dclarke 4,235 #1 Posted 16 hours ago I picked up a well worn 867 several months ago. Took it apart to determine what I had to work with and started a list of parts I’d need to bring it back to life. I Found the matches under the fender pan. 7 6 1 1 Share this post Link to post Share on other sites
sqrlgtr 2,641 #2 Posted 16 hours ago That's pretty cool find to go along with a cool tractor. 2 Share this post Link to post Share on other sites
dclarke 4,235 #3 Posted 15 hours ago This tractor needed a lot of repair or replacement parts so I met up with a buddy who supplied me with most all the parts needed to put a nice tractor together. 13 Share this post Link to post Share on other sites
dclarke 4,235 #4 Posted 15 hours ago (edited) Last fall I found a decent set of 5.50 front tires, I got all 4 rims cleaned up, new tubes and a coat of Miller’s tire paint and got those ready to go. I was also able to make any repairs to the tins and frame before winter set in, the lower steering shaft was replaced and I had new bushings installed in a couple lower supports and added a zerk to the bottom bushing on the support I used on this project. I got the motor generator refreshed, while it was apart I drilled & tapped new regulator mounting holes to move the regulator terminals a bit farther away from the gas tank then filled the original holes with epoxy. Edited 15 hours ago by dclarke 1 10 Share this post Link to post Share on other sites
dclarke 4,235 #5 Posted 15 hours ago I thought I might play in the snow with this tractor so I picked up some weights and a very nice blade. 3 8 1 Share this post Link to post Share on other sites
dclarke 4,235 #6 Posted 14 hours ago A few months ago I got the tranny apart, found some nice gears to replace bad ones and had to get a new pulley for the 5/8” input shaft. The hub on front of the pulley needed turned down to allow belt alignment so I had that done and then added a couple more set screws to help hold it in place. I also added a second drain plug to the tranny case. 4 9 Share this post Link to post Share on other sites
dclarke 4,235 #7 Posted 14 hours ago (edited) I ran into all kinds of problems with the engine, the block was cracked, the replacement needed bored and all the other usual stuff. I finally found what I needed, had the machine work done and got it back together a few weeks ago. Edited 14 hours ago by dclarke 12 Share this post Link to post Share on other sites
dclarke 4,235 #8 Posted 14 hours ago With the warmer weather I was about ready to start reassembly. I bought a tranny kit from Lowell, had to find good pinion plates for the differential, mine were cracked. Got the tranny together and bolted to the frame. I decided to try the thrust bearings on the spindles so I had the front axle machined for that. 10 Share this post Link to post Share on other sites
dclarke 4,235 #9 Posted 14 hours ago Assembly went pretty easy, all new wiring, new switches & lighter. 10 Share this post Link to post Share on other sites
dclarke 4,235 #10 Posted 14 hours ago I pretty much got it finished up this week. A seat from Matt Castagno, I added seat springs so made a new steering wheel shaft and raised the steering wheel. New decals from Terry and a new headlight lens. A nice original paint tractor with a few added touches. I’m pretty happy with how it turned out. 16 5 Share this post Link to post Share on other sites
kpinnc 17,947 #11 Posted 12 hours ago Looks fantastic to me. To heck with a paint job, you took care of all the important stuff! Very nicely done sir! You even found OEM Kohler engine parts. Awesome! 3 2 1 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,299 #12 Posted 11 hours ago Turned out Nice , Denny ! 2 1 Share this post Link to post Share on other sites
Pullstart 69,815 #13 Posted 7 hours ago Well done! You really have a gem there Denny! 3 1 Share this post Link to post Share on other sites
ri702bill 11,921 #14 Posted 7 hours ago The addition of a second 1/4" pipe plug in the forward well is an excellent idea. 4 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,133 #15 Posted 7 hours ago Beautiful work!!! 2 1 Share this post Link to post Share on other sites
ebinmaine 78,390 #16 Posted 7 hours ago Beautiful work! 1 1 Share this post Link to post Share on other sites
Retired Wrencher 6,598 #17 Posted 6 hours ago (edited) @dclarke Very nice surviver. You do not see these every day. I would not make into a worker just show. Just my Edited 6 hours ago by Retired Wrencher 1 1 Share this post Link to post Share on other sites
ri702bill 11,921 #18 Posted 6 hours ago 16 minutes ago, Retired Wrencher said: @dclarke Very nice surviver. You do not see these every day. I would not make into a worker just show. Just my Nope! They were all intended to be "Workin' Girls". It's what they do best. The way Cecil & Elmer envisioned... 2 1 Share this post Link to post Share on other sites
Thegearhead0324 1,471 #19 Posted 5 hours ago Very good job, all important things fixed and redone, neat and nicely put together, great original patina. All that’s left is to enjoy it . 2 1 Share this post Link to post Share on other sites
sqrlgtr 2,641 #20 Posted 5 hours ago 1 hour ago, Retired Wrencher said: @dclarke Very nice surviver. You do not see these every day. I would not make into a worker just show. Just my 57 minutes ago, ri702bill said: Nope! They were all intended to be "Workin' Girls". It's what they do best. The way Cecil & Elmer envisioned... I believe WH's can do both . 1 Share this post Link to post Share on other sites
ri702bill 11,921 #21 Posted 5 hours ago No "Prom Queens" here..... they all wear their working clothes for all the 4 seasons to get a spot in the garage. 2 Share this post Link to post Share on other sites
WHX?? 56,183 #22 Posted 4 hours ago For sale Denny? You know how I like buying tractors from you!!! 1 2 Share this post Link to post Share on other sites
rjg854 12,967 #23 Posted 2 hours ago 3 hours ago, ri702bill said: Nope! They were all intended to be "Workin' Girls". It's what they do best. The way Cecil & Elmer envisioned... Exactly Share this post Link to post Share on other sites
squonk 46,187 #24 Posted 2 hours ago 2 hours ago, WHX?? said: For sale Denny? You know how I like buying tractors from you!!! Might have to put a few flower pots on Marketplace! Share this post Link to post Share on other sites
Mike'sHorseBarn 3,486 #25 Posted 1 hour ago 2 hours ago, WHX?? said: For sale Denny? You know how I like buying tractors from you!!! You just got rid of an 867 lol Share this post Link to post Share on other sites
