pfrederi 21,150 #26 Posted April 30 1 hour ago, wallfish said: Is the little rubber O ring in the hole on the carb body for the low idle screw? Air sucking in there would be an issue I didn't know there was an Oring?? 1 Share this post Link to post Share on other sites
Handy Don 17,474 #27 Posted April 30 (edited) 33 minutes ago, pfrederi said: I didn't know there was an Oring?? Yep. On the threaded part of the valve between the spring and the body. Edited April 30 by Handy Don 2 Share this post Link to post Share on other sites
ebinmaine 80,695 #28 Posted April 30 35 minutes ago, pfrederi said: I didn't know there was an Oring?? 2 minutes ago, Handy Don said: Yep. On the threaded part of the valve between the spring and the body. Not on several of mine. Share this post Link to post Share on other sites
Handy Don 17,474 #29 Posted April 30 2 minutes ago, ebinmaine said: Not on several of mine. So far on both of the K181 #22s I’ve rebuilt. Pesky little critters and NOT included in the rebuild kits. 3 Share this post Link to post Share on other sites
ebinmaine 80,695 #30 Posted May 1 3 minutes ago, Handy Don said: So far on both of the K181 #22s I’ve rebuilt. Pesky little critters and NOT included in the rebuild kits. Interesting. 1 Share this post Link to post Share on other sites
wallfish 20,611 #31 Posted May 1 8 minutes ago, ebinmaine said: Not on several of mine. You may not have noticed it. It's usually stuck into the carb body hole and stays but dry rotted ones can fall out 4 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #32 Posted May 1 28 minutes ago, wallfish said: You may not have noticed it. It's usually stuck into the carb body hole and stays but dry rotted ones can fall out I'll double check em 1 Share this post Link to post Share on other sites
pfrederi 21,150 #33 Posted May 1 I thought the idle mixture screw felt a little loose maybe there was an o ring to snug it up. 3 Share this post Link to post Share on other sites
pfrederi 21,150 #34 Posted May 5 (edited) I am more confused than ever about Kohler Carbs. As some have pointed out I should try different High speed and idle needles it my problem carb. Needles have different #s and port sizes ...There are numbers stamped on the high speed needle shahft ..is there a cross reference for that to the #carb it should be on,? Left two ports right only 1 port... Edited May 5 by pfrederi 1 Share this post Link to post Share on other sites
pfrederi 21,150 #35 Posted May 5 Learned a bit about Kohler carbs ... The idle circuit... once you get the plug out there is a chamber with three ways out. One goes directly in to the carb passage one goes to the idle needle and the other goes up to the top of the high speed needle.. Always wondered why the high speed needle had double threads.. the gap between them has a port that feeds the idle circuit. So the wrond high speed needle could be messing up my idle problem 1 1 Share this post Link to post Share on other sites
tunahead72 2,662 #36 Posted May 5 (edited) 21 minutes ago, pfrederi said: I am more confused than ever about Kohler Carbs. As some have pointed out I should try different High speed and idle needles it my problem carb. Needles have different #s and port sizes ...There are numbers stamped on the high speed needle shahft ..is there a cross reference for that to the #carb it should be on,? Left two ports right only 1 port... Paul, have you looked at the Kohler carb reference manual? It might answer some of your questions. One of my K241 carbs (can't remember which one) has zero ports. I'll post a link to the manual in a few minutes. Edited May 5 by tunahead72 1 Share this post Link to post Share on other sites
tunahead72 2,662 #37 Posted May 5 Here we go... Engine Kohler Carburetor reference #TP-2377-E.pdf - Kohler - RedSquare Wheel Horse Forum 2 1 Share this post Link to post Share on other sites
pfrederi 21,150 #38 Posted May 5 12 hours ago, tunahead72 said: Here we go... Engine Kohler Carburetor reference #TP-2377-E.pdf - Kohler - RedSquare Wheel Horse Forum Thank you now some light reading 2 Share this post Link to post Share on other sites
