Bbrown
502 brake set lever
Bbrown
My 502 doesn’t have a brake set lever , I just put a new brake lining on and would like to get a lever to make the brake system 100%. My parts brake down shows it as part # 4417, I found one on eBay but sells says it’s for a 605 and is a different wheel horse number. I’m finding part numbers sometime are misleading, does anyone know if a 502 and 605 share a common brake lever or where I might find one ?
Easton Rich
I believe they are the same, someone correct me if im wrong. I've got tons of those if you're interested PM me.
Bbrown
Rich I have done some more digging and correct me if I’m wrong. It looks like the 605 lever sits low down near the brake drum and you push it down to lock , the 502 has a cut out in the tin and the lever points upward and you would pull it reword to lock. I could be way off as I’m finding very little information or pictures.
Achto
:WRS:
I believe the difference would be on the notches on the bottom. The one for the 502 would only have one notch so you would have to have your brake set just so for it work. The one for the 605 will have many notches allowing you more choices on your locking position.  As far as interchange ability, I do think that they would interchange. I'll try to get some pics showing the difference.
Bbrown
Thanks I would love to see the pictures
Achto
You're correct, the upper portion of the handle is different. Here is a pic of the one on my 855 (same as a 605 handle)
This is a pic of the one on my 633 (same as your 502 handle)
You should be able to use a lever on yours from any 1962 - 1964 model. Incase you did not know. The last number in the model number will indicate the year of the tractor from 1960 - 1967. Your 502 would be a 1962.
Edited by Achto
Bbrown
Achto that is exactly what I was looking for! Your 633 looks awesome just from that picture, I can only imagine what the rest looks like. Thank you I will continue my search . Living on a hill I think the parking brake is a necessity, the only flat spot I have is in my barn.
Edited by Bbrown
Achto
Thanks.:)
A little eye candy for you.
IMG_20250419_081643271_HDR.jpg.0e0db98bb81723a6b83a351715489d49.jpgIMG_20250419_081808446_HDR.jpg.167dddf4b76198e35e788d9f188e5ad6.jpg
  • Excellent 2
WHX??
:WRS:
This is on  a 702 but should be the same. I may have one if @Easton Rich doesn't. Be a few days before I can look.
Bbrown
WHX I think Easton Rich has the three notch levers, if you have one like your 702 I can put it to good use let me know thanks
Achto
@Bbrown Just a heads up. If you put an @ before the name of the person you want to alert, (like I did with your name). They will get an automatic alert, this helps ensure that they will check your response.
Bbrown
Great tip I’m not real savvy on this stuff, and that is one sharp tractor @achto
Easton Rich
Yep, I looked and I only have the 3 notch levers. Sorry:(
Ed Kennell
@Bbrown  When you want to alert a member you need to type @ then the members name. A drop down of the members names that match will appear. Then click on the name in the drop down that you want to alert.   Try it.
Bbrown
Thanks missed that step
Bbrown
WHX?? Hope you see this
