PWL216
Is nine months long enough?
PWL216
With guidance from @Bill D….
Took off the plastic trigger ring using a small hook-end pic.
Found a few small pieces on the flywheel magnets of what I assume are old flywheel key and/or pieces gouged off the crankshaft.
Cleaned the trigger ring with acetone.
Reinstall the ring with correct side out.
PWL216
Posted (edited)
But now…I don’t like the way the flywheel bolt threads in. The first few threads look sketchy so I rethreaded them. Still don’t like the way it threads in - to tight. I tried a standard 7/16-14 and it felt the same way. I’m thinking I just screw it in…
Edited by PWL216
Bill D
You should replace the flywheel.  That magnet will shed more pieces, jam into the charging stator and ruin the stator or break the stator mounting tabs off the cam cover.  You can chase the threads in the crank with a tap.
sqrlgtr
This would be my biggest worry and would really check magnets out. If I were in doubt, I would try and run down a good fly wheel. Its hard to tell in Pic how much damage has been done through and if you're not worried about them then go for it.
PWL216
I guess I’m on the lookout now for new flywheel. If anyone’s got one, please let me know. If you know where I can get one at a reasonable price, please let me know that as well. Thanks.
MainelyWheelhorse
To answer your question, for a baby….yes  😁
For a shop to hold your tractor and not work on it…no.
I would have went and gotten the tractor after about two weeks of no activity.
At least you’re fixing it yourself the right way, and not paying through the nose to possibly get it fixed. With the wealth of knowledge here you should get the issue taken care of quickly.
Bill D
Place an ad in the wanted section of the classifieds. Someone may have on. K&B and A-Z should have them as well.  I'm pretty sure the P216, 218 flywheels will work as well.
Bill D
Also consider searching your local FBM for Onan engines.
c-series don
And wouldn’t you know I actually threw one away about a month ago! I had a P216 with real bad knock. I took a few parts off it and scraped the rest. I got tired of it taking up space in my shop and moving it around. As I was getting it out of my truck to scrap it I remember thinking someone would probably take this for parts! But who? And when? Nope, I’m trying to have less junk in my life so away it went. Had I known @PWL216 was going to need the flywheel I would have gladly saved it for him. It’s one of those things that we all think “As soon as I get rid of that, I’m going to need it!” And then we don’t throw it out and then look around and think “How did I accumulate all this stuff?!!” Correct me if I’m wrong, but most of you know exactly what I’m talking about 😂😂
  • Sad 3
  • Heart 1
Bill D
Fully understand. I have way too much stuff.  I also have hoarder tendencies so there's that...
  • Heart 1
sqrlgtr
Just going to go ahead and say if anyone else has any Onan's they are going to throw out holler at me first please.:handgestures-thumbupright:
Bill D
I found a P216 for $50 on FBM.  It's in Cornwall on Hudson.  Probably a bit far to travel.
Bill D
Posted (edited)
Is @Bens vintage tractorsstill on here.  He may have something.   I found his ad on Facebook.   He's got lots of stuff for sale and he's close.
Edited by Bill D
953 nut
He was on before the Big Show but don't recall seeing him since then, could always PM him.
Handy Don
I understand he was living with his mom and had a lot of storage but now she’s moving and he’s downsizing.
WHX??
Posted (edited)
I have a flywheel. Might have the bolt and key way too. Yours for a case of beer. I parted out a PPG20 awhile  ago and pretty sure all i sold were the pistons.
Will get it out for pictures when I get home. At my cabin for a couple days yet.  Remind me PW or I WILL forget
Edited by WHX??
Speeling
Bill D
If he's a motivated seller you might be able to score the parts you need and another tractor.
WHX??
Lookin at your pics it doesn't look like the crank is tapered. Might be just the pic.  The one I have is tapered for sure.  I haven't looked up part nos yet but looks like it sports the same one I have.
What do you guys think ... right one? Hate to send it out if it ain't.
Bill D
Any updates?  Is it running yet?
Cee245
Where are you located?  I have a P220 flywheel.  I dont need anything for it, but its obviously very heavy so shipping would be expensive unless local.
I'm by I90 near Erie, PA.
  • Heart 1
PWL216
Thx @Cee245 I already have one on the way. Paul
PWL216
Hi @Bill D The flywheel should be here this week. Hopefully early this week. If I can get it back together quickly, I’d like to bring it to the M&G this Saturday.
Bill D
Great news.  I can't wait to see a video of it running.   Unfortunately,  I'm unable to make the meet and greet.  It would have been nice to meet you in person.
Since that tractor has been sitting for the last nine months,  now would be a good time to drain out the old gas, change fuel lines if needed and clean the carb.  Changing the plugs and wires wouldn't hurt either.  I've made new wire sets for all my Onans.  I use solid core wires.  Then it will be ready for start up.
Edited by Bill D
WHX??
I got him one coming Cee but yea it just fit in a large flat rate box ... 30 plus smackaroos. Should get it tomorrow but with the holidays ... :confusion-shrug:
PWL216
Update….
1. Timing ring installed
2. New flywheel installed
3. Spark plugs are new and gapped at .025
- not starting still
4.  Installed new coil wires
5. Removed starter coil
- no cracks
- ohms out fine (pics attached)
* confirmed proper oil level to eliminate the possibility of the low oil sensor preventing it from starting
