WHX?? 54,902 #1 Posted 6 hours ago No relation to @19richie66 I'm sure but every time I use it I think of him. It was FREE from a wholesaler for selling mini split air conditioners. Thought what good is it with a stupid metric crescent wrench head in our line of work. Supposed to be used for torqueing flare nuts for proper install of aforementioned ACs. 'Till I found they offer a 3/8 ratchet head. Found in the jungle no less. Bad news it only goes to 60 ft lbs but still. Measures in inch lbs as well. Has a visual & tone when torque setting is reached. Very handy for rod caps on a Clinton. 5 2 1 Share this post Link to post Share on other sites
ri702bill 11,248 #2 Posted 4 hours ago 1 hour ago, WHX?? said: Thought what good is it with a stupid metric crescent wrench head in our line of work. Supposed to be used for torqueing flare nuts for proper install of aforementioned ACs. The original Metric / SAE Fitzall wrench!! Share this post Link to post Share on other sites
JoeM 9,605 #3 Posted 4 hours ago 2 hours ago, WHX?? said: Supposed to be used for torqueing flare nuts for proper install of aforementioned ACs Along the way, some of our equipment was hosed with JIC hoses and nuts. One issue was leaking due form over tightening hose ends on the flares. Had to have a class on how not to gorilla tighten JIC fittings. After that a lot of problems went away. I have an inline figial digial head and it works pretty good, I have found it requires a certain touch. 1 Share this post Link to post Share on other sites
Handy Don 15,908 #4 Posted 2 hours ago 1 hour ago, JoeM said: Had to have a class on how not to gorilla tighten JIC fittings. After that a lot of problems went away. Well made point! I got a lesson from a hydraulics guy. His advice was to go “firm” and then, with the pump running, tighten to just past where the leaking stops! So that’s how I did it and, so far, it’s worked. 2 2 Share this post Link to post Share on other sites
19richie66 17,803 #5 Posted 16 minutes ago Very handy indeed but I see nothing Ritchie on it. But if it makes you smile every time you use it, I’ll be there for you! I got ya brother! Share this post Link to post Share on other sites
