JCM 11,002 #1 Posted February 16 Recently installed the 48'' dozer blade for Winter plowing as needed. After when finished all connections I used this lubricant to top off the install. This blade has not seen service for a while and the channel and sector needed a good lube as did the release pin for the blade angle. These Chesterton Products are great. Had a connection to them in 1984-86 when I worked in a chemical plant . They still dispense after all these years. Thinking of you Pete. @peter lena 2 4 1 Share this post Link to post Share on other sites
ebinmaine 77,972 #2 Posted February 16 4 hours ago, JCM said: Chesterton Products That's a new one to me Jim. 1 Share this post Link to post Share on other sites
lynnmor 8,700 #3 Posted February 16 3 minutes ago, ebinmaine said: That's a new one to me Jim. Yes, it is a rather new company, only 142 years old. 1 2 Share this post Link to post Share on other sites
ebinmaine 77,972 #4 Posted February 16 1 minute ago, lynnmor said: Yes, it is a rather new company, only 142 years old. That's it ??!! 1 Share this post Link to post Share on other sites
JCM 11,002 #5 Posted February 16 They have the best teflon pipe dope ever made in my opinion along with there gold end teflon tape among many other products. Share this post Link to post Share on other sites
peter lena 9,812 #6 Posted February 16 @JCM thanks for the shout ! not familiar with that one , experiment , does it stand up ? creep as stated ? always trying something , like to stay after chains / related , just a basic for me , just got in,battery tender plug in was finally removing ice cap on driveway , my sun angle is at it is weak in winter , just when you need it most . always do a once over after any use , fuel top off , stabil , oil check trans check , anything need a look ? battery tender plug in , light bulb reflector , under engine , been using MACS chain / cable , napa , with good adhesive results , also really stays with my plow quadrant , movement set up , very smooth / easy lever squeeze , blade swing is effortless . regularly refer to related movement ease , that says it all about , my attention to detail , just something i,ve always done . used chesterton at pfizer , worked there for 30 years , retired for 20 , basically , if it creeps , thats what you want , pete 1 Share this post Link to post Share on other sites
