Chav88 42 #1 Posted March 7 Hello, my Name is Dick and I have been a lurker for a while and now I’m the proud owner of a 78 D160 with a Onan 16hp and hydraulic 3 point hitch. It additionally came with a plow and snow blower plus the 48” deck. Now let me explain how we arrived here because the D160 wasn’t what I had my heart set on even though now I have it I’m in love. I am with a lack of a better term…a giant NERD. I am a HVACR tech and more specifically a chiller tech and I’ve also done things in my past such as build custom motorcycles, and sheet metal at a resto shop. I have a full fab shop including a lathe, press, chop saw, tubing bender, notcher, tig, mig etc…. My hobby is tinkering from building an repairing my own cars to building mini bikes from scratch. Now I have recently purchased a larger property with a wooded area that need cleaned up and we keep a large garden. I knew I needed a tractor and there is nothing I love more than a tool that can do many jobs. I had my heart set on a gear drive 4x4 sub compact tractor and I quickly realized that it was going to be very difficult to find an older gear drive tractor that had all the attachments I needed that was also within a reasonable distance. Nominees were the JD650, the Kubota b7100, the ford 1200, yanmar 155d, Mitsubishi Beaver. The issue is I wanted a snow blower, a front end loader, and a mower. Finding all of these and less than a few hundred miles proved impossible and even though the attachments can be found it was a mess when it came to getting the right info. If I had time purely as a project it would work but I need this thing to work. I switched my focus to getting 2 machines. 1 lawn and garden tractor for mowing and moving a garden trailer and 1 for the loader. The wheel horse gear drive mowers were already in my want list for my smaller property but it was a little light for what I needed but the d160 popped up and it seemed like the perfect compromise between what I wanted and what I needed. Now, it’s not perfect and it needs a little work. The lower deck needs to be fixed, I’m sure the spindles need to be gone through. The whole thing just needs freshened up. I also need to find a mule drive and get the deck working, as well as build something custom for the 3 point to haul firewood out of the woods. It’s still to be determined if it will make it out of the woods without 4x4 but tires and maybe a winch may help. Maybe I’ll get spunky and build a loader out of it. Only time will tell. 8 Share this post Link to post Share on other sites
ebinmaine 81,281 #2 Posted March 7 21 minutes ago, Chav88 said: still to be determined if it will make it out of the woods without 4x4 but tires and maybe a winch may help You'll do just fine with the right prep. My S/O Trina and I have over a dozen tractors here. We live on a mountainside. She has several smaller mid 1960s machines. Mine are all mid to late 1970s. Much heavier both by initial build but also because that's how they're outfitted by me. Our terrain is pretty challenging here n there. Get some good AG tires or chains. WEIGHT is your friend. Share this post Link to post Share on other sites
Chav88 42 #3 Posted March 7 28 minutes ago, ebinmaine said: You'll do just fine with the right prep. My S/O Trina and I have over a dozen tractors here. We live on a mountainside. She has several smaller mid 1960s machines. Mine are all mid to late 1970s. Much heavier both by initial build but also because that's how they're outfitted by me. Our terrain is pretty challenging here n there. Get some good AG tires or chains. WEIGHT is your friend. Oh yeah, mountains are a different animal for sure. My wooded area is sort of a ravine. What gets us here in IL is the Clay soil. It just hits different when it’s wet. I’m sure when it’s dry I’ll be totally fine. 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #4 Posted March 7 20 minutes ago, Chav88 said: Oh yeah, mountains are a different animal for sure. My wooded area is sort of a ravine. What gets us here in IL is the Clay soil. It just hits different when it’s wet. I’m sure when it’s dry I’ll be totally fine. Likely, your best bet is chains, unless the tractor will be driven across asphalt you care about. Share this post Link to post Share on other sites
Easton Rich 1,296 #5 Posted March 7 1 hour ago, Chav88 said: giant NERD Aren't we all 2 1 1 Share this post Link to post Share on other sites
Chav88 42 #6 Posted March 7 13 minutes ago, ebinmaine said: Likely, your best bet is chains, unless the tractor will be driven across asphalt you care about. Yeah it has the chains with it and I won’t have to worry about asphalt. 2 Share this post Link to post Share on other sites
Chav88 42 #7 Posted March 9 A few additional things I’m adding to the list. 1. Hydro temp gauge is busted. 2. Small hydro leak from the middle cylinder. 3. Deck spindles probably could use a rebuild. Joe M has sent me a mule drive that I will need to rebuild but as long as I can get her mowing within a month or so I’ll be fine. Hardest part is moving my shop to the new property and also needing to get it functional enough to do some minor repairs. I’ll make do. 1 Share this post Link to post Share on other sites
Chav88 42 #8 Posted April 2 Well we have moved into the new property and put the wheelhorse to work. For doing nothing but checking the fluids it was doing pretty good. It had something goofy going on with the idle speed and the choke. But it was running and I had work to do so I let it be for a day or two and it ended up not starting. Simple fix. They had used way too much RTV under the air cleaner which obstructed choke movement which caused it to slip the cable loose which caused it to be stuck “closed ish”. Once again I have a lot to get cleaned up on the new property to get it halfway functional so my fix was a quick temp fix. I used grease to seal the air cleaner and used electrical tape to add a little grip to the cable. I also adjusted the idle and she runs like a top now. 2 Share this post Link to post Share on other sites
