tractorhogg 667 #1 Posted May 13 The furthest rear hose on my 3 point cylinder (p/n102174) was leaking a bit from the swivel joint. I had a hydraulic hose place make me another one (50.00), but with the adapter connector it was WAY too big/long to not interfere with the 3 point pivot bracket. I found one with the right part number on eBay for 17.00 shipped, but the connector was larger than mine and after I got it on i'm almost sure the 3 point lift pivot bracket would hit it. The hydraulic hose repair place I used says they can't get that small fitting, so to fix the weeping I took a 4 inch piece of blue masking tape and applied a thick coating of a 2 part epoxy and wrapped the hydraulic fitting where it was weeping, it seems to have fixed the problem, but I would really like to find a place that would have the right fitting or find the correct OEM part. The part I bought from eBay had the right part number, but it was at least 3 inches longer than mine and like I said the fitting was larger in size. Any suggestions would be great. I'll post pictures later. Thanks 1 Share this post Link to post Share on other sites
Bar Nuthin 3,643 #2 Posted May 13 7 minutes ago, tractorhogg said: The furthest rear hose on my 3 point cylinder (p/n102174) was leaking a bit from the swivel joint. I had a hydraulic hose place make me another one (50.00), but with the adapter connector it was WAY too big/long to not interfere with the 3 point pivot bracket. I found one with the right part number on eBay for 17.00 shipped, but the connector was larger than mine and after I got it on i'm almost sure the 3 point lift pivot bracket would hit it. The hydraulic hose repair place I used says they can't get that small fitting, so to fix the weeping I took a 4 inch piece of blue masking tape and applied a thick coating of a 2 part epoxy and wrapped the hydraulic fitting where it was weeping, it seems to have fixed the problem, but I would really like to find a place that would have the right fitting or find the correct OEM part. The part I bought from eBay had the right part number, but it was at least 3 inches longer than mine and like I said the fitting was larger in size. Any suggestions would be great. I'll post pictures later. Thanks I don't know what size ORB fittings your particular tractor needs, but I've been able to get custom hoses made by @wheelhorseman. He owns www.wheelhorsepartsandmore.com Lowell is his name and his hoses are very nice. He should be able to help you. 2 Share this post Link to post Share on other sites
Achto 32,963 #3 Posted May 13 https://wheelhorsepartsandmore.com/product/102174-102287-rear-lift-cylinder-hoses-d-series-wheel-horse/ 2 Share this post Link to post Share on other sites
tractorhogg 667 #4 Posted May 14 4 hours ago, Achto said: https://wheelhorsepartsandmore.com/product/102174-102287-rear-lift-cylinder-hoses-d-series-wheel-horse/ It appears the cylinder is leaking from the rod, not the swivel joint hose. are those cylinders rebuildable? Thanks Share this post Link to post Share on other sites
Achto 32,963 #5 Posted May 14 8 minutes ago, tractorhogg said: are those cylinders rebuildable? Yes they are. Lowell also provides that service as well, if you are unable to do it your self. https://wheelhorsepartsandmore.com/product/gt-14-d-series-welded-hydraulic-cylinder-repair/ 1 Share this post Link to post Share on other sites
tractorhogg 667 #6 Posted May 14 Here's what I'm talking about on the pivot bracket almost hitting the hydraulic hose. I wonder if the pivot bracket is on upside down or backwards? 1 Share this post Link to post Share on other sites
tractorhogg 667 #7 Posted May 14 12 minutes ago, Achto said: Yes they are. Lowell also provides that service as well, if you are unable to do it your self. https://wheelhorsepartsandmore.com/product/gt-14-d-series-welded-hydraulic-cylinder-repair/ Thanks a bunch!!!! 1 Share this post Link to post Share on other sites
tractorhogg 667 #8 Posted May 14 47 minutes ago, Achto said: It appears the lift cylinder is leaking. 90 percent sure, if not it's the hose, good news the NOS hose I bought WILL work if I turn the pivot bracket over, someone put it on upside down. that gives me an extra 1/2" of clearance. The pivot bracket hitting the hose may have caused damage to the cylinder and/or hose. I'll contact Lowell about the cylinder, Thanks Achto Yes they are. Lowell also provides that service as well, if you are unable to do it your self. https://wheelhorsepartsandmore.com/product/gt-14-d-series-welded-hydraulic-cylinder-repair/ Thanks a bunch!!!! 1 Share this post Link to post Share on other sites
