AHS 1,701 #1 Posted May 25 History of the machine; 11/25 i got it from up North, from the original owner. It hadn’t ran in 6 years, so i cleaned all the mouse nests out, (it was full of mouse nests!) , started it. It runs 100%. It’s got 464 hrs on it! The only issue with it, was the starter (so i thought!). I would go to start it up and the starter would engage but the motor wouldn’t turn, and then i would turn the key off and to start for a little bit until it got over that stroke and then it would start just fine! I figured the starter had mouse crap all in it, so i replaced it yesterday. It’s been thru 3 starters!?!? United technologies automotive was the starter i took out it, (it doesn’t look like a kohler brand starter). So, the new starter does the exact same thing! Now hears what i think! The original owner must have had stating issues with it at some point, so he replaced the starter. It must be the solenoid, the +/- system, the key switch or the compression release of the motor? Im stumped! Has anybody had this issue? My next thing has got to be replaced the solenoid and check for cracked wires? Share this post Link to post Share on other sites
ebinmaine 80,695 #2 Posted May 25 2 minutes ago, AHS said: I would go to start it up and the starter would engage but the motor wouldn’t turn, and then i would turn the key off and to start for a little bit until it got over that stroke and then it would start just fine Are indicating that you're "bumping" the starter to get the engine past a certain point? If so, I'd look at the timing (if adjustable) or maybe a valve adjustment? 1 Share this post Link to post Share on other sites
Gasaholic 390 #3 Posted May 25 1. I'd start off with a voltage drop test to identify potential bad grounds, and then I'd check compression for being in spec (compression release failure) and likely discover the issue somewhere between those 2 tests. 2 3 Share this post Link to post Share on other sites
953 nut 69,293 #4 Posted May 25 Lots of replacement parts are purchased and installed that weren't needed because no one bothered to diagnose the actual problem. You need to take a systematic approach to find the actual problem. Why won’t my starter turn over from the key switch?\ Lets take a logical step by step inspection of your starter problem. Is your PTO in the ON position, a wheel horse will not start with the PTO on. Have you had the battery load tested at an auto parts store? Have you cleaned and tightened all electrical connections including grounds? Are all fuses good and fuse holders cleaned? If these have all been done, we can check components of the starting system as follows; don’t skip a step or you may miss the problem. Be sure the transmission is in neutral and the parking brake is set. Take a pair of automotive jumper cables and connect the black cable to your battery "-" and a good clean spot on the engine. Now connect the other cable to the large post on the starter and touch the other end to the battery "+" terminal, does the starter turn over? If the starter turns over the battery and starter are good. If it didn't turn over try the same steps with the battery in your car/truck, if that cures the problem then the "good" battery wasn't so good. Presuming the starter turned over move the jumper wire from the starter post to the other end of the wire going to the starter which is one of the large posts on the solenoid. If the starter turns over when the battery is touched by the jumper as before then that cable is good, if not you have found your problem. Presuming the starter turned over move that jumper to the other terminal of the solenoid, connect the other end to the battery and use a small piece of wire to temporarily connect the battery "+" terminal to the small terminal on the solenoid, this should cause the solenoid to close and the starter to turn over. If not, the solenoid is probably the problem. If this was successful remove the large jumper cable and use the small jumper wire to the small terminal of the solenoid, the solenoid should close and the starter turn over. If not the cable to the battery is the problem. Presuming all of these have been successful remove the black jumper wire and repeat the small jumper to small terminal, if the starter turns over the ground is good. If all of these components test good then remove your ignition switch, be sure the transmission is in neutral, parking brake on, clutch depressed and PTO off. Use a small jumper to connect the terminals that were connected to the “B” and “S” terminals of the ignition switch. If the starter turns over then the PTO switch and other safety switches are operating properly and your ignition switch may be bad. 1 3 Share this post Link to post Share on other sites
squonk 48,119 #5 Posted May 25 Clean the starter mounting pads on the starter and where it bolts on the engine. Check and clean the ground cable. 2 Share this post Link to post Share on other sites
AHS 1,701 #6 Posted May 25 1 hour ago, squonk said: Clean the starter mounting pads on the starter and where it bolts on the engine. Check and clean the ground cable. Ok! I was sure the starter was the problem. Cleaning the connections and fuses. Like @ebinmaine answered, valve adjustment. Could the valves be to tight? That would make it hard. Share this post Link to post Share on other sites
Gasaholic 390 #7 Posted May 26 20 hours ago, AHS said: Like @ebinmaine answered, valve adjustment. Could the valves be to tight? That would make it hard. Nah too much clearance can defeat the compression release mechanism , not very common to have excess clearance in an L-Head normally (and I think command has hydraulic lifters? or no?) But too little clearance would cause low compression and backfiring, running issues, etc. However, worn out or broken compression release (on the camshaft) can cause hard starts due to high compression - so compression gauge is the tool to test with - Which is why I said a voltage drop test would help to locate where the issue is - cleaning contacts where starter mounts to engine is one good step but you can have ground problems within the cables themselves (corroded where wires crimp to terminals, for example) that simply cleaning connections won't help. I'm sure there's voltage drop test procedures in these forums somewhere , all it takes is a simple DMM and knowing where to put the probes for a step by step test - the overall picture is first seen by connecting + test led to battery ground post and the - lead to tractor frame bare ground and if you see a voltage reading *while cranking* then you have a voltage drop somewhere in the grounds - so simply moving the - test probe to different places (starting with the ground cable to frame or engine mount is easiest to get to usually) until you get a 0 volts reading which is where you know you DONT have a drop.. then just test between any 2 ground points until you isolate the bad ground. Its easy and quick , just need to understand where to put the test leads and what your voltage readings should be. the hardest part of the whole test is figuring out how to hold 2 leads to test points and a third hand free to turn the key switch! Share this post Link to post Share on other sites
