BradKahler
Dimensions needed for Mid Mount Grader Blade Bracket
BradKahler
I'm building a mid mount grader blade for my B80 and I've found a lot of information but I'm lacking a couple of dimensions and an angle.  Any chance one of you might have access to one of these and be willing to provide the needed information?
Thanks!
Brad
  • Like 4
ebinmaine
We have a couple Mid Mount Grader Blades here. I can get you those measurements tomorrow.
Have you seen the thread that shows the rest of the measurements?
BradKahler
Yes, I found a thread that had most dimensions but I wasn't comfortable trying to figure out the angle.  I used several different images I found and the camera angle seems to distort the angle enough that each image comes up with different angle.
Thanks, any help would be appreciate.
DLF
The pivot is mounted at 90 degrees to the frame. That angle is determined by the angle the blade is attached to the pivot.
I don't have factory blade to measure. The factory mounted to the top angle of the blade that gave the angle.
Go down to " wheel Horse Manuals" and look up 40" grader blade. It gives good pictures.
BradKahler
I agree, the parts manual appears to show what would be a 90 mounting.  I even found one picture that sort of gives that impression.  However, I've found several others t hat are distinctly not 90 degrees to the mounting arm.  Needless to say it's very confusing.
20180515_203222.jpg.ad5a98c75d2bb4d1de3256049fb65d1f.jpg.b8ef2858dd18038a53d88fd2eeb01d05.jpg
20180515_203610.jpg.9189332c2253cbc9936405c80fab1712.jpg.90bdd85b05154e01b291c850a97aa661.jpg
605207485_2783561438653684_9005058156589560376_n.jpg.0ff3d548fd3183a1a6e7378a6bc000de.jpg
ebinmaine
On 4/10/2026 at 3:12 PM, BradKahler said:
Upper distance is approximately 16".
Measuring the whole upper frame, from the front, the angled pin sets here.
And the rear cross pin is at 18".
Lower distance is 3".
Angle is approximately 105⁰.
  • Excellent 2
BradKahler
Perfect!!  Exactly what I was looking for.
Thank you.
ebinmaine
Thank you.
Glad to help
ebinmaine
32 minutes ago, BradKahler said:
close enough to function.
Agreed.
I'm looking forward to seeing your completed project.
kpinnc
6 hours ago, BradKahler said:
made some progress on fabricating the grader blade components.
Looks factory to me. Well done! :thumbs:
BradKahler
Posted (edited)
I tacked welded the lift arm pieces together so I could do a trial fit and everything seems to look good.  I'm still waiting on the bracket for the blade so it might be a few days to a week or so before I can get much more done on it.
Eric, could I trouble you for one more measurement?  I'd like to know the location of the lifting link tab.  I'm guessing it's centered side to side, but knowing the fore/aft location would be a big help.  Thanks!
Edited by BradKahler
ebinmaine
Glad to help.
I can get that for you sometime tomorrow.
ebinmaine
On 4/17/2026 at 11:15 AM, ebinmaine said:
Glad to help.
OK sooooo tomorrow is actually 3 days...
:hide:
Notice I'm measuring from the SIDE of the large round pin.
BradKahler
:hide:
Perfect!!  Thank you :)
Chrishar
Where did you find the measurements to make the frame part I have the blade but I don't have the frame if you could give me the measurements that would be nice thank you
BradKahler
Along with the pictures provided by ebinmaine in this thread, these are the pictures I found on here on Red Square in a couple of different posts.  So far they have given me all the information needed to fabricate the lift arm assembly.
Moderator, if I shouldn't have posted these pictures, please delete them.
IMG_20181108_173450148.jpg.539f266ecdd22e579d216ba4154eaa0f.jpg.5f6b7d9094047011e25f1f6c81f5a51d.jpg
IMG_20181108_173501579.jpg.c2f1cb786fc26a80c0d958844945e487.jpg.d01915da59cdd3a89b25dc04b63c9163.jpg
IMG_20181108_173509007.jpg.9311bf2738f6b886530568330d738b8a.jpg.43f6ae8ab9172b954da86641581a431e.jpg
IMG_20181108_173518502.jpg.9587c1dadf74f8a4d4441c4c1492eff9.jpg.9123bbe59e7e7822ff15fc2ada3a9884.jpg
IMG_20181108_173530059.jpg.861fddc4985712b6141b6cb9124e5f51.jpg.8819d1d6877866852be233c8d7b5d591.jpg
IMG_20181108_173535976.jpg.2ed0fa68fb6463d1a69012115b7f65db.jpg.7923c66d015400f5e85a78f168a3de76.jpg
IMG_20181108_173558016.jpg.9a4f746bde8fa3ff99c4d6f74e064d0c.jpg.2d55dfb8c9a8bbb48a1b1e0f5e172f58.jpg
IMG_20181108_173626945.jpg.f3e0e79c30cad3267a746489088d6857.jpg.87183d8a9e2b1575f4dd7b935ad8b88f.jpg
IMG_20181108_173640824.jpg.571eef2c3031966c6e71da230d61104d.jpg.56c70e2e64bf12f05b021060cd3277ac.jpg
IMG_20181108_173721616.jpg.f3e7b8e640c9350e110768ab3037dcc6.jpg.58aaaf58e12a4fa8e99cb9d12dfe3af5.jpg
IMG_20181108_173730295.jpg.0010c3e19171a5a3bdfdae3a9982657b.jpg.331b4bddc0d26057be36578e3613c6eb.jpg
Chrishar
Thank y'all for the information
ebinmaine
Some or all o' those are mine too.
I'm fine with the repost. That's what we're here for.
:handgestures-thumbupright:
Edited by ebinmaine
CORRECT AUTOCORRECT
  • Heart 2
BradKahler
Getting closer to having it finished.  I'm just about finished with the sector plate, just need to file the three slots to width and then weld the round bar to the sector plate.  Also I still need to work out the adjusting arm, but I have enough pictures that I don't think it's going to be too difficult.  Once I'm sure everything fits properly I'll get it all welded and painted.
  • Excellent 3
sqrlgtr
@BradKahler
WHOA WHOA, WHOA, I see a big problem here, you should be making two and sell me one :ychain:
  • Haha 5
BradKahler
13 hours ago, sqrlgtr said:
@BradKahler
Well dang, I'm sorry to have to report that the window for ordering has expired... :naughty: :D
I'm glad you like the progress so far!  I've got to file two of the slots in the sector plate to size, tack weld the shaft to the sector arm and then do a trial fit on the tractor.  If all goes well it then next up will be a lot of welding, cleaning, and painting.
sqrlgtr
I guess my coupon is null and void also? :ychain:
  • Haha 1
BradKahler
I tried to put in a good word for you with with senior management but they said there's nothing they can do about it.  If they made an exception for one person then that would set a dangerous precedent :naughty: :D
  • Haha 1
BradKahler
I forgot to mention I also still need to fabricate the adjusting handle.  Stay tuned....
