Trimman 0 #1 Posted February 10 I just bought my first awesome Wheel Horse 520H with a 44" snow blower. The blower doesn't lift real high. How can I make it lift a little higher? Share this post Link to post Share on other sites
rjg854 13,454 #2 Posted February 10 You can add washers or some type of bushing between the flag and the pipe to make it lift higher. Of course this will depend on what type of blower set up you have. 1 Share this post Link to post Share on other sites
wallfish 20,744 #3 Posted February 10 It doesn't need to lift very high to transport it. Mine lifts about 2-3" off the ground. The adjustment for a 44" 2 stage is the metal plate with multiple location holes in it. The slot is at the bottom. The slot allows the blower to float with the terrain as it's moving so keep in mind he higher you make it lift, the less float down action it will have. Randy was referring to a single stage blower lift bar for washers. The 2 stage lift rod is much different. 5 Share this post Link to post Share on other sites
c-series don 12,752 #5 Posted February 11 2 hours ago, wallfish said: Mine lifts about 2-3" off the ground Mine is the same. I have a 44” two stage on a 417-A. I’ve never really had the need to lift it higher, as long as it’s up a few inches for transport or backing up it has worked fine for me. 5 Share this post Link to post Share on other sites
wallfish 20,744 #6 Posted February 11 Most of the time I don't even lift it up when backing up while doing snow. 1 Share this post Link to post Share on other sites
WHX?? 58,388 #7 Posted February 11 Good luck with your new to. Any issues with it lots of pros here. Lot of good info here on deuces not to mention 520s. 4 hours ago, wallfish said: Mine lifts about 2-3" off the ground. I'll third that and when it is lifted it hangs to one side which I think they all do. I very seldom lift it when blowing just when heading to the barn. 2 Share this post Link to post Share on other sites
lynnmor 9,081 #8 Posted February 11 10 hours ago, WHX?? said: I'll third that and when it is lifted it hangs to one side which I think they all do. Do you have the heavy lift assist spring installed? Mine lifts reasonably level. Share this post Link to post Share on other sites
Dan 312-8 663 #9 Posted February 11 12 hours ago, c-series don said: Mine is the same. I have a 44” two stage on a 417-A. I’ve never really had the need to lift it higher, as long as it’s up a few inches for transport or backing up it has worked fine for me. @c-series don where our friendship first started, 2021 at the Big Show, me staring a 44" 2 Stage blower, and you walking up commenting on how great they were. We must have BS'd for over an hour, exchanged phone numbers and the rest is history. This is more than red tractors, it's a Brotherhood! 2 Share this post Link to post Share on other sites
WHX?? 58,388 #10 Posted February 11 27 minutes ago, lynnmor said: heavy lift assist spring Yes I do. Also one under neath on the lift bar. Even looked at ways to put one on the other side. Just learned to live with it. On uneven grade it can dig it if not careful. They are about as heavy as a 60 inch deck. 2 Share this post Link to post Share on other sites