Bar Nuthin 3,223 #39 Posted May 5 (edited) On 4/30/2026 at 2:55 PM, sqrlgtr said: Only other thing I can think of that has not been mentioned is maybe a bent main or idle mixture screw the needle end???? I bent one once and it never would adjust right but robbed one off another and it worked IDK if I just got lucky or they all will swap around.... Same I had one that had the slightest hook at the very tip, I assume from being over-tightened at one time. It was impossible to set the high idle correctly. Sometimes the tractor would die, other times it would cough or surge. I tried filing the tip, but only made things worse. I ended up finding a NOS matching part number on eBay, and now that K301 is my sweetest running engine. Easy start at any temp, steady RPM at low, high, or anywhere in between. Edited May 5 by Bar Nuthin 2 1 Share this post Link to post Share on other sites
tunahead72 2,662 #40 Posted May 5 53 minutes ago, pfrederi said: Thank you now some light reading Yeah, it's a lot. 1 Share this post Link to post Share on other sites
pfrederi 21,150 #41 Posted May 6 Did considerable "light reading" Thanks to @tunahead72 I finally figured out that the Carb in question has the wrong High speed needle. (at least I think so) but fortunately in my spare parts pile (i never throw anything away...not that I can find it later) I found the right one. Now as soon as i replace the freeze plug I can try it out. n I am having a refreshing malted beverage as this has worked my old brain too hard... 2 4 1 1 Share this post Link to post Share on other sites
Handy Don 17,474 #42 Posted May 6 1 minute ago, pfrederi said: I am having a refreshing malted beverage Essential to keep hydrated to stay at top productivity. Nice work on the needle! 3 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #43 Posted May 6 54 minutes ago, Handy Don said: Essential to keep hydrated to stay at top productivity. I've been known to use that excu..... ehh reason! 54 minutes ago, Handy Don said: Nice work on the needle! Agreed. @pfrederi please keep us posted. 4 Share this post Link to post Share on other sites
pfrederi 21,150 #44 Posted May 6 Just now, ebinmaine said: I've been known to use that excu..... ehh reason! Agreed. @pfrederi please keep us posted. Wish the USPS would hurry up with the plug 3 Share this post Link to post Share on other sites
ebinmaine 80,695 #45 Posted May 6 1 minute ago, pfrederi said: Wish the USPS would hurry up with the plug Agreed. We've had numerous issues with the local distribution center due to lack of staff.... 1 1 Share this post Link to post Share on other sites
ineedanother 2,864 #46 Posted May 7 3 hours ago, pfrederi said: Wish the USPS would hurry up with the plug I buy packs of 10 in the jungle. 3/8 and 5/16 always laying around here. Some other sizes too. 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #47 Posted May 7 8 hours ago, ineedanother said: I buy packs of 10 in the jungle. 3/8 and 5/16 always laying around here. Some other sizes too. Can you PM me the link? Share this post Link to post Share on other sites
Handy Don 17,474 #48 Posted May 7 20 hours ago, ineedanother said: I buy packs of 10 in the jungle. 3/8 and 5/16 always laying around here. Some other sizes too. 11 hours ago, ebinmaine said: Can you PM me the link? And me as well, please? 1 Share this post Link to post Share on other sites
pfrederi 21,150 #49 Posted May 7 56 minutes ago, Handy Don said: And me as well, please? and since the USPS thinks it takes a week or more to move an envelop 400 miles i would like it also.... 1 Share this post Link to post Share on other sites
ineedanother 2,864 #50 Posted May 7 Well, they've gotten more expensive! Although some sources have these things at upwards of $10 each. 3/8" (0.375 $15 for 10) - do a jungle search for item 07-239 5/16" (0.313" less commonly used and more expensive, $38 for 10) - do a jungle search for item 88-171-8 Interestingly, the description for the 3/8" is that they are rubber, silicone not the case...if that search doesn't work let me know and I can PM a link. 1 Share this post Link to post Share on other sites
