Ed Kennell
I Saved One
Ed Kennell
I burned some trash in the burn barrel yesterday same as I've been doing for 60 years.  I came in, ate dinner and looked out about an hour later and saw smoke coming from around the shed door.  I ran out and cracked the door to see black smoke and intense heat.    Closed the door and ran to the other barn to turn on the hose.  Lucky I had the hose nearby to water the garden.
I cracked the door and the flames erupted in the front corner.   It took about 30 minutes to get things cooled down enough that I could go inside and concentrate the water on the hot spots.  This is a 30 yo T-111 shed that I covered with metal several years ago.   So I had heat between the metal and wood that I was finally able to get the water on.    Sure could have used you Don O.
Mrs. K wanted to call the local Fire Co.  but, I assured her I Got This.
I'm guessing a spark from the burn barrel found it's way under the metal and lit it up.IMG_20260519_065752856.jpg.a7d6d975e1bd39de8ccfa9bedcdafcbc.jpg
I had some vinyl siding stored overhead that all melted and covered everything.  Shelves full of plant bedding trays, rope, buckets, everything plastic melted.
IMG_20260519_065630902_BURST000_COVER_-_Copy.jpg.1f7101b91069fceb84a7e6109380f150.jpgIMG_20260519_113553994_BURST000_COVER.jpg.dc2bb2864f82981394eed006d1cc21b4.jpg
Three square foot holes were burnt thru the floor and the corner wall where the fire started.     Repaired the holes today.
IMG_20260519_113530439_BURST001.jpg.0b6bc39ddeb62c49fbbfa12fbcb65871.jpgIMG_20260519_113540199.jpg.80788d88b5c59a44496c23e635895b6f.jpg
The lawn sweeper is really all that was lost.   It was right over the floor hole.
The log splitter and crab pots and traps were in the rear corner and were not damaged.
Some of the plastic duct on the Trac Vac melted and the paint on the 310 was damaged.  It may buff out with a buffing compound.
This can of starter fluid was sitting here on the Trac Vac Briggs.   Note the melted cap.    Me thinks I was seconds away from a total burn down.   The burn barrel has been relocated.
  • Like 5
  • Sad 12
  • Heart 1
ebinmaine
Good save Ed!
MainelyWheelhorse
Looks like you caught it just in time!
953 nut
:twocents-02cents:           Should have called, this could have gotten much worse in a hurry.   Glad you got it out but as a former volunteer fireman I can tell you they would have been glad to roll up on an extinguished fire and would help you clear out the shed to be sure there were no hot spots.
  • Like 4
parsonsponyz
Glad you're alright first and foremost and that the shed with all contents were relatively okay.
squonk
FD Love to use their Fire axes! :lol:
We had a big construction job going on at work and there was a staircase that was boarded up on both ends. A smoke detector tripped on top of the stairs and the alarm went off and here come Geneva's finest. We searched for the detector and concluded it was in the stair well. Those guys whipped the axes out like they were six shooters! :hilarious:
  • Haha 4
nyquil junkie
Burn barrels can ruin your day.  A few yrs ago while my GF was buring garden cleanup in the side yard, the yard caught fire 20 feet from the house.
Protip: You can't put out a grass fire by throwing a tarp over it. Sure it LOOKS like its out but who knew... plastic is flammable.
In my defense, it did buy me 3 min to get the hose.
wallfish
Glad you got it under control Ed.
(But I'm still going to bust your nuts at the BS!)
  • Haha 5
kpinnc
Cool head under pressure. You did well sir! :bow-blue:
JoeM
Minutes away from an insurance job!
I quit burning years ago, I just throw it in the trash. They say it is better for the environment but IDK.
Horsin'round
Not the kind of excitement you want.  Glad you were able to control it and minimize damage.
JoeM
Might want to convert an old WH? (did you think you got away?)
  • Haha 4
