Pullstart
2026 Big Show Buy/Sell/Trade Thread
Blaine
8 hours ago, Ed Kennell said:
I'm not sure if they will fit, but there will be plenty of experts at the show that will know.    Take some close up pics and some measurements to compare.   I'll be there Thur-Sat.
I may be coming to Dover before the show.  My son lives near Pinchot Park.  If I come your way, I'll get your address and bring them along.
Thanks for making me take another look. It’s a 4413, not 3924. I was looking at the wrong thing in the parts diagrams. Apparently the 4413 fits some rangers, and probably other models as well. 13 full teeth and the number is just below them. The one in your bucket looks like a good possibility.
Edited by Blaine
Pullstart
@pfrederi I’ll do that engine deal.  :handgestures-thumbupright:
Dan 312-8
Anyone near this that is coming to the show?
pfrederi
Its yours
Ed Kennell
17 hours ago, Blaine said:
It’s a 4413
Here are the three that I have.
IMG_20260602_083306675_BURST000_COVER.jpg.1a1917819008fdb605ce699c770d45bc.jpgIMG_20260602_083140424_BURST000_COVER.jpg.f6581faf0d4dd19a149ed0ed15e8e0c3.jpgIMG_20260602_083109711_BURST000_COVER.jpg.7406e6b1fc44dff8c2f91ee334adf5d9.jpgIMG_20260602_083007773.jpg.dce37f55f72041031d16c84e18e6a4ca.jpg
702854boy
2 minutes ago, Ed Kennell said:
If @Blaine doesn't need the one on the left, how much do you want for it?
WHX??
I was Dan but since Sparky won't make diesel come down to less than $100 a gallon those plans got nixed. I got a hold of him and going to go get it just to keep it from falling into the hands of the enemy. Yours still if you can find hauling help but we don't know of anybody from this area that is going. :unsure:
  • Sad 5
  • Heart 1
Pullstart
Now I’m going to have to find my own fun?  Dang I was looking forward to some poop shovel Mac!  It’s all the craze these days you know.  :sad-pacing:
  • Haha 3
WHX??
Yeah I know ... bums me 'till no end.
Dan 312-8
Thanks Brother!
Let’s see how it shakes out.
I am fortunate, I live less than 90 minutes from the show. But 14 hours from the grader blade…
 I truly appreciate your thoughtfulness!
Bests,
Dan
Ed Kennell
$20 delivered to the Big Show.     Oh, Red Square Supporters always get a 50% discount.   =  $10
  • Excellent 2
  • Heart 1
702854boy
I'll take it
Sparky
  Oh don’t be blaming me!
  Doesn’t your wife drive a Prius??? Fuel it up or plug it in or whatever it is ya do to make those things run and get to the show!!
  Maybe rip the seats out so that 867 will fit in the back…think outside the box Jim!!
 :lol:
  • Haha 5
squonk
Now, who am I going to pick on?
  • Haha 2
Ed Kennell
Plenty of choices left.         :occasion-clown::occasion-clown::occasion-clown::occasion-clown:
  • Haha 3
squonk
1 of those :occasion-clown: doesn't sit still long enough.
  • Haha 1
Pullstart
:greetings-waveyellow:
  • Haha 4
squonk
@WHX?? triple up with @Pullstart split the fuel and tolls 3 ways . Hook your trailer to Kevin's Taj Mahal and each bring 1 tractor. It's not like you need to pay for a hotel room also. You'll be kicking yourself and flapping around like a Batam rooster if you don't go.
  • Excellent 2
  • Haha 3
Handy Don
I'll volunteer, too. :)
pfrederi
3 spd tranny 1" axle. Was working ok but pulled out  of service because she would get stuck in two gears.  Never got around to grinding a flats on the shift rails to fix it.  $10
piston to piston sunstrand picked up years ago no idea of condition but it does have the hydro cylinder, control valve and implement relief valve  $ 20
squonk
Paul I'll take that 3 spd.
Blaine
 I found this bulletin. ?do=download
 It leaves the question “but what about the 6471?”
 I never lifted the 702 to see exactly what happened as i could see from the top side that it had obviously snapped. I just got done having a closer look at things. Apparently the 4413 was an issue. The bore area is only about an inch long, so it got loose on the shaft. Someone partially welded it to the shaft, then the pin eventually walked out only holding on one side and snapped the bore out.
 So it looks as though WH lengthened the bore area and increased the roll pin to 5/16”, then eventually welded the sector to the shaft as an assembly, (for models that use 2 tie rods) but no welded assembly for models that use a single tie rod, that i can find anyway.
 Being that my shaft is worn and torn up pretty bad, i may be able to use one of the welded ones, if the total shaft length is at least 17-3/4.
My shaft is actually about 17-1/8”, but it only sticks through the sector maybe an inch, like the one to the left in of your picture. So if one of the welded ones are about 16” from the flat of the bore area on the toothed side of the sector to the other end of the shaft, i should be able to make it work.
I’m assuming that the shaft on the right has what looks like a spacer/washer on top and it is not an extension of the sector casting. If it is part of the sector, i’ll take the one in the middle. :text-thankyouyellow:
If the two hole steering pivot falls at the right area, i could drill a hole between them where needed, if not i can remove it and use my single hole steering pivot.
 If the shaft isn’t long enough, i have some 3/4” i.d dom tubing to fix that too.
Edit: Which one does NOT have the extra half teeth on the ends? I don’t know if they’re needed but mine has them.
Edited by Blaine
pfrederi
You got it.
adsm08
Not sure if I can use it for any of my projects, but for $20 I'll bite.
