FLtractor 223 #1 Posted April 9 Afternoon, I cannot find any suitable mounting locations for this facet fuel pump on my 856. Any recommendations? Thought about coil boil, open side hole on frame near the exposed pulleys but awfully close. Thought zip tie and or hose clamp to front axel and extend ground to frame while running positive fuel pump wire to coil. 1 Share this post Link to post Share on other sites
oliver2-44 11,753 #2 Posted April 9 I suggest you look for a mounting place close to the bottom of the tank. all those electric (and old mechanical ones) were good at pushing gas, not sucking a long distance from tank. 1 Share this post Link to post Share on other sites
FLtractor 223 #3 Posted April 9 1 minute ago, oliver2-44 said: I suggest you look for a mounting place close to the bottom of the tank. all those electric (and old mechanical ones) were good at pushing gas, not sucking a long distance from tank. Oh wow I didn’t think it could be mounted that far from carb and that high up.. I was recommended before to mount it low on tractor frame somewhere beneath carb Share this post Link to post Share on other sites
oliver2-44 11,753 #4 Posted April 9 Low is good, but I've always heard closer to tank, and push not suck. Interested to see what others say. 2 1 Share this post Link to post Share on other sites
kpinnc 18,967 #5 Posted April 9 (edited) Get you a couple brass elbows and you can mount it up front. I do suggest you use the included filter that comes with the pump. I made a small L shaped tab and used one oil pan bolt to secure mine on the Bronco. Edited April 9 by kpinnc 3 2 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,681 #6 Posted April 9 Took a screenshot from a YouTube video for you to look at @VinsRJ put his pump under the tank on his 857 project. That would be a much better spot. 1 Share this post Link to post Share on other sites
peter lena 10,065 #7 Posted April 9 @FLtractor have my carbole electric / low pressure pump , 2 - 3.5 psi ,mounted similar to @kpinnc up front , also have a fuel filter and check valve there , clear fuel line , so I can see standing fuel up to carb , also have a filter at tank flow start , never had an issue with fuel delivery . use stabil in all my fuels , add an ounce or 2 to every tank top off , instant starts , no debris in filters . replaced fuel lines , before adding sta bil , no debris at all since , its a good swap , pete 1 Share this post Link to post Share on other sites
FLtractor 223 #8 Posted April 9 2 hours ago, Mike'sHorseBarn said: Took a screenshot from a YouTube video for you to look at @VinsRJ put his pump under the tank on his 857 project. That would be a much better spot. Thank you. Do you happen to have the full video link as well? Share this post Link to post Share on other sites
Mike'sHorseBarn 3,681 #9 Posted April 9 1 hour ago, FLtractor said: Thank you. Do you happen to have the full video link as well? https://youtu.be/ctTXESXH6_U?si=kqc7BOOCBbA60bxM 1 Share this post Link to post Share on other sites
FLtractor 223 #10 Posted April 10 5 hours ago, oliver2-44 said: I suggest you look for a mounting place close to the bottom of the tank. all those electric (and old mechanical ones) were good at pushing gas, not sucking a long distance from tank. Will look into bottom of tank Share this post Link to post Share on other sites
FLtractor 223 #11 Posted April 10 4 hours ago, peter lena said: @FLtractor have my carbole electric / low pressure pump , 2 - 3.5 psi ,mounted similar to @kpinnc up front , also have a fuel filter and check valve there , clear fuel line , so I can see standing fuel up to carb , also have a filter at tank flow start , never had an issue with fuel delivery . use stabil in all my fuels , add an ounce or 2 to every tank top off , instant starts , no debris in filters . replaced fuel lines , before adding sta bil , no debris at all since , its a good swap , pete Will look into the filter, valve and using stabol 1 Share this post Link to post Share on other sites
FLtractor 223 #12 Posted April 10 (edited) 1 hour ago, Mike'sHorseBarn said: https://youtu.be/ctTXESXH6_U?si=kqc7BOOCBbA60bxM Does RJvin still post or frequent this forum anymore? Wanted to ask him exactly how he screwed the fuel pump up into the tank straps or pan the tank sits in.. watched the video but with the spacing of the fuel pump mounting holes and the fuel tank pan … it doesn’t quite make sense where it was screwed up into Edited April 10 by FLtractor Share this post Link to post Share on other sites
FLtractor 223 #13 Posted April 10 5 hours ago, peter lena said: @FLtractor have my carbole electric / low pressure pump , 2 - 3.5 psi ,mounted similar to @kpinnc up front , also have a fuel filter and check valve there , clear fuel line , so I can see standing fuel up to carb , also have a filter at tank flow start , never had an issue with fuel delivery . use stabil in all my fuels , add an ounce or 2 to every tank top off , instant starts , no debris in filters . replaced fuel lines , before adding sta bil , no debris at all since , its a good swap , pete Have a picture of how it’s mounted? From front and behind perhaps? Share this post Link to post Share on other sites
