pfrederi 20,368 #26 Posted Thursday at 11:16 PM 1 hour ago, wallfish said: Is the little rubber O ring in the hole on the carb body for the low idle screw? Air sucking in there would be an issue I didn't know there was an Oring?? Share this post Link to post Share on other sites
Handy Don 16,357 #27 Posted Thursday at 11:49 PM (edited) 33 minutes ago, pfrederi said: I didn't know there was an Oring?? Yep. On the threaded part of the valve between the spring and the body. Edited Thursday at 11:50 PM by Handy Don 1 Share this post Link to post Share on other sites
ebinmaine 78,453 #28 Posted Thursday at 11:52 PM 35 minutes ago, pfrederi said: I didn't know there was an Oring?? 2 minutes ago, Handy Don said: Yep. On the threaded part of the valve between the spring and the body. Not on several of mine. Share this post Link to post Share on other sites
Handy Don 16,357 #29 Posted Thursday at 11:56 PM 2 minutes ago, ebinmaine said: Not on several of mine. So far on both of the K181 #22s I’ve rebuilt. Pesky little critters and NOT included in the rebuild kits. 2 Share this post Link to post Share on other sites
ebinmaine 78,453 #30 Posted Friday at 12:00 AM 3 minutes ago, Handy Don said: So far on both of the K181 #22s I’ve rebuilt. Pesky little critters and NOT included in the rebuild kits. Interesting. Share this post Link to post Share on other sites
wallfish 19,838 #31 Posted Friday at 12:03 AM 8 minutes ago, ebinmaine said: Not on several of mine. You may not have noticed it. It's usually stuck into the carb body hole and stays but dry rotted ones can fall out 3 1 Share this post Link to post Share on other sites
ebinmaine 78,453 #32 Posted Friday at 12:31 AM 28 minutes ago, wallfish said: You may not have noticed it. It's usually stuck into the carb body hole and stays but dry rotted ones can fall out I'll double check em Share this post Link to post Share on other sites
pfrederi 20,368 #33 Posted Friday at 01:24 AM I thought the idle mixture screw felt a little loose maybe there was an o ring to snug it up. 2 Share this post Link to post Share on other sites
pfrederi 20,368 #34 Posted 18 hours ago (edited) I am more confused than ever about Kohler Carbs. As some have pointed out I should try different High speed and idle needles it my problem carb. Needles have different #s and port sizes ...There are numbers stamped on the high speed needle shahft ..is there a cross reference for that to the #carb it should be on,? Left two ports right only 1 port... Edited 18 hours ago by pfrederi Share this post Link to post Share on other sites
pfrederi 20,368 #35 Posted 18 hours ago Learned a bit about Kohler carbs ... The idle circuit... once you get the plug out there is a chamber with three ways out. One goes directly in to the carb passage one goes to the idle needle and the other goes up to the top of the high speed needle.. Always wondered why the high speed needle had double threads.. the gap between them has a port that feeds the idle circuit. So the wrond high speed needle could be messing up my idle problem 1 Share this post Link to post Share on other sites
tunahead72 2,630 #36 Posted 17 hours ago (edited) 21 minutes ago, pfrederi said: I am more confused than ever about Kohler Carbs. As some have pointed out I should try different High speed and idle needles it my problem carb. Needles have different #s and port sizes ...There are numbers stamped on the high speed needle shahft ..is there a cross reference for that to the #carb it should be on,? Left two ports right only 1 port... Paul, have you looked at the Kohler carb reference manual? It might answer some of your questions. One of my K241 carbs (can't remember which one) has zero ports. I'll post a link to the manual in a few minutes. Edited 17 hours ago by tunahead72 Share this post Link to post Share on other sites
tunahead72 2,630 #37 Posted 17 hours ago Here we go... Engine Kohler Carburetor reference #TP-2377-E.pdf - Kohler - RedSquare Wheel Horse Forum 1 1 Share this post Link to post Share on other sites
pfrederi 20,368 #38 Posted 5 hours ago 12 hours ago, tunahead72 said: Here we go... Engine Kohler Carburetor reference #TP-2377-E.pdf - Kohler - RedSquare Wheel Horse Forum Thank you now some light reading 1 Share this post Link to post Share on other sites
Bar Nuthin 2,358 #39 Posted 5 hours ago (edited) On 4/30/2026 at 2:55 PM, sqrlgtr said: Only other thing I can think of that has not been mentioned is maybe a bent main or idle mixture screw the needle end???? I bent one once and it never would adjust right but robbed one off another and it worked IDK if I just got lucky or they all will swap around.... Same I had one that had the slightest hook at the very tip, I assume from being over-tightened at one time. It was impossible to set the high idle correctly. Sometimes the tractor would die, other times it would cough or surge. I tried filing the tip, but only made things worse. I ended up finding a NOS matching part number on eBay, and now that K301 is my sweetest running engine. Easy start at any temp, steady RPM at low, high, or anywhere in between. Edited 5 hours ago by Bar Nuthin 1 1 Share this post Link to post Share on other sites
tunahead72 2,630 #40 Posted 4 hours ago 53 minutes ago, pfrederi said: Thank you now some light reading Yeah, it's a lot. Share this post Link to post Share on other sites
