Bbrown 6 #1 Posted April 5 My 502 doesn’t have a brake set lever , I just put a new brake lining on and would like to get a lever to make the brake system 100%. My parts brake down shows it as part # 4417, I found one on eBay but sells says it’s for a 605 and is a different wheel horse number. I’m finding part numbers sometime are misleading, does anyone know if a 502 and 605 share a common brake lever or where I might find one ? Share this post Link to post Share on other sites
Easton Rich 1,296 #2 Posted April 5 I believe they are the same, someone correct me if im wrong. I've got tons of those if you're interested PM me. 1 Share this post Link to post Share on other sites
Bbrown 6 #3 Posted April 5 Rich I have done some more digging and correct me if I’m wrong. It looks like the 605 lever sits low down near the brake drum and you push it down to lock , the 502 has a cut out in the tin and the lever points upward and you would pull it reword to lock. I could be way off as I’m finding very little information or pictures. 1 Share this post Link to post Share on other sites
Achto 32,963 #4 Posted April 5 1 hour ago, Bbrown said: I’m finding part numbers sometime are misleading, does anyone know if a 502 and 605 share a common brake lever or where I might find one ? I believe the difference would be on the notches on the bottom. The one for the 502 would only have one notch so you would have to have your brake set just so for it work. The one for the 605 will have many notches allowing you more choices on your locking position. As far as interchange ability, I do think that they would interchange. I'll try to get some pics showing the difference. 2 Share this post Link to post Share on other sites
Bbrown 6 #5 Posted April 5 Thanks I would love to see the pictures 1 Share this post Link to post Share on other sites
Achto 32,963 #6 Posted April 5 (edited) 27 minutes ago, Bbrown said: It looks like the 605 lever sits low down near the brake drum and you push it down to lock , the 502 has a cut out in the tin and the lever points upward and you would pull it reword to lock. You're correct, the upper portion of the handle is different. Here is a pic of the one on my 855 (same as a 605 handle) This is a pic of the one on my 633 (same as your 502 handle) You should be able to use a lever on yours from any 1962 - 1964 model. Incase you did not know. The last number in the model number will indicate the year of the tractor from 1960 - 1967. Your 502 would be a 1962. Edited April 5 by Achto 2 2 Share this post Link to post Share on other sites
Bbrown 6 #7 Posted April 5 (edited) Achto that is exactly what I was looking for! Your 633 looks awesome just from that picture, I can only imagine what the rest looks like. Thank you I will continue my search . Living on a hill I think the parking brake is a necessity, the only flat spot I have is in my barn. Edited April 5 by Bbrown 1 Share this post Link to post Share on other sites
Achto 32,963 #8 Posted April 5 1 hour ago, Bbrown said: Your 633 looks awesome just from that picture, I can only imagine what the rest looks like Thanks. A little eye candy for you. 6 Share this post Link to post Share on other sites
WHX?? 58,388 #9 Posted April 5 This is on a 702 but should be the same. I may have one if @Easton Rich doesn't. Be a few days before I can look. 2 2 Share this post Link to post Share on other sites
Bbrown 6 #10 Posted April 5 WHX I think Easton Rich has the three notch levers, if you have one like your 702 I can put it to good use let me know thanks 1 Share this post Link to post Share on other sites
Achto 32,963 #11 Posted April 5 @Bbrown Just a heads up. If you put an @ before the name of the person you want to alert, (like I did with your name). They will get an automatic alert, this helps ensure that they will check your response. Share this post Link to post Share on other sites
Bbrown 6 #12 Posted April 5 Great tip I’m not real savvy on this stuff, and that is one sharp tractor @achto 1 Share this post Link to post Share on other sites
Easton Rich 1,296 #13 Posted April 5 Yep, I looked and I only have the 3 notch levers. Sorry Share this post Link to post Share on other sites
Ed Kennell 47,946 #14 Posted April 5 @Bbrown When you want to alert a member you need to type @ then the members name. A drop down of the members names that match will appear. Then click on the name in the drop down that you want to alert. Try it. 1 1 Share this post Link to post Share on other sites
Bbrown 6 #15 Posted April 5 Thanks missed that step Share this post Link to post Share on other sites
Bbrown 6 #16 Posted April 5 WHX?? Hope you see this 1 Share this post Link to post Share on other sites
Treepep 1,151 #17 Posted April 6 That would be @WHX??. Then he knows! Welcome Share this post Link to post Share on other sites
953 nut 70,653 #18 Posted April 6 Looks like you have found sources for the lever and some good information. 1 Share this post Link to post Share on other sites
WHX?? 58,388 #19 Posted April 6 Yep will take a look when I can. 1 Share this post Link to post Share on other sites
squonk 48,427 #20 Posted April 6 Those flower pots don't move themselves! 1 Share this post Link to post Share on other sites
WHX?? 58,388 #22 Posted April 29 (edited) @Bbrown Here's what I have Bob. Not sure if it's the right one for a 502 or not. It's got the notches on the bottom but I don't think that would matter. The IPL shows it smooth from what I can tell and the same 4417 part number for both tractors. It also doesn't show the offset like I pictured above and that's on the 702 flame. 'Course that doesn't mean that is right either. Hopefully the guys can chime in. @Achto isn't the side cover missing on your 702 maybe look? Sorry for sleeping at the switch on it Bob. I come back from @Pullstart plow day and plum forgot. Edited April 29 by WHX?? Share this post Link to post Share on other sites
WHX?? 58,388 #23 Posted April 29 (edited) Never mind Dan it's missing on your 702. Did we take it off for some reason? Note 702 next to we parted out has one on it. The mystery deepens ... your 702 again Dan. At this point I am at a total loss for which is correct. One style mounts to the clutch rod one mounts to the brake arm. Edited April 29 by WHX?? Share this post Link to post Share on other sites
Bbrown 6 #24 Posted April 29 @WHX?? I think the one on your 702 is what I need. There’s no room on the clutch rod grunion but on the brake rod it looks like it will fit. Thank you for checking I’ll keep hunting Share this post Link to post Share on other sites
WHX?? 58,388 #25 Posted April 30 I concur Bob. I do have the style with the offset but I will most likely need it for a 702 resto I have planned or Dan may need it when he restores his. So I can't offer it at this time. Dan I'm not so worried about he has been known to fabricate them if he has one to copy. By my way of thinking I should have an extra if I could find it ... I'll keep looking. The only thing I can suggest for now is put an ad in classifieds/wanted for one. Share this post Link to post Share on other sites
