adsm08
K181 Carb issues
adsm08
The boy went to mow tonight and couldn't get the engine to start. I took a look, and fuel was running out of the carb. So I took it apart, checked the float and needle, they are working at best I can tell. They pass every test I know, I can flip the carb over and not be able to blow through it, I can hold the float up and get no fuel, I can let go of the float and it drops, along with the needle.
But as soon as I put the bowl on and prime the fuel system fuel starts running out of the carb.
This is one that has had an electric pump installed. Aside from the pump overwhelming the float I'm at a loss.
ebinmaine
What's the exact fuel pump you're using?
WHX??
Float not full of gas ... hole in it?
  • Like 4
pfrederi
:text-yeahthat:
Mike'sHorseBarn
If the bowl vent is plugged it will do that too.
  • Like 5
wallfish
:text-yeahthat:
ri702bill
Yup, a "float" in name only. I've seen a few. If that is the case, best to just replace it.
Are you using the little bent wire clip that loosely attaches the float to the needle? Improperly installed, it can cause the needle not to close all the way....
WHX??
Shortly after I built the flame it started spewing gas. Yep pin hole in float. I was too stupid to pull the float off and check it just dropped the bowl and checked the valve. I had the bowl off ten times before I got off the recliner and checked the float.
A very small hole and just for $hit$ & grins tried to repair it. You know just to see if I could.
Enlarged the hole with a dental pick and shook the gas out and set in a warm place to further evaporate it out. Then just soldered it shut. Being brass soldered up easy.
 Still working to this day.
I had pics if I could find them ... :rolleyes:
Edited by WHX??
sqrlgtr
:text-yeahthat: I hate to admit it, but the little bent wire has bit me a couple times in the past. I've never heard of a e pump going bad and start making more pressure but guess it could be possible.
peter lena
@adsm08   have electrics on my  units ,  2-3.5 PSI  , no issues at all ,  sounds like a VERY TYPICAL COLLECTIVE  ISSUE ,  not one but EVERY stage of  FUNCTION , would recommend an entire carb swap , remove it from the problem , start fresh , like a fuel check valve and filter just before carb ? clear fuel line  , verifies  standing clean fuel to carb !  have that basic  on all my small engines , stand by gen too , no issues , pete
adsm08
This is the pump I am using, it ran all winter and spring so far on this one.
ENGINEMAN Gasoline Electric Fuel... https://www.amazon.com/dp/B0FBGN2PNS?ref=ppx_pop_mob_ap_share
The float is empty, not full of fuel by the time I get the bowl off, and I've never had a punctured one drain that fast.
I am not sure where the bowl vent is on this carb. I mostly work with fuel injection.
The wire clip actually seems to be MIA. I was in a hurry and didn't realize it last night, but I don't remember seeing it at all.
This one has a removable seat. I am not 100% sure the seal between the seat and body isn't leaking, but I can't figure out how to remove it. It is clearly 10mm/ 3/8, but I don't have a socket thin enough and can't get a wrench to swing on it either.
Edited by adsm08
sqrlgtr
all the sunken floats Ive had you couldn't hardly get the fuel out of them so its probably not sinking.
I have seen them with and without and don't believe they are necessary. I have had the float needles go bad and that sounds like what you may have. Is the needle all metal or does it have a rubber type tip?
ebinmaine
6 minutes ago, sqrlgtr said:
rubber type
Age of needle and seat?
Ethanol fuel?
WHX??
Always a problem. Tom @Shynon was turning sockets down and selling them. Originals are 3/8 aftermarkets 10 mm.
adsm08
I have dealt with that issue on fuel level sender floats as well. I am confident it is not sinking.
Rubber tipped needle. Tip feels pretty pliable.
Ethanol fuel?
I bought this unit at the show last year. I only use non-ethanol fuel. All history before last June is unknown.
If anyone here sold a Commando 8 with a bunch of added lights and a car horn to a youngster for $450 down across from the pavilions at the end of the fair grounds, feel free to chime in on the history.
ebinmaine
My experience shows me that if a carb  EVER had ethanol or MAY have had ethanol (you don't know) then it just automatically gets a rebuild.
That's become no more negotiable than an oil change.
A lot of the nut driver sockets that attach to a screwdriver 🪛 handle type driver will work. Not the one piece tool. The little separated bits.
Retired Wrencher
I think those K181 run best with a 1 to 2 Psi pumps. Thais what I have on 856 I have. Also I have this on a 1057. Start up turn key and it is all ready running. I hope this helps. You and your son enjoy the ride when done.
squonk
I have a few I made with my " Poor Mans Lathe!" :helmet:
Bench grinder under the white background