FLtractor 223 #14 Posted April 10 6 hours ago, kpinnc said: Get you a couple brass elbows and you can mount it up front. I do suggest you use the included filter that comes with the pump. I made a small L shaped tab and used one oil pan bolt to secure mine on the Bronco. Do you happen to have a picture showing how it’s attached to the tractor frame? You just used one fuel pump bolt to hold it in place? What size brass fitting are they? 1 Share this post Link to post Share on other sites
kpinnc 18,967 #15 Posted April 10 3 hours ago, FLtractor said: Do you happen to have a picture showing how it’s attached to the tractor frame? You just used one fuel pump bolt to hold it in place? What size brass fitting are they? I don't have pics but it was L shaped with 3 holes drilled: one for the oil pan bolt and two for the pump. Fittings are 1/4 barbed elbow and I think a 3/8 NPT street elbow. 1 Share this post Link to post Share on other sites
Stan50 231 #16 Posted April 10 @kpinnc That block off plate - did you use regular fuel pump gasket with that plate? I fabricated similar block off plate, they layin on the shelf with CarBole fuel pump, waiting for mechanical pump failure Share this post Link to post Share on other sites
kpinnc 18,967 #17 Posted April 10 2 hours ago, Stan50 said: That block off plate - did you use regular fuel pump gasket with that plate? I fabricated similar block off plate, they layin on the shelf with CarBole fuel pump, waiting for mechanical pump failure I just used gasket material and some silicone dressing just in case. But a regular fuel pump gasket will work just fine. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #18 Posted April 10 (edited) FLtractor: The first is mounting second is wirier with fuse. This is on the 856. Works fine so far two years now. Edited April 10 by Retired Wrencher 1 Share this post Link to post Share on other sites
FLtractor 223 #19 Posted April 10 5 hours ago, kpinnc said: I don't have pics but it was L shaped with 3 holes drilled: one for the oil pan bolt and two for the pump. Fittings are 1/4 barbed elbow and I think a 3/8 NPT street elbow. Interesting. What size bolts did you use inside the facet fuel pump mounting holes? Share this post Link to post Share on other sites
Retired Wrencher 6,989 #20 Posted April 10 (edited) One more thing what model did you get =1 to 2 psi or different? Edited April 10 by Retired Wrencher Share this post Link to post Share on other sites
FLtractor 223 #21 Posted April 10 (edited) 28 minutes ago, Retired Wrencher said: FLtractor: The first is mounting second is wirier with fuse. This is on the 856. Works fine so far two years now. So you used this hole here .. and you drilled a second hole into the support frame for other fuel pump bolt hole? went with #. 60245 given yours is on the other side of most I’ve seen.. do you have a picture of how you ran your fuel line from tank to fuel pump to carb? Edited April 10 by FLtractor Share this post Link to post Share on other sites
Retired Wrencher 6,989 #22 Posted April 10 (edited) I used one bolt to the frame and second to the pump with steel with pre drilled holes in it. I do not remember the name of the steel, it has multiple holes. I can take a picture of it today. That’s how I adapted it. Can paint it to blend it in with the rest of the car or just leave it. It’s a short piece anyway I’d say maybe about an inch and a half. Edited April 10 by Retired Wrencher Share this post Link to post Share on other sites
peter lena 10,065 #23 Posted April 10 @FL tractor , 2- 3.5 psi on pump , no issues with that range , also get after any / all related levers / linkage , cables , with penetrating lubrication , the easier it moves / slides , the easier it works , just about every lawn anything I see is caked with rust , choke cables , sound like a hacksaw blade on rust , what could that possibly be? mine slide with ease , pete Share this post Link to post Share on other sites
FLtractor 223 #24 Posted April 10 4 minutes ago, peter lena said: @FL tractor , 2- 3.5 psi on pump , no issues with that range , also get after any / all related levers / linkage , cables , with penetrating lubrication , the easier it moves / slides , the easier it works , just about every lawn anything I see is caked with rust , choke cables , sound like a hacksaw blade on rust , what could that possibly be? mine slide with ease , pete Any recommendations on which lubricant? Same as you use for the cable rasiing and lowering the hitch? Share this post Link to post Share on other sites
peter lena 10,065 #25 Posted April 10 @FLtractor master blaster is good , or similar , verify its spreading , rust run out , creeping related lube stain , also use , super lube , hydraulic oil , after penetrant , comes in small bottles / hardware store . also use that in paint recovery , hot sun soak , feeds the faded paint , pete Share this post Link to post Share on other sites