Chav88 42 #9 Posted April 2 And then we found ourselves with tire. The previous owners of the property had piles of construction wood and pallets all over the yard for reasons that are unknown. We’ve been cleaning it up and I ran over something pokey. Had to toss a new tube in and realized just how bad the tires are so hopefully these can get me through the summer and I can sandblast the rims and source a pair of back up rims so I can run ag tires on one set and some turf tires on the other. My workshop is in total disarray from moving so I’m sort of limited in what I can do right now. One of the things I realizing is cat 0 attachments are sort of far and few between. I’m going to have to fabricate something so I can skid logs and I also would like to incorporate a receiver so I can fabricate a better trailer too. For now I’m getting by. If anyone has some leads on a spare set of wheels I’d appreciate it. Even if they have the same 6 lug pattern but maybe a different size that I can make work. 1 Share this post Link to post Share on other sites
ineedanother 2,885 #10 Posted April 2 9 hours ago, Chav88 said: Well we have moved into the new property and put the wheelhorse to work. For doing nothing but checking the fluids it was doing pretty good. It had something goofy going on with the idle speed and the choke. But it was running and I had work to do so I let it be for a day or two and it ended up not starting. Simple fix. They had used way too much RTV under the air cleaner which obstructed choke movement which caused it to slip the cable loose which caused it to be stuck “closed ish”. Once again I have a lot to get cleaned up on the new property to get it halfway functional so my fix was a quick temp fix. I used grease to seal the air cleaner and used electrical tape to add a little grip to the cable. I also adjusted the idle and she runs like a top now. RTV really isn't a good choice to use there and I guess you agree at this point. A quick replacement with some gasket paper or something would be more than adequate. I've seen (and maybe have used ) 3x5 cards or a tablet back in a pinch when it's not in a critical spot but I always have gasket paper and hole punches in the shop. 1 1 Share this post Link to post Share on other sites
953 nut 70,653 #11 Posted April 3 Great introduction. Sounds like you have a lot of tasks the D-160 will be able to help you with. 1 Share this post Link to post Share on other sites
Chav88 42 #12 Posted April 5 On 4/2/2026 at 6:37 PM, ineedanother said: RTV really isn't a good choice to use there and I guess you agree at this point. A quick replacement with some gasket paper or something would be more than adequate. I've seen (and maybe have used ) 3x5 cards or a tablet back in a pinch when it's not in a critical spot but I always have gasket paper and hole punches in the shop. Yeah I like to keep some around too for special occasions. Soda boxes work pretty well too. I knew the grease would get me by until I have my shop sorted. Share this post Link to post Share on other sites
Chav88 42 #13 Posted April 5 Starting this post I’m realizing I have yet to get any pictures of the D160 doing work and I’ll try to do better because we have been putting it to work. With that being said I picked up some belts for the deck and mule drive. The deck I had to go with a 105” because I could t find the 105.5 but the local Toro dealer had the correct mule drive belt. I pressure washed the deck and inspected it pretty good. I found a few more issues as well as others I forgot about. I have to weld the shrouds under neath where the welds cracked. This is the biggest challenge right now because I don’t have a 240 circuit ran to my shop yet but my TIG/Arc is dual voltage so I can make it work for now. I’m hoping there is a way to find replacement spindles because these are chewed up pretty good. I think as long as I don’t take them off they will be fine but also the center spindle has something goofy with the spacer. Either way I have the spindles greased up and a new belt on the deck. Then I took the number off the mule drive bearings but figured I’d pop the shields off these and clean them up and see what happens i started with brake clean to flush out dirt, then I blew them out and added a little crease and feels pretty smooth so we will see what happens. The goal is to have the mower on and working tomorrow. 2 Share this post Link to post Share on other sites
Chav88 42 #15 Posted April 10 Well the fun continues. First we had another flat tire due to the tire have a bad bead and poking a hole in the new tube. So today I got 2 brand new tires and tubes, cleaned the inside of the wheels up with a a wire wheel and solved that issue for now. I also got the new belts and mower deck installed. I sort of rigged it for now. Like I said all I have is my 120 arc welder and limited tools u til I get my shop setup but the grass isn’t waiting. So I sort of patched the shrouds up and this is when I realized I didn’t have a lift rod for the deck. So I used what I had to bandaid that problem. I’m going to have to either may something proper or find an actual part for it. My belt for the drive seems too long. I used the OEM but the adjustment has to be all the out for it to work and that push’s the deck so far back that sometimes it hits the rear wheel. Cant imagine if it has the oem 27” tires on it. But it was mowing pretty good otherwise until the mower died. I hopped off and check under the hood and seen nothing. Standing to the side I started it and it started right up. Hopped back on and hit the pto and as soon as I din that it died. I assumed it was the seat switch and it was. So I need to find a replacement for that but for now it’s bypassed. 2 Share this post Link to post Share on other sites
