camprc0001@gmail.com
Fuel Pump replacement oem or aftermarket?
I've had problems with aftermarket fuel pump for a wheel horse 312-8, 1988.  Is it better to spend the money for an oem metal version that is supposed to be a lot more reliable but may be harder to install? I would appreciate any advice on this. Thanks, Richard
ebinmaine
7 minutes ago, camprc0001@gmail.com said:
harder to install?
Why would a metal pump be more difficult to install?
I haven't looked in years but I don't know if we can still get metal pumps OE.
It may be worth seriously considering installing an electric pump.
953 nut
:WRS:
For the past thirty years or so the Kohler fuel pumps have all been made of plastic. I agree with @ebinmaine that a low pre3ssure electric pump would be a superior choice. You can power it from the supply that feeds your hour meter that way it is fuse protected and turns off with the ignition. You can find them on eBay for about the same price as the mechanical ones. I use these on all of my Wheel Horses.
Edited by 953 nut
add photo
ri702bill
And, in doing so, you no longer have to be concerned with raw gas diluting the engine oil due to a ruptured pump diaphragm.... and if installed correctly, the electric pump is self priming.
John c
How would you install it incorrectly?
I decided this morning to go with an electric for this C101 I'm working on right now, and I think I know the proper way to install one, as close to the tank as possible, add a filter in front of it, and pay attention to the flow arrow.  I'm gonna feed mine from the ignition circuit at the switch and add a fuse for it behind the dash, I just have finished replacing the wiring so I'm familiar with it right now.
sqrlgtr
I've searched for them NOS but can't even find that anymore :naughty:. I seen in another post earlier that the metal pumps haven't been made in over 30YRs. IDK I've never done the math but that's probably pretty close. I really like the old metal pumps on the older mochines (espeicaly the S/G's) but don't mind Epumps on the 300,400,500 series and think they are a big improvement when fuel tank is under the seat plus you can hide Epump better on them.
ri702bill
Ideally the pump wants to about the same level as the gas in the tank - that floods the pump inlet and allows it to pump immediately (as long as the shutoff is open!!). These pumps do a great job pushing fluid, not so in pulling.
  • Similar Content
    • Mithral
      By Mithral
      So my Kohler CH18S had a coil problem.  One coil tested out bad.  So I replaced both coils while I have things apart, ... and now I have a coil grounding issue.
      When the kill wire is connect to both coils, the engine will not start.
      If I remove both kill wires the engine will start, and will consequently stop when I reconnect the wires.
      If I remove one kill wire from either coil, the engine will start and run on one cylinder, until I reconnect the second kill wire and then the engine stops.
      If I disconnect the kill wire going to the wire harness, it makes no difference to the above.
      It appears that the kill wire connected in series from one coil to the other coil is grounding out from coil to coil.
      I have no idea why this might be.  Unless I simply got the wrong coils.
      So I thought I would ask advice before I go rewiring myself a separate kill switch while I have everything opened up.   Or I guess I could fall back to just choking it to turn off.  Hmm....
    • powerrepair2016
      By powerrepair2016
      Hello, first off please forgive me if I have made an error in going about this on your forum.
      I have several wheel horse parts that are brand new original oem replacement parts for a 1974 c120 (I think) I don't know anything about them. I was curious what there value is, i cant find them anywhere and when i do it just says discontinued.
      Here are the parts I'm currently curious about
      Tire rod assembly - part # 111412
      Assembly clutch bar part # 103227
      Taillight base part # 105202
      I also have a part that just has a hand written tag on it, says  "deck list for 48" 42" wheel horse" it appears to be a part that holds the blade deck up.
      Any input is appreciated.
