Lost Pup
520 Owners with Foot Pedal
Lost Pup
Acquired this 520. Looked clean and cared for. Owners brother did not know much about it.
Starts quick and runs well. Transmission is strong.
First time for me with the foot control and dang it’s seems to far away. I am 5’ 10”.  I think the foot lever needs adjustment.
Are others with the foot control say the main pedal is 90 degrees or less to the floorboard or what ?
This is my pedal at the current neutral position in the pic.
My ankle got rather hot  quickly from the vented cover.
Thoughts and Suggestions are Welcome.
JoeM
Under the floor board there should be a Heim joint. You can unscrew the joint making the rod longer and that should bring the pedal closer to you.
It does look like yours is to far forward.
Edited by JoeM
WHX??
:text-yeahthat:I have mine set so the reverse pedal is 1/4 -1/2" above the floor board.
cleat
Yes, as WHX?? said, adjust it so you get full reverse with the pedal just almost but not quite touching the floor board. That will get you full reverse speed with the main forward pedal as far back as it can be.
