AHS 1,701 #1 Posted March 7 Not mine… yet!! The man described it as running, needs work. C160 8 speed. It was obviously set up as a plow tractor. W/o the PTO clutch the mower lever, and chains and weights. Loud muffler!! Just the tractor, no attachments. It’s 1.5 hours away from home. Honestly, it looks in pretty good shape for being 50 y/o. Ive got an idea what it’s worth, but I don’t wanna over pay. What’s it worth? Share this post Link to post Share on other sites
pfrederi 21,151 #2 Posted March 7 "Needs Work" may mean any thing from oil change and a bath to engine overhaul needed..... 3 Share this post Link to post Share on other sites
ri702bill 13,067 #3 Posted March 7 (edited) 4 hours ago, AHS said: It was obviously set up as a plow tractor. OK, there's a few flags..... You need so inspect the 4 Unidrive mounting holes on the "F" plate for cracking. On the later tractors, the plate material is thinner than the earlier ones and ribs were added. Get a look at the plow that was used. If the moldboard is all distorted like a prize fighters nose, it has seen hard use... Time consuming to fix properly. Also look at the ears on the lower steering block - one or both may be broken off due to the twisting action on the frame in use. Common part. Pull both dipsticks to check the condition & level of the fluids. Water in the Unidrive is a milky mess on the dipstick. Check the four seals on the Unidrive for leakage. Get an honest explaination on "needs work" Any or all of the things I mentioned are repairable, with your time & money, and all affect the price. Low end with issues that are not showstoppers - $200. High end for "clean" tractor - $425. MY ballpark figure. Edited March 7 by ri702bill 4 Share this post Link to post Share on other sites
ineedanother 2,866 #4 Posted March 7 Hubs would be hard to check with weights on. Definitely check the "F" bracket before anything if was actually a plow tractor. Value would be nearly impossible to know without putting eyes and hands on it. 2 Share this post Link to post Share on other sites
ebinmaine 80,710 #5 Posted March 7 Engine. $250 minimum 8 speed transmission. $100 minimum Chains. $50 Other various parts..?? Couple hundred or more. You could pay anything under $500 and not lose. 1 Share this post Link to post Share on other sites
Ed Kennell 47,351 #6 Posted March 7 For me, rollers are worth $150. If it runs and drives with no engine or tranny noise add $100. 4 1 Share this post Link to post Share on other sites
squonk 48,126 #7 Posted March 7 (edited) Seat looks to bedecent. Worth $100 at least. Check the frame/hoodstand area directly under the lift lever. I've run across several with it cracked there. Edited March 7 by squonk 6 Share this post Link to post Share on other sites
ri702bill 13,067 #8 Posted March 7 1 hour ago, ineedanother said: Hubs would be hard to check with weights on. Definitely check the "F" bracket before anything if was actually a plow tractor. Value would be nearly impossible to know without putting eyes and hands on it. Weights are on the outside, glance inboard at the four shafts where they protrude from the housing for seepage. Heavy axle seepage may indicate bad axle bearings - removal & disassembly required to fix. 1 Share this post Link to post Share on other sites
Lee1977 7,772 #9 Posted March 7 It's 1974 or 75 over 50 years old not likely you'll find two tight hubs. 1 Share this post Link to post Share on other sites
ri702bill 13,067 #10 Posted March 7 32 minutes ago, Lee1977 said: It's 1974 or 75 over 50 years old not likely you'll find two tight hubs. But yet I had to cut one off on the C81 I purchased from Sparky..... Sometimes, the red weld wins. This one had walked inward & rotated the key... 1 Share this post Link to post Share on other sites
AHS 1,701 #11 Posted March 7 6 hours ago, ineedanother said: Hubs would be hard to check with weights on. Definitely check the "F" bracket before anything if was actually a plow tractor. Value would be nearly impossible to know without putting eyes and hands on it. Ok, what is the “F” bracket? I would really like to see behind the tractor, and see if it has the plow bracket on there! I bet 100% the shift boot is barely on there, that’s one thing i always check! I’ll check the fan/steering and the frame. Now, the guys just gotta get back to me!! Share this post Link to post Share on other sites
