Goldnboy
C161 stuck reverse
Goldnboy
Picked up a decent C161 auto yesterday at a local WH show.. any ideas why the motion control will stick in reverse and only way to disengage is to turn off the engine?
It does has a hack wiring job that I will redo from scratch once this is resolved.
DLF
Posted (edited)
My 520 would hang up in reverse when i got it, does you C-161 have a Eaton hydro. Found a notch worn in the cam and a worn cam plate that caused mine to hang up. I replace both on the 520-H.
Only way to get mine out when hung up was hit the brake
Lee1977
Edited by DLF
953 nut
K&B has the parts you need and when you figure out what wiring problems you have let us know, we can help.
Goldnboy
I have the sunstrand auto with a Kohler engine i downloaded the SM and look forward to the neutral adjustment..i have done several Eaton 1100 transmissions
953 nut
27 minutes ago, Goldnboy said:
sunstrand auto
:handgestures-thumbupright:              You probably need a new plastic cam plate to cure the problem.
Goldnboy
So I got the new cam plate but not sure what is left to do to remove it to install new one.
squonk
Get a couple of long 3/8" bolts. Take out the upper 2 bolts that hold the trans to the frame and install the long bolts. Take out the remaining 2 original bolts out of the trans and roll the trans back. Replace cam and reinstall trans bolts. May have to unhook the parking brake lever spring.
Edited by squonk
  • Excellent 4
Handy Don
Counterintuitive, for sure, but the amount of things to loosen/remove in the other direction is much larger!
squonk
Half hour job.
953 nut
14 hours ago, squonk said:
Half hour job.
If all of the seat, fender, and tank support fasteners cooperate and you don't have a deck or snow plow frame to contend with..
squonk
Seat and fender should be able to stay on. Maybe a fuel line and tail light wires if equipped will have to be unhooked.
I replaced the control shaft seal in my 875 this way . I was surprised how easy it was to get at everything. The cam is a lot less work than the seal. Even a deck should be able to stay on but would be in the way of a jack to hold the frame up.
Goldnboy
@squonk was good on his method worked well but I needed to remove right foot rest and belt guard to remove drive belt. The eccentric wouldn't move but I worked it  loose with vise grips. It was rough and had burs along with the ball.  I cleaned up with wire wheel mill file and sanded very smooth. I put everything together with new plastic cam and motion control worked really good and stayed in neutral.
Unfortunately in the process I noticed I have cracked frame mounts....
Edited by Goldnboy
squonk
20 minutes ago, Goldnboy said:
@squonk was good on his method worked well but I needed to remove right foot rest and belt guard to remove drive belt. The eccentric wouldn't move but I worked it  loose with vise grips. It was rough and had burns along with the ball.  I cleaned up with wire wheel mills file and sanded very smooth. I put everything together with new plastic cam and motion control worked really good and stayed in neutral.
Good thing you did it that way. Otherwise you wouldn't have discovered it until maybe it was too late! I had a leak at the shaft that cam operates and was putting it off until I felt the seat moving around whilst mowing. Discovered this!
  • Sad 2
953 nut
Catch a problem early any way you can. One non- running parts tractor I bought had been partly disassembled by a previous own and then haphazardly bolted together with about half the bolts missing and nothing tight. I wanted to see if the engine and transaxle were worth anything. I put in a battery, cables, and a temporary gas tank, started it up and drove it around the yard until the front axle fell off.   :scared-eek:       Seems the PO hadn't put the bolt that retains the pivot pin back in.
  • Haha 2
