seeking a ground in the off position to stop the magneto from producing ignition spark. Share this post Link to post Share on other sites
