Buschlight13 9 #26 Posted Tuesday at 08:35 PM 18 hours ago, oliver2-44 said: Now drain the transmission and see if its still full of gear oil, oil and water, or pure rusty water. if it had a lot of gear oil oil or at least oily water soup you might align the forks and put the shifter back in to verify how the transmission works. Then decide if you do a diesel flush or a full rebuild. If it's all water and rust, rebuild it. PS put a new rubber boot on the shifter whenever you permanently reinstall it. That's where they get water in these transmissions Won't have much time to work on it till the weekend, but I did follow the guide, and get the shifter back in place with the screw. However it doesn't move. Gonna watch some of the stuff and plan to drain and clean it. These guides make it seem very doable. 1 Share this post Link to post Share on other sites
Buschlight13 9 #27 Posted Wednesday at 09:35 PM Found a little time to get the frame further disassembled. Gonna drain it and decide what I need to do but really leaning towards a total rebuild cause it looks like a good time. Share this post Link to post Share on other sites
kpinnc 17,674 #28 Posted Wednesday at 09:55 PM 17 minutes ago, Buschlight13 said: like a good time. I can tell you already that your hitch pin is definitely gonna provide a good time. Soak/ heat, soak/ heat, repeat... Don't hit it very hard either. 1 Share this post Link to post Share on other sites
702854boy 632 #29 Posted Wednesday at 10:16 PM (edited) Same with the hubs Another thing to look out for when you take the tranny off is the mounting plate for it, make sure it's not all cracked and everything Edited Wednesday at 10:16 PM by 702854boy 2 Share this post Link to post Share on other sites
Buschlight13 9 #30 Posted 14 hours ago 14 hours ago, kpinnc said: I can tell you already that your hitch pin is definitely gonna provide a good time. Soak/ heat, soak/ heat, repeat... Don't hit it very hard either. Found a few threads on this lol. I'm betting you're right. Share this post Link to post Share on other sites
Handy Don 16,192 #31 Posted 8 hours ago 21 hours ago, Buschlight13 said: leaning towards a total rebuild Leaving the bolts out of the top of the transaxle and an uncovered shifter hole during messy disassembly can easily let crud inside. Outcome depends on the crud, but on any of the hydros, crud can cause serious damage. Share this post Link to post Share on other sites
kpinnc 17,674 #32 Posted 3 hours ago 11 hours ago, Buschlight13 said: Found a few threads on this lol. I'm betting you're right. They will definitely come out with some patience. Just be careful not to get annoyed and try to beat it out. The cast iron case will break. Ask me how I know... Share this post Link to post Share on other sites
Handy Don 16,192 #33 Posted 2 hours ago 28 minutes ago, kpinnc said: be careful not to get annoyed and try to beat it out Yep. Anytime you hit steel hard there is deformation. If it enlarges the diameter of the pin, you’ve just defeated your purpose. Share this post Link to post Share on other sites
kpinnc 17,674 #34 Posted 2 hours ago 18 minutes ago, Handy Don said: Yep. Anytime you hit steel hard there is deformation. If it enlarges the diameter of the pin, you’ve just defeated your purpose. Good point. Most of us cut the pin close to the case, and drill a fairly large hole in the end so we can use a punch to push it out. This reduces the deformation. Share this post Link to post Share on other sites
