WHX??
Oiling Pre Filters
WHX??
Who actually does this? I know what the book says but when you do it it seems to make a mess of the air box collecting more dirt no matter how much you squeeze the excess out.
Racinbob
I never do for the same reason.
Ed Kennell
You may be the only one.
Well, maybe oily Pete.  :confusion-shrug:
Edited by Ed Kennell
  • Haha 5
lynnmor
I follow the instructions on the label so the fine dust gets trapped.  After oiling the foam work it in, then remove the excess by repeatedly squeezing the foam with paper towels layered in.  With no oil you will not trap anything but the large particles, the paper filters are getting expensive and blowing tiny holes in them with compressed air is not a wise move.
  • Excellent 2
702854boy
We usually do this on our Cub Cadet as it has a prefilter but the Wheel horses don't.
Mike'sHorseBarn
I always throw the prefilter away.........:blink:
  • Confused 1
Achto
I usually spritz it with light coat of K&N filter oil. I've had the same can for about 6yrs.
https://www.oreillyauto.com/detail/c/k-n-engineering/k-n-engineering-12-25-ounce-air-filter-oil/kan0/990516
I check it over at oil change time. If it looks dirty then I grab the K&N cleaner, spray it down, scrub, rinse, and re-oil. Again, this stuff goes a long way, think my cleaner bottle is about the same age as the oil.
https://www.oreillyauto.com/detail/c/k-n-engineering/k-n-engineering-1-quart-oiled-cotton-air-filter-cleaner/kan0/990621
  • Like 4
rick
I do as @lynnmor does.  No mess in the air box but plenty of fines on the prefilter.
Dawn dish soap and warm water easily clean the foam, I squeeze the foam dry in paper towels and let it air dry a day or so before oiling with the same oil I put in the crankcase.
Edited by rick
To add cleaning detail.
  • Like 4
lynnmor
The only difference between the two available Kohler filters on my zero turn is that the commercial filter uses a pre-filter, so I added one.  :greetings-waveyellow:
Racinbob
As I said, I never oil it. After every mowing I'll at least knock off the crud it catches. Every few mowings I'll remove the paper filter and tap it clean. I figure the paper filter is all a lot of engines get and it works fine. The pre-filter just catches a bunch before it gets to the main filter. Even without oil.
Edited by Racinbob
SylvanLakeWH
I always do. The amount of crap it catches is proof positive that it works. Never any residual in the housing...
I guess I have to ask why wouldn't you? So what if it's a bit messy. Am i missing something?
702854boy
In my mind, better in the filter and filter housing than the engine. Easier to clean a little mess than to rebuild an engine.
Racinbob
For many years (decades) pre-filters were never used and nobody thought a thing about it. I have no problem not using the foam at all for that reason. I see the pre-filter as just that. Used for stopping the frog size chunks from getting to the real filter. It works well for me, for that purpose.
midpack
I use them and use the foam filter treatment I used to use on my dirt bike air filter. That stuff works great and doesn't make a mess in the air cleaner housing
WHX??
Not as bad as oil filters ... :rolleyes:
Gotta pull the trigger on the right ones.
Wadda you go to the Pullstart school of just ain't  right?? :laughing-rolling:
4 hours ago, Ed Kennell said:
maybe oily Pete.
Not a squeaky filter in the house ... :lol:
No never supposed to blow out air filters except for maybe the shop vac. Guys to to blow out furnace air filters but all that does is loosen it up to get sucked through,
Little known fact ...  a filter catches smaller particles the dirtier it gets. The holes air must pass through get smaller and smaller till it won't pass air at all.
That's when that dash light won't come on because the nipple broke off the back of the sensor ... :huh:
Handy Don
:text-yeahthat:
  • Similar Content
    • Bill Sherman
      By Bill Sherman
      My 1986 417-8 is equipped with the anti-icing system air cleaner and I am having trouble finding the correct element for it.  I have yet to even find out what is the correct part number.  It is 6 inches OD and 1 7/8 high.  Any help would be greatly appreciated.
