Andy N.
Winter Project - Tractor Cab and Snow Blower Electronic Control Upgrade!
Easton Rich
Fancy!
kpinnc
Very nice! :thumbs:
WHX??
Wow!!!! @dclarke you gotta see this!
Edited by WHX??
JCM
AWESOME Andy   That black roof is great looking on there as well as all your other mods. Love the horn demo and smile. Money well spent. You will never regret having an OTC. Great job !!
ri702bill
Looks like you are ready to take on a DOT contract!
Well Done
  • Haha 1
SylvanLakeWH
:eusa-clap:
Bill D
Excellent!
Achto
That is SAWEEEET !!! :handgestures-thumbupright:
Achto
8 hours ago, Andy N. said:
and cab heater
Did you go with the one from Original Tractor Cab? I see that theirs had a 25amp draw. Just wondering if you have enough charging out put from the engine to keep up with it?
dclarke
Might be time for you to upgrade the 520, Jim…. Excellent work, Andy N.!!
  • Haha 2
Andy N.
i did and to be honest, the heat output probably won’t make much of a difference in the cab. I put my digital multimeter on the battery and turned everything on one by one and it did draw down to just under 12 volts when I turned the heater on with all the lights on. The heater was free with the package as part of a promotion they were running at the time.
I do plan upgrading to a digital volt/amp gauge on the tractor.
Also will be looking for a reduction steering kit to put on it. I believe everything from a 520-H system should fit on a 418-A with little modification. I’m planning on the cab being a permanent install and didn’t want to put it on the 520-H that I have because that reactor was my Dad’s and has sentimental value and enjoy using it for mowing and other things.
Edited by Andy N.
WHX??
First thing I thought of Denny when I saw the joy stick! Problem is we usally did't have enough snow to justify it. This year being somewhat of a exception untill the back end of winter when we did't get any snow. Had it out for those light dustings just for the seat time.
Not fammiliar with a 418 electrical sytem Andy but yes be careful of a the accesories. I did draw measurements on the high powered lighting I put on but blew the nine pin out on every 520 I modded.  Now that everyday is Saturday never blow at night anymore. Don't have to worry about blowing early AM or when I got home from work in the dark.
You would like the 520 front end running gear ...makes a world of difference when using a suicide knob & turning radius. I see @Easton Rich has some for sale now. Pullstart may have a extra setup too. Might want to consider a foot motion kit too.
Bad thing is it's a pain to do maintenance on a tractor with a cab on ... 520s anyway. Can't even check check the oil decent with a deuce on.
Andy N.
My 520-H is a '89 which originally didn't come with reduction gearing. A few years back, I did find a system for sale and installed it on that. It is very nice with front mounted attachments and 60" mower deck.
Routine engine mx isn't as bad on a 418-A with the cab. WH went with no oil filter on the M18. Anything heavy on the rear cylinder would be definitely be a PITA. I did get pretty good at taking the battery in and out with the cab installed during this whole process. :D
I did pick up my 12 volt power from the accessory line prior to the fuse, since I installed separate fuses for everything I installed, and just getting those wires routed was very tight. The junction box in the pic below that I mounted forward of the fuses came with the kit.
1 hour ago, WHX?? said:
Not familiar with a 418 electrical sytem Andy but yes be careful of a the accesories. I did draw measurements on the high powered lighting I put on but blew the nine pin out on every 520 I modded.  Now that everyday is Saturday never blow at night anymore. Don't have to worry about blowing early AM or when I got home from work in the dark.
Luckily, no 9 pin on the 418-A. Much simpler electrical system.
JCM
I also received the electric heater promotion from OTC when I bought the cab for my JD 3320 four or five years ago. They should have saved themselves the trouble shipping it,completely useless. Again nice job on the Mods.
wallfish
Very Nice!
I like the idea of a joystick over using smaller switches.
Adding a small flap of rubber or some weather strip under the bottom edge of the deflector will stop the back flow of snow when it is pointed down. That back flow snow will cover the limit switches
JCM
 Very nice feeling to do it when it's not dark, snowing and blowing. Way more fun. We earned it for sure.
Easton Rich
Ill let it go for $325. Or make me an offer if you're interested
c-series don
Did I miss something @Easton Rich? What are you willing to let go for $325? You know I wouldn’t want to miss out on something that I don’t necessarily need!!😂