Chav88 42 #16 Posted April 11 Okay this is my theory. Toro gave me a 1594 which is 105.38” and the oem called for 105.5. But I’m betting that the wheel horse 105.5 was the OD and the 105.38 is the standard ID. Non of the pulleys are severely worn enough to cause such an issue with the belt. I’m betting if I were to go to a 103.5 or so I’d be in better shape. Share this post Link to post Share on other sites
ebinmaine 81,281 #17 Posted April 11 @953 nut Any thoughts? Share this post Link to post Share on other sites
Chav88 42 #18 Posted April 11 But she is still putting in work, previous owners were bigger hippies than I. They tried to let the entire yard grow into a prairie but didn’t really understand what they were doing. They ordered to also throw scrap wood in piles so now I have overgrown mess hiding land mines all over. I’m currently doing a full pass with the deck up to take top off and then slowly going back with the deck set at max height. As long as I go slow it’s doing okay but once this belt stretches a bit I’m sure it’ll be an issue. 3 Share this post Link to post Share on other sites
Chav88 42 #19 Posted April 12 Last night after getting the entire lawn mowed twice and several interactions with land mines we shut her off and took a break to tend to the burn barrel that’s been burning for 3 weeks to get rid of the trash wood scattered all over the property. When I came back….no start. Battery was dead. What’s odd is I confirmed it was charging shortly after buying it and the ammeter shows it’s charging and increases as you add lights or clutch. But the only thing I can think of is that I was using the clutch for so long that it put another draw on the battery and I didn’t let it charge up after shitting it off. Not that it’s correct but it’s something to keep an eye on 1 Share this post Link to post Share on other sites
Chav88 42 #20 Posted April 21 Okay I have some updates. Today I searched and found a 103” belt and with the adjuster all the way tight the 103” fits perfect. But I did make a realization and I have to take the blame. Not often I admit I messed up but I realized I put the 107.38” belt on the mule drive instead of the 105” and I put the 105” on the deck. Which explains why the spindle belt was too tight. I wrote it down wrong and never went back and re confirmed my numbers. So I guess the only good is I learned that there is quite a bit of play in the belt size so if in the future I’m in a bind I can make things work. I noticed a huge difference having a tighter belt. I was able to mow the county ditch full speed without having too poor of a cut. So I am loving this thing. One odd thing is now the deck sits for the forward so it’s not hitting my wheels but when I lift the deck the mid lift rear brackets interfere with the rear adjustment. I’m going to have to read the manual again and make sure I’m not missing anything. Few other small updates. I made a cheap drag harrow that I’ll have to get a picture of and I’m on the hunt for a plow bracket. Other than that the battery still goes dead after using the PTO so I’m going to have to look up the charging specs. I’m assuming the charging system is weak. And lastly I came across a c160 so I might be able to use for parts, I have to do some research, as well as a 24hp Onan. I’m guessing it’s far too large to fit in the area the 16 fits. 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #21 Posted April 21 25 minutes ago, Chav88 said: c160 That by itself is a very desirable model. A grail for lots of folks. Share this post Link to post Share on other sites
Chav88 42 #22 Posted April 23 On 4/21/2026 at 6:24 AM, ebinmaine said: That by itself is a very desirable model. A grail for lots of folks. Really? For me I love my D series but I’d really like a gear drive. My friend is wanting me to buy his d180 with end loader and 3 point mower. Now that’s tempting! 1 Share this post Link to post Share on other sites
Chav88 42 #23 Posted October 12 Okay long time since I’ve made an update. The wheelhorse has served me well this summer and she has gotten all the work done that I needed but she has found some issues. The deck is popping holes left and right. I’ve patched them but a combination of the decks condition and my property has left the deck in rough shape. I’ve tried to find a replacement but marketplace has been less than fruitful. I thought about fabbing a new deck or modifying one to fit. But at this point it’s time for her to get the snowblower hooked back up and get freshened up for winter. I also need to build a ballast for the rear and find the proper size tire chains. 1 Share this post Link to post Share on other sites
953 nut 70,653 #24 Posted October 12 Welcome back. I can't see any reason that the mounting hardware from your mower couldn't be transplanted to a newer deck from a 300 or 400 series. Their mounting looks extremely similar, there are a couple of "D" adaptors shown but you already have them. 2 Share this post Link to post Share on other sites
parsonsponyz 420 #25 Posted October 12 Glad to hear your making progress on your property and tractor. So, regarding the mower deck, my recommendation would be to find another 48" in good shape and transplant your mounting hardware to you "new" deck. I have done this in the past instead of taking time to prolong a rusting deck. It's been a while since the last time I performed this task but if I'm remembering correctly, it's a bolt on job. 2 Share this post Link to post Share on other sites
