FarmallFarmer09 23 #1 Posted May 26 (edited) Just wrapped up the restoration on my 71 charger 12, with a kohler k301, but theres still a few adjustments that need done. I pulled the throttle lever and line off when redoing the engine, didn't rebuild or replace anything just took stuff apart to paint it. Before restoration, The throttle lever would work fine, all the way up on the throttle equals top throttle things like that. Well when i put it back together, It now is super touchy, like full throttle is now only half way up on the lever and now i only have idle and full throttle no in-between. Ive adjusted everything with the linkages and even bought a new spring and everything and it still doesn't work like it used to. What should i do? Edited May 26 by FarmallFarmer09 Extra info Share this post Link to post Share on other sites
WHX?? 57,022 #2 Posted May 26 Move the spring on the governor arm to the third hole up from the bottom that's where mine like to be. Guessing you set the governor to the manual? 2 Share this post Link to post Share on other sites
pfrederi 20,741 #3 Posted May 26 3rd hole from the bottom. Make sure the clamp on the throttle cable on the valve cover is tight. 2 Share this post Link to post Share on other sites
pfrederi 20,741 #4 Posted May 26 8 minutes ago, WHX?? said: Move the spring on the governor arm to the third hole up from the bottom that's where mine like to be. Guessing you set the governor to the manual? @WHX?? Your high speed stop looks like 10,000 rpm 5 Share this post Link to post Share on other sites
FarmallFarmer09 23 #5 Posted May 26 26 minutes ago, WHX?? said: Move the spring on the governor arm to the third hole up from the bottom that's where mine like to be. Guessing you set the governor to the manual? Yes right to manual Share this post Link to post Share on other sites
FarmallFarmer09 23 #6 Posted May 26 Everything is tight and it still doesnt work. Share this post Link to post Share on other sites
ebinmaine 79,266 #7 Posted May 26 Here's a video I made several years ago. Share this post Link to post Share on other sites
pfrederi 20,741 #8 Posted May 26 Do you have a picture of the bell crank Share this post Link to post Share on other sites
peter lena 9,910 #10 Posted May 27 @FarmallFarmer09 regularly refer to choke and throttle cables sounding like a hack saw blade on a bolt have also added , medium pull hook end extension springs to all 3 of my horse set ups , very easy to lubricate cabling with penetrant , till it runs out the end , starting at highest point , also use kroil , easy to add on a piece of perforated steel , close to spring pull area . eliminated that issue years ago . paint it red or black , it disappears . local bone yards have piles of that trim , metal . pete Share this post Link to post Share on other sites
FarmallFarmer09 23 #11 Posted yesterday at 01:24 PM On 5/26/2026 at 6:01 PM, pfrederi said: Do you have a picture of the bell crank Share this post Link to post Share on other sites
pfrederi 20,741 #12 Posted yesterday at 01:38 PM Is the governor arm ever contacting the control cable? Share this post Link to post Share on other sites
ebinmaine 79,266 #13 Posted yesterday at 02:42 PM 1 hour ago, pfrederi said: Is the governor arm ever contacting the control cable? Looks awful close to the exhaust pipe too Share this post Link to post Share on other sites
kpinnc 18,601 #14 Posted 21 hours ago On 5/26/2026 at 3:20 PM, WHX?? said: Move the spring on the governor arm to the third hole up from the bottom that's 1 Share this post Link to post Share on other sites
FarmallFarmer09 23 #15 Posted 6 hours ago 23 hours ago, ebinmaine said: Looks awful close to the exhaust pipe too Yes it makes contact to the governer and the exaust pipe 1 Share this post Link to post Share on other sites
FarmallFarmer09 23 #16 Posted 6 hours ago 15 hours ago, kpinnc said: Thats what i did, but it didnt work either Share this post Link to post Share on other sites
ebinmaine 79,266 #17 Posted 4 hours ago 1 hour ago, FarmallFarmer09 said: Yes it makes contact to the governer and the exaust pipe Both of those are a serious problem. My experience shows me that the very first thing you need to do is get a proper throttle cable on there. The exhaust will melt the cable casing and make it so the interior will hardly move through the exterior. Also, the cable being against the governor arm is preventing proper motion of that whole system. Share this post Link to post Share on other sites
pfrederi 20,741 #18 Posted 2 hours ago Contact with the governor arm is a big problem.... Go under the lowest cooling fin stay behind the governor arm make sure it doesn't contact at any point in its motion 1 Share this post Link to post Share on other sites
FarmallFarmer09 23 #19 Posted 2 hours ago 2 hours ago, ebinmaine said: Both of those are a serious problem. My experience shows me that the very first thing you need to do is get a proper throttle cable on there. The exhaust will melt the cable casing and make it so the interior will hardly move through the exterior. Also, the cable being against the governor arm is preventing proper motion of that whole system. So i need a new cable on it Share this post Link to post Share on other sites
pfrederi 20,741 #20 Posted 2 hours ago 15 minutes ago, FarmallFarmer09 said: So i need a new cable on it If the cable still moves freely I suppose you could keep using it but REROUTE it 2 Share this post Link to post Share on other sites
peter lena 9,910 #21 Posted 14 minutes ago @pfrederi agree on the reroute , basically try , spray , try a spring pull assist , to close ? that enhances any pull start assist . also have and use prorated stainless trim tabs for a spring pull assist point .to close . every time you move the cable start point , there is smooth pull against to pull it back to stop . all my cabling slides with ease . front of engine , fan shroud 2 holes close to cable lever swing point ? short medium pull extension spring , lubricate all involved . insuring swing / movement ease ? hiding in plane site ? pull to close / start . have spring pull assist on all my stuff , experiment , pete Share this post Link to post Share on other sites
