Goldnboy
C161 stuck reverse
Goldnboy
Picked up a decent C161 auto yesterday at a local WH show.. any ideas why the motion control will stick in reverse and only way to disengage is to turn off the engine?
It does has a hack wiring job that I will redo from scratch once this is resolved.
DLF
My 520 would hang up in reverse when i got it, does you C-161 have a Eaton hydro. Found a notch worn in the cam and a worn cam plate that caused mine to hang up. I replace both on the 520-H.
Only way to get mine out when hung up was hit the brake
Lee1977
Edited by DLF
953 nut
K&B has the parts you need and when you figure out what wiring problems you have let us know, we can help.
Goldnboy
I have the sunstrand auto with a Kohler engine i downloaded the SM and look forward to the neutral adjustment..i have done several Eaton 1100 transmissions
953 nut
27 minutes ago, Goldnboy said:
sunstrand auto
:handgestures-thumbupright:              You probably need a new plastic cam plate to cure the problem.