ineedanother 2,866 #12 Posted March 7 2 hours ago, ri702bill said: This one had walked inward & rotated the key... That was my point for @AHS earlier regarding the weights. I should have looked closer at my first c-160. Hubs, axles, and F-bracket had been mistreated over the years before I got it. Dozer blades and chains have been a red flag for me ever since, not that those are ever dealbreakers. 1 Share this post Link to post Share on other sites
ineedanother 2,866 #13 Posted March 7 1 minute ago, AHS said: Ok, what is the “F” bracket? I would really like to see behind the tractor, and see if it has the plow bracket on there! I bet 100% the shift boot is barely on there, that’s one thing i always check! I’ll check the fan/steering and the frame. Now, the guys just gotta get back to me!! That's what @ri702bill and I both referenced. It's what the UniDrive bolts to. A dozer blade attached to the axle bracket can twist and stress the frame enough to cause considerable damage. Lots of discussion over the years here about it. 1 Share this post Link to post Share on other sites
ri702bill 13,067 #14 Posted March 7 (edited) 10 minutes ago, AHS said: Ok, what is the “F” bracket? The 3-sided plate at the rear of the frame. I bought this 854 for parts - only one hole was not cracked out, and the frame itself has a 1/4" twist... the tractor walked & wiggled like an inchworm. Edited March 7 by ri702bill 1 1 Share this post Link to post Share on other sites
AHS 1,701 #15 Posted March 8 Wow!! Holy!! Look at the cracks!! Share this post Link to post Share on other sites
JCM 11,415 #16 Posted March 8 That's what happens to a Wheel Horse when you work it like it's a D8 Caterpillar Bulldozer. It will only do so much over time. 4 Share this post Link to post Share on other sites
AHS 1,701 #17 Posted March 8 1 hour ago, ineedanother said: That's what @ri702bill and I both referenced. It's what the UniDrive bolts to. A dozer blade attached to the axle bracket can twist and stress the frame enough to cause considerable damage. Lots of discussion over the years here about it. Holy smokes!!! It looks like someone rammed into snow banks, etc, (I don’t even wanna know!!). The previous owner of my 00 312-9 bent the plow blade up on either end…. I just didn’t want to know and never asked!! Like @JCM quoted; D8!!! That should say enough!! Ok; im going down a rabbit trail here… i cant stand it when those kids/young adults have Wheelhorses that there running around for a ‘mud mower’!! 3 Share this post Link to post Share on other sites
AlexR 3,112 #18 Posted March 8 If I am not mistaken those are firestone 23° rear ag tires, those are worth a chunk of change as well. 1 Share this post Link to post Share on other sites
JoeM 10,267 #19 Posted March 8 One good indicator of condition is the throttle shaft / linkage wear. A lot of play indicates it being on the governor a lot. I just figure start up front where the power is and work back That machine is desirable and will bring a little more. An hour and a half drive is pushing it for me, that is to just look, but it is a hobby. Most tractor people are pretty honest and will hold it.....but always call before you leave I have on a rare occasion someone change the plan. 3 Share this post Link to post Share on other sites
ri702bill 13,067 #20 Posted March 8 9 hours ago, AHS said: Wow!! Holy!! Look at the cracks!! And THAT is why that area needs to be looked at while the cash is still in the wallet. Also - do NOT trust someone elses cover-up "fix" to hide the damage. I sell reinforcing plate weldments to prevent the damage, not hide it. The best fix is to repair then weld the two together... 1 Share this post Link to post Share on other sites
squonk 48,126 #21 Posted March 8 9 hours ago, JCM said: That's what happens to a Wheel Horse when you work it like it's a D8 Caterpillar Bulldozer. It will only do so much over time. 60" plows will do that! 1 Share this post Link to post Share on other sites
ebinmaine 80,710 #22 Posted March 8 50 minutes ago, squonk said: 60" plows will do that! So will a narrow 42". That's why I reinforced my frames. 1 1 Share this post Link to post Share on other sites
JoeM 10,267 #23 Posted March 8 12 hours ago, squonk said: 60" plows will do that! And rough operators! 4 Share this post Link to post Share on other sites
