tractorhogg 618 #1 Posted Tuesday at 11:35 PM My engine gave up the ghost, a trusted repair shop says the piston/rings are worn and the cylinder is out of taper and out of round. They also said the crankshaft, bearings, and oil seals need to be replaced, both ends have play in them. It will also need a new connecting rod, both valves, springs and valve guides. The repair shop doesn't think I should use aftermarket parts, but with labor and material I'm going to be well over 3k in this rebuild, that's not in my budget. I am open to buying a decent used K341a (spec 71141) or buying NOS parts from members or sellers here. I really hate to use a newer replacement engine, I wont ever buy a predator engine, but I'm open to a Honda, Briggs, Kohler 20-24 hp. I'd also be open to a kohler k482 or magnum 18-20 hp if they were in good shape. I really appreciate any input or idea Share this post Link to post Share on other sites
Handy Don 15,950 #2 Posted Tuesday at 11:42 PM (edited) If (or when?) I’m facing a repower decision, I’d look first at a Briggs Vanguard twin. Not a direct bolt-in, but not far off. My thinking, as a guy who has only worker equipment, is that getting a 40 or 50 year old engine would not fill me with confidence unless I could be positive it had years of useful life ahead. If I were doing a resto or a parade tractor, I’d have a different opinion. Edited Wednesday at 07:33 PM by Handy Don 2 Share this post Link to post Share on other sites
Easton Rich 982 #3 Posted Wednesday at 01:39 AM If its gonna be a worker I'd go with a Vanguard. @kpinnc might be able to give you some insight on them. 1 Share this post Link to post Share on other sites
kpinnc 17,159 #4 Posted Wednesday at 03:08 AM 3 hours ago, tractorhogg said: My engine gave up the ghost, a trusted repair shop says the piston/rings are worn and the cylinder is out of taper and out of round. They also said the crankshaft, bearings, and oil seals need to be replaced, both ends have play in them. It will also need a new connecting rod, both valves, springs and valve guides. The repair shop doesn't think I should use aftermarket parts, but with labor and material I'm going to be well over 3k in this rebuild, that's not in my budget. Which engine are you referring to? All the faults you describe are common to an engine that is just worn out. The price range you describe sounds a bit high, even if it is an Onan. 2 Share this post Link to post Share on other sites
Achto 31,017 #5 Posted Wednesday at 12:51 PM 13 hours ago, tractorhogg said: I really appreciate any input or idea 3 Share this post Link to post Share on other sites
pfrederi 19,895 #6 Posted Wednesday at 07:45 PM Lot of us have over hauled with after market parts (heck where are kohler part made nowadays..) Why did he want to replace the crankshaft because it needs to be ground and he can't do it??? Rebuild kits are 160 Valve guides $20 Crank bearings ( have never had to replace them) another $50 My machine shop bore and hone cylinder 100 Grind Crank 75 valve job 40 Will after market last 50 years like your did...Maybe not but, probably long enough...,,, 3 Share this post Link to post Share on other sites
tractorhogg 618 #7 Posted 6 hours ago On 2/25/2026 at 6:51 AM, Achto said: Thanks, I'm going to sell the tractor. I'm listing it in the classifieds for 600 1 Share this post Link to post Share on other sites
tractorhogg 618 #8 Posted 6 hours ago On 2/24/2026 at 9:08 PM, kpinnc said: Which engine are you referring to? All the faults you describe are common to an engine that is just worn out. The price range you describe sounds a bit high, even if it is an Onan. 16 horse Kohler single, It ran good a month earlier, no smoke or no use of oil, plenty of power. I'm going to sell the tractor, I bought another one Share this post Link to post Share on other sites
tractorhogg 618 #9 Posted 6 hours ago I've decide to sell the D-160 and let someone either repower it or put the engine back together. I'll list it locally and on the classifieds here. The shop said it was .003 out of round/taper, but it did not smoke or use oil. I've bought another D series for 2000.00, seemed the better deal 2 Share this post Link to post Share on other sites
